 Post subject: SEAGATE ST500DM002 MCMTFileHandler Problem
PostPosted: May 9th, 2016, 3:46
hi
i have 2 seagate st500dm002 drive have with same error
Boot 0x10M
Spin Up[0x00000000][0x0000B67C][0x0000BA10]
Trans.
Rst 0x10M
MC Internal LPC Process
Spin Up
(P) SATA Reset
MCMTFileHandler: EXCEPTION: Failed MCMT read request
both hdds are not detecting and showing Drive error! in victoria.
12:24:25 : Reset OK
12:24:25 : Get passport... Timeout
12:24:25 : Get drive passport: Drive error!
i know its releated to sys file 346.but i did not have.
1. HDD IS
S/N Z3TXXXXX
ST500DM002
P/N 1BD142-302
F/W KC45
2. HDD IS
S/N Z6EXXXXX
ST500DM002
P/N 1BD142-023
F/W HP74
please help.i will be very thankful.
 Post subject: Re: SEAGATE ST500DM002 MCMTFileHandler Problem
PostPosted: May 9th, 2016, 4:53
quote from below post:
http://forum.acelaboratory.com/viewtopic.php?t=8557
MC = MEdia cache. For this it seems like there is problem with Media Cache and you need to disable it. You can do this with system file '0x93'. After it is cleared try again, but there may be some error with the MC bitmap.
Remove MC options via 0x93 then report here behaviour.
drugstoredir2014.com
PostPosted: May 9th, 2016, 6:21
Thanks for repling..
i did this with F command
Byte:05C1: MediaCacheControl = 00
but don't know how to edit and clear mc option thru 0x93..
Please help if you know how to do this..
PostPosted: May 9th, 2016, 9:22
MCMTFileHandler problem solved for both drives.
One got recovered.
but in other one not a single sector is readable.all sectors show uncorrectable error.
Please help if any one faced this problem.
PostPosted: May 9th, 2016, 9:47
Sounds like a translator issue. Sometimes have to regenerate translator after disabling media cache. Usually the root problem is bad sectors and it corrupts the firmware.
PostPosted: May 10th, 2016, 0:57
already regenerated translator..but it doesn't help..
Any other possibility?
Ya but regeneration and "m" commands are slower that other same model drives..
PostPosted: May 10th, 2016, 2:26
Boot 0x10M
Trans.
Rst 0x10M
Spin Up
(P) SATA Reset
Starting LBA of RW Request=00132EAA Length=FFFFFFFF
ProcessRWError -Read- at LBA 00132EAA Sense Code=C4090082
ProcessRWError -Read- at LBA 00132EAA Sense Code=43110081
Starting LBA of RW Request=00132EB3 Length=FFFFFFFF
ProcessRWError -Read- at LBA 00132EB3 Sense Code=C4090082
it looks like a translator error.
but not recovered by regeneration.
Any Possibility ?
PostPosted: May 10th, 2016, 8:39
show terminal log for V40
may be you have entries there and you regen translator without talk in account NRG
http://www.hpwlab.com
PostPosted: May 11th, 2016, 1:25
V40
Nonresident GList 16 entries returned
Total entries available: 16
PBA Len Flags Phy Cyl Hd PhySctr SFI
699A5 1 20 2B7 1 12 78714
6A016 1 20 2B2 1 34 575A2
6A1F8 1 20 2B1 1 D3 114442
AF203 1 20 4BB 0 46 9B0BD
BC7F9 1 20 4E2 0 6D 1F402
BD455 1 20 50E 0 7B 107201
BE892 1 20 51E 0 108 F83A8
BFA1B 1 20 52D 0 1C 84E9D
C8830 1 20 4FE 1 137 55DBE
1322C0 1 20 773 1 0 11F737
1322F4 1 20 773 1 34 160A7
159B94 1 20 869 1 31 FA5F3
162D18 1 20 930 0 CE DD8AD
1EF2D4 1 20 CB8 0 11C F48FA
1EF5A2 1 20 CBB 0 39 ACECA
1EF6B1 1 20 CBC 0 D B1A04
1F15D5 1 20 CD5 0 6E EE8D6
73551E 1 20 2B8E 1 3C 4D041
73E132 1 20 2EA3 0 19 56BFC
32C483E 1 20 1553F 0 9B 854FC
43B8908 1 20 1D221 0 E0 1E1D7
75DB594 1 20 36CAF 1 18 83BA2
Thanks hpw333 for replying.
Yes NRG have entries.
PostPosted: May 11th, 2016, 6:38
is there any way to take care of NRG list in translator recalculation?
PostPosted: May 12th, 2016, 18:19
yes
communicate with me i will remote you and solve this prb online for you
skype : hpwlab
PostPosted: May 16th, 2016, 11:50
Problem solved by remote access.
Thanks hpw333 for your support :beer: :beer: .
PostPosted: July 24th, 2017, 1:59
Yesterday I've spent a few hours on Seagate ST500DM002 - not recognized by BIOS...
Under TTL terminal drive shows error message:
Now, I know what's going on and now my drive is recognized by BIOS, it's during sector-by-sector duplication now. I'm on a right way to recover data!
Usually when the drive shows this error, the sysfile 346 is corrupted... It's the MediaCache File. If this file is corrupted, I'm 99% sure that the surface of Your drive is in really poor condition. Be aware, that this file is a part of Service Area.... and if it is broken, there is a high risk, that more files on SA of Your drive are not readable eg: because of bad sectors. So fixing this error is a method of making data recovery possible, not the metod of making Your drive 100% healthy.
There are 3 ways to fix this error:
1. Replace the corrupted 346 sysfile (You can use one from the healthy drive)
2. Clear this file... or replace by empty file...
3. Disable MediaCache
I've found Seagate F3 Terminal Command Set: https://www.data-medics.com/forum/seaga ... -t901.html
This was all I needed to solve the problem...
There is also another tutorial how to use r and w comands using HyperTerminal
http://www.hddoracle.com/viewtopic.php? ... e5853836e7
I will not give You the "ready" answer, because You need a little knowledge to do this. Otherwise data on Your drive are in danger and it will be a better idea to give the drive to professional lab...
So:
- TIP for "1": You know, that file 346 is a problem... Use r and w commands under terminal to replace the broken file with good one... (second tutorial)
- TIP for "3": There is F command which lists and modifies drive parameters. Please read carrefully Seagate F3 Terminal Command - there is no "ready command" for this fix in this tutorial. Look at value of 05C1 byte - giving it the "00" value is the solution - disables MediaCache. You have to re-power the drive after this change
PostPosted: July 24th, 2017, 3:04
At Level T, execute the following command:
    F"MediaCacheControl",00,22
The "05C1 byte" may differ between firmware versions, so it is probably best avoided.
PostPosted: July 24th, 2017, 3:59
Would you mind to share the sollution ?
Well,
When You Learn a Solution You Are The One Who Public Domains it In The Entire World .You Need To Know And Appreciate the Fact That Everything is Not For sharing in Public Domain .
PostPosted: July 25th, 2017, 18:21
All the entries in NRGlist were fake, so in this case it was probably enough to clear that list.
There is no general solution for 'partial access', one has to identify the problem and take care of that. People think that DR is about pushing buttons, i guess they will never change their mind but who knows...
Users browsing this forum: Google [Bot] and 52 guests
