Translator regeneration,Error "Maximam defect chain length"
May 10th, 2016, 0:22
Hello All,
Im facing this problem with segate drive..
Model : ST9500325AS
Serial : 6VEQHHPE
Firmware : 0002BSM1
Capacity : 465.76 GB (976 773 168)
Im using PC-3K UDMA
I was trying Translator Regeneration, which technique I used some time succefully.. but with this perticular drive got this Error
--> "Maximal defect chain length is reached!"
Find log Entry below..
Test : Recover translator
Start from LBA.......................... : 963401286
Translation "forks" list file........... : C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Wyatt\ST9500325AS-0002BSM1-6VEQHHPE\Defects\TranslationForks.lba
Maximal defect chain length............. : 1024
Take into account P-List................ : Yes
At ambiguity hide "left" UNC............ : Yes
Process "32 byte tail" bug.............. : Yes
Execute Reset after defect hiding....... : No
HDD ID reading...
Detecting defects hiding cmd type...
G-List erase...
Start scanning...
"Fork" searching: 963401286 - 976773167
Verify sectors ext error Device error detected "UNC"
"Right fork", LBA = 00963401286, pattern 0x00
Defects hiding (P)...
Moving defects to Slip-List...
Translator regeneration...
Try to analyse the HDD manually or increase the maximal defect chain length!
LBA : 963401286
--- Can anybody tell me how to proceed in this situation ? I already tried increasing length in option box, but every time getting same error..
- Vaibhav (Mum,IND)
Re: Translator regeneration,Error "Maximam defect chain leng
May 12th, 2016, 17:53
I'm not saying this will solve your problem, but to answer your question, set max length to "0" for "unlimited."
May 16th, 2016, 1:46
Hello Sir,
Thanks for reply.. I will defiantly try this out and let you know the result..
May 17th, 2016, 0:11
Hello Sir,
It works I got this message " Translator recovery is completed!"
Thank you so much..
May 17th, 2016, 12:52
My pleasure! Glad you got it!
