 Post subject: About hard level ST380817AS disk firmware update.
PostPosted: January 18th, 2017, 15:11
Hi, sorry my bad english.
My Seagate ST380817AS hard drive's PCB card crashed.
I bought new second hand Seagate ST380817AS hard drive and replaced PCB card.
But didn't benefical.
I think this. After discovered this detail: Config code mismatch.
My broken down Pcb config code: c4r-04 , I bought Pcb card congfig code: c4r-03.
It is mismatch.
My opinion is re-programming PCB card. But it is need mastership.
I can connect PCB card terminal interface. (with ttl adapter to Usb, baudrate 9600)
I can getting F> prompt and advanced commands can writable.
I can connect terminal, but i dont now command set. I cannot continune.
I want to PCB re-program, but I do not know.
In hdd guru available files:
http://files.hddguru.com/download/PC-30 ... gate/Puma/,
http://files.hddguru.com/download/Non-P ... gate/Puma/
But i do now know flash this files. Can you help me?
Thanks.
 Post subject: Re: About hard level ST380817AS disk firmware update.
PostPosted: January 19th, 2017, 4:09
Spildit wrote:
Sorryyyy ----
Verry silly of me ....
Happens all the time now...
You don't have to write ROM on F> at all ...
If you have a donor drive (entire drive) than you will be at level T> and you can write ROM (same version as of patient drive) from there.
You will need some sort of ST-10 firmware tool like St-Com lacking something better...
Any decent Seagate (ST-10) firmware tool should be able to write ROM to the PCB ...
Thank you for answer.
I understand, I can fix problem with STComTools. But STComTools software is unknown source and not easily to access..
Users browsing this forum: No registered users and 298 guests
