 Post subject: Toshiba Reset S.M.A.R.T Command
PostPosted: May 30th, 2016, 9:45
Hello all, I've a Toshiba 2.5' HDD (MQ01ABD075H), Detected model, capacity, S/N etc but shows
SIGNATURE SCAN FAIL
P90 FATAL
HDD FATAL ERROR
I've gone through http://www.hddoracle.com/viewtopic.php? ... ands#p2633, do not find the terminal command that I need
Can anyone share the command to reset S.M.A.R.T please
Thanks in advance.
 Post subject: Re: Toshiba Reset S.M.A.R.T Command
PostPosted: May 30th, 2016, 10:57
I doubt that there is a [mnemonic] instruction.
PostPosted: May 30th, 2016, 11:17
There is, but i doubt it will be shared so easy on the forum by request.
Angel Data Recovery
