 Post subject: WD 15EADS 1.5 TB - Unknown not Initialized 0 MB
PostPosted: May 27th, 2016, 11:25
Hello All,
Before I explain the problem, please know that I have been searching on this forum, and others, for solutions and couldn't find one explanation for it. So I hope you can help me and possible others that might have the same issue.
I have a WD Cavier Green 1.5 TB HDD that shows the following problem:
http://postimg.org/image/l8jzqsikb
Running the Western Digital LifeGuard Diagnosis I get the following:
http://postimg.org/image/uftxzll2z
Running the hard disk sentinel diagnosis software also returns "The status of the hard disk is unknown":
http://postimg.org/image/txdcdq4xn
I tried several recovery data software such as wondershare data recovery, mini tool partition wizard, easeUS data recovery, icare data recovery, getdataback... and none of them have worked.
I bought online another exact same WD 15EADS HDD and tried it in the same slot with same cable connections and worked fine. I then replaced the pcb between both HDD but nothing changed.
There is no clicking or weird noise from the HDD.
I am honestly without any ideas to solve this. I have access to a clean room and I bought a precision tool kit too, if necessary, to open the disk and check if the head is stucked - but as there is no strange mechanical noise I don't think that would be the cause of the problem, right?
I have important data in the hdd that I wouldn't want to lose and I can't afford like 500$ or more to recover the data in a professional laboratory.
Thanks for your time and hope you can help me at least to know that I have reached the end of the line and there is nothing more I can do ;)
Cheers
 Post subject: Re: WD 15EADS 1.5 TB - Unknown not Initialized 0 MB
PostPosted: May 27th, 2016, 15:48
I'd bet on some sort of firmware issue, assuming what said is correct (spinning normally with no untoward noises) and it's not been tampered with.
PostPosted: May 27th, 2016, 16:37
seem that this is not bad heads , and this is Firmware issue
needs to access SA modules then test all
and may be corrupted Rom in some cases
test only will decide reason for prb
http://www.hpwlab.com
PostPosted: May 27th, 2016, 17:18
Spildit wrote:
Ok, I'm willing to attempt to fix this drive then. If interested PM me.
Regards.
Should be fairly straightforward :-)
If you have the tools and know how to use them of course!
PostPosted: May 27th, 2016, 17:27
Does the drive spin up? What happens if you install the PM2 (Power Up In Standby) jumper? Does the drive then appear in BIOS?
PostPosted: May 27th, 2016, 18:06
I'm trying to determine whether PUIS has been enabled. The OP could use the good drive to compare how a PUIS-enabled drive shows up in BIOS. If module 0D in the ROM doesn't have a model number, then that could explain why BIOS doesn't report one.
PostPosted: May 28th, 2016, 12:25
Thanks for all the feedback!
While reading your suggestions and trying to understand the problem better, I compared both pcbs and they are in fact not entirely similar:
Patient Drive and PCB: WD 15EADS-00P8B0
2061-701640-700
Donor Drive and PCB: WD 15EADS-65P8B0
2061-701640-202
(Notice that the patient pcb in the donor drive results in the same problem as patient pcb+rom)
I guess this is the biggest difference between pcb and probably the root of the problem, they are different in the "chip c75" as shown bellow:
Patient:
http://postimg.org/image/wwlnyjzm3
Donor:
http://postimg.org/image/yahziod8r
I also read that buying a similar pcb would not solve this problem for these type oh HDD because they have very unique bio chips / firmware? And a transfer of the chips and welding aftweards would be necessary.
Spildit:
Do you think you can solve the problem if I ship you the pcb? do you need both of them? If yes we can PM. Thanks!
Cheers
PostPosted: May 31st, 2016, 19:15
buy PC3000, fix it and then return it... say you didnt like it :)
chances are you just need to tweak the headmap in RAM by switching it all to H0 or H1 to load up, then switch the map back and image.
