 Post subject: WD 1 TB - No Data Access : WDC WD10EARS-00Y5B1-80.00A80
PostPosted: June 26th, 2016, 15:23
Hello, ,
Cap : 1 TB
No Data Access , HDD detected DRD DSC.
unable to read any sectors .
Some Modules unable to Read from SA. Attached Screen Shot.
Module : 42............................. : Ok
Module : 43............................. : Ok
Module : 4E............................. : Ok
Module : 49............................. : Ok
Module : 4A............................. : Ok
Module : 4D............................. : Ok
Module : 03............................. : Ok
Module : 25............................. : Module (0025) read error Module ID 25 reading error Data request error - Device Error Detected: "FM ERR FILE ID"
Module : 26............................. : Module (0026) read error Module ID 26 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 38............................. : Module (0038) read error Module ID 38 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 39............................. : Module (0039) read error Module ID 39 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 37............................. : Module (0037) read error Module ID 37 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 2D............................. : Module (002D) read error Module ID 2D reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 2E............................. : Module (002E) read error Module ID 2E reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : B5............................. : Module (00B5) read error Module ID B5 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 6B............................. : Module (006B) read error Module ID 6B reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 3A............................. : Module (003A) read error Module ID 3A reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 28............................. : Module (0028) read error Module ID 28 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 3B............................. : Module (003B) read error Module ID 3B reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 3C............................. : Module (003C) read error Module ID 3C reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 3D............................. : Module (003D) read error Module ID 3D reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 3E............................. : Module (003E) read error Module ID 3E reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 3F............................. : Module (003F) read error Module ID 3F reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 6F............................. : Checksum error
Module : 116............................ : Module (0116) read error Module ID 116 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 118............................ : Module (0118) read error Module ID 118 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 119............................ : Module (0119) read error Module ID 119 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 68............................. : Module (0068) read error Module ID 68 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 69............................. : Module (0069) read error Module ID 69 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 6A............................. : Module (006A) read error Module ID 6A reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 120............................ : Module (0120) read error Module ID 120 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 04............................. : Module (0004) read error Module ID 04 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 05............................. : Module (0005) read error Module ID 05 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 3700........................... : Ok
Module : DE............................. : Ok
Should overwrite modules for Donar HDD ?
Please Help.
Alex
 Post subject: Re: WD 1 TB - No Data Access : WDC WD10EARS-00Y5B1-80.00A8
PostPosted: June 26th, 2016, 16:49
Both copies ?
Most of the above mod's are not required to access user area or can be taken from the same model/FW ver. (I.e. not unique to the HDD), Except for 25 & 38 in case of encryption.
But there is missing from the list you have provided some other unique mod's, why are they not on the list ?
PostPosted: June 27th, 2016, 1:05
All Modules Re-written from Exact Donar drive .
Now After SA Structure Test , all modules are ok .
But Still Can't Access Data , Any Sector Reading Gives Error - Address mark not Found.
How to Resolve ? Data is imp for client.
Regards,
Alex
PostPosted: June 27th, 2016, 4:29
You've re-written ALL mods from donor drive? :shock:
PostPosted: June 27th, 2016, 6:26
:shock:
No wonder... :(
PostPosted: June 27th, 2016, 6:59
I hope this was your own drive.
PostPosted: June 27th, 2016, 7:19
I'm afraid it's not.
PostPosted: June 27th, 2016, 8:16
I wonder how can be possible that many people located in Asia and Middle East, that don't know the basics of data recovery, can afford expensive PC3000 tool :?
On forum i see more and more people every day located in those area that have PC3000 but seem to know anything about data recovery.
How is possible that????
:shock:
My firmware database:
PostPosted: June 27th, 2016, 8:31
Everybody can buy a scalpel, but without knowledge end training you cant make a successful bypass operation.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: June 27th, 2016, 11:21
Maybe countries like India get lower pricing from Ace?
PostPosted: June 29th, 2016, 10:25
Sorry for Delayed Reply.
Not All modules Re-written .
Modules which are unique to Drive Specific are skipped like P list , Defect list SA & others .
Modules like 01 , 11 , 3c are over written .
I have Successfully Recovered Data from Hard drive .
Drive is fully Functional & imaged.
You may be Right Mr. michael chiklis , that Some Asian might not have good Data Recovery Knowledge but not in all cases.
We Value Client Data & so while doing any operation , we do take backup of 0 & 1 head SA & Tracks too.
Regards,
Alex
PostPosted: June 29th, 2016, 13:50
Yep, the best thing to do first of all is backup of SA :wink:
PostPosted: June 30th, 2016, 7:50
:shock:
have seen many post on this forum having expensive tools but not from Asia asking for help on the basic problems, so i think it is not common for Asia only. :)
i dont think so.
Data Recovery Pakistan
PostPosted: June 30th, 2016, 8:26
Any one in DR Business is always learning , no one is perfect & able to do all critical jobs .
Except Few , we are still unable to Resolve the problem of Seagate drives ROM Re-generation.
I mean if Seagate hard disk's ROM Damaged then no one can recover data .
Any way , All data Recovered from WD 1TB , thanks for reading .
Warm Regards,
Alex
PostPosted: June 30th, 2016, 8:34
OK we were fooled from this
and we thought by "all" you meant ALL.
Good job in recovering the data!!
PostPosted: June 30th, 2016, 8:53
:D :D Thanks northwind .
Alex
Users browsing this forum: No registered users and 110 guests
