 Post subject: Samsung S2 320 GB Portable - help identifying problem
PostPosted: June 19th, 2016, 11:12
Some day my HDD (Samsung S2 portable 320 GB) stopped being detected. I've tried to recover the data trying:
- soldering directly onto the HDD PCB SATA "terminals", - no result
- swapping the PCB from a working second identical drive I've bought - no result
- today I swapped the heads - no result - disc acts just like before swapping.
I posted a short movie with the cover open documenting the disk behavior.
https://youtu.be/JuoK2c9DwiM
Can you please tell me what is the cause of the behavior and is there a way to recover any data?
Regards from the great Bungholio.
 Post subject: Re: Samsung S2 320 GB Portable - help identifying problem
PostPosted: June 19th, 2016, 12:06
Not the best thing to power on the drive with lid off, and no cleanroom environment :(
Could be incompatible heads, bad surface....I can hear a high pitch note.
Take it to a pro if data is important.
http://www.rescue-it.se
PostPosted: June 19th, 2016, 13:54
Thanks for the reply.
Yeah, i know that it's a bad idea to open the HDD not in a clean room, but i consider those drives garbage so I'm just giving a try..
The data is not as important to pay the price for a pro recovery.
Regarding the head compatibility i really doubt that this could be an issue because firstly the drives are identical and secondly the head in the broken HDD before swapping behaved exactly the same.
So I think that now only a plate failure could be left and that means there is no way to recover the data at home.
What do you think?
PostPosted: June 19th, 2016, 15:41
How do you think the bad drive failed?
Users browsing this forum: siamak5561 and 76 guests
