 Post subject: WD external HDD cannot mount
PostPosted: June 15th, 2016, 3:47
Dear all,
Seems like I cannot attach a video to my post so it is only available through this link:
http://ovh.to/hCBS4Cy
Based on the video, is there a way I can fix this drive myself? What should be the steps to follow?
Many thanks for your kind assistance.
Elie
 Post subject: Re: WD external HDD cannot mount
PostPosted: June 15th, 2016, 17:02
You drive is acting like dead heads, also you have open the drive in a non clean environment and you have contaminated the drive, if the data has value to you I will take it to a "DR pro" is not much you can do to recover this drive, will need special equipment, convert the USB board to SATA and good chance your drive is an SED "Self Encrypted Drive" http://www.indodatarecovery.com/ give them a call.....
Users browsing this forum: No registered users and 268 guests
