Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2  Next
 Post subject: 7200.10 Barracuda stay Busy with continue terminal message.
PostPosted: June 20th, 2016, 6:10
Hello Sir,
Facing this problem with a segate 160 GB drive.. it Stays BUSY always.. spin continuously..
Not auto detect in my PC3K.. after manually selecting family(Selected family. : Barracuda 7200.10 Galaxy2D
Selected model.. : ST3160815AS) , shows below message on terminal ..
@`óûReset
4096k x 16 DRAM
NHAWK - 1_Disk S-3E 03-27-07_13:54
HM SFI
(P)SATA Reset
2000 0000 D80A 0000 0000 0001 0011 009F 005E 005F 0003 6000 00C0 F7B0 FC0E
DC54 5613 0002 001D E18C FFE1 21E5 FF43 FF23 4398 4649 0146 494E 0146 493D 0005
0000 0000
SP=F7A4
0000 : C4FA 02C6 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34
0020 : C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34
0040 : C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34
0060 : C4FA 0F34 C4FA 0F34 C4FA 49DE C0FA 4934 C0FA 5648 C4FA 0F34 C4FA 49DE C0FA BEC4
0080 : C4FA 0F34 C4FA 0F34 C6FA 0BC8 C6FA 0A9A C0FA FCA0 C4FA 0F34 C6FA 0D0A C0FA E926
00A0 : C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 40E2 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34
00C0 : C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34
00E0 : C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34
0100 : C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 1076 C6FA A7D0 C4FA 0F34 C4FA 3952
and it continue with same figures..
why terminal showing this output ?
 Post subject: Re: 7200.10 Barracuda stay Busy with continue terminal messa
PostPosted: June 20th, 2016, 6:28
I THINK ROM IS BROKEN
his disc is a read-only ....... T2 with the backup firmware later found forgot to find a similar firmware After writing bad sectors found only the beginning for Class B ....... After 93 and later stopped!
PostPosted: June 20th, 2016, 8:00
Thanks for quick reply.. how to proceed then ?
PostPosted: June 20th, 2016, 8:39
T>FASCIFE
power off
and write stuff
PostPosted: June 22nd, 2016, 1:56
Moltke wrote:
T>FASCIFE
power off
and write stuff
But not gettong T as script shown above displays continuously .. it U5 drive..
PostPosted: June 22nd, 2016, 5:29
NHAWK can not be U5
And this is a problem with the Stuff
since
(P)SATA Reset
App-code already loaded
PostPosted: June 22nd, 2016, 6:09
Hello Moltke,
Just confirmed with customer.. His IT person tried with "similar PCB of other drive" without ROM swap to make it operational.. and he said the PCB with drive is original as he made it "as it is "..
Seage 7200.10 , ST31608115AS is in segate utility of U5.. as drive is busy always.. I manually selected drive from utility.. and Model number is available for selection..
So the conclusion is , the IT guy mess up with ROM.. isn't it ?
PostPosted: June 22nd, 2016, 10:29
So what ? its prior to F3, not a big deal.
PostPosted: June 22nd, 2016, 13:38
Good day VaibhavS.
no. the conclusion is that we need to bring order to the disk configuration on the vendor tracks.
PostPosted: June 23rd, 2016, 7:32
Hello All,
Thanks for keeping me on track.. and giving hints for my query,
I search on different forum for my query and I think loader for Seagate is solution for my problem,
I went through procedure.. and found loader on web..
but Im confuse on which options to select on loader element window..
PostPosted: June 23rd, 2016, 7:34
Also , is it correct loader ?
PostPosted: June 24th, 2016, 2:33
Hello all,
Sorted out :D its go to basic formula.. loader works successfully..
Thanks all ..
PostPosted: June 24th, 2016, 12:58
Hi there!
I have a very similar case.
After i changed head stack assembly the drive stays bsy, and i have a terminal like this:
Reset
4096k x 16 DRAM
NHAWK - 1_Disk    S-3E   05-14-08_14:46
Buzz HM SFI
(P)SATA Reset
0100 : C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 1076 C6FA A97E C4FA 0F34 C4FA 3952
0120 : C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 FFFF FFFF C4FA 0F34
0140 : C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34
0160 : C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34
0180 : C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34
01A0 : C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34
01C0 : C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34
01E0 : C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34 C4FA 0F34
0200 : F4EC F5EC F7EC C0DA FFA6 C4DA 077C 1170 162D F1F6 B500 24C0 945C F5F2 B502 F7F2
0220 : FF1C C0DA FE38 C4DA 06FE 738A 1008 F1F2 B502 92E0 126C 738A 2002 C4DA 0260 C4DA
0240 : 06FE F7FC F5FC F4FC 00DB FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0260 : 88BE F1F6 2F50 89E6 00C4 03CC 009B FFFF 88BE 739A 100D F4E6 001B 41E0 00D7 00C0
0280 : 41B8 F4E6 A578 61E0 00D7 00C0 41B8 00CC 89E6 0000 48B7 B7B7 FFBF FFBF 009B FFFF
02A0 : 4653 616C 6873 5520 736E 7075 6F70 7472 6465 FF06 2FD8 D002 002C 2FD6 440D 002D
02C0 : 2D4E 7300 002C 88E6 0000 5AA5 A5A5 0CE6 0003 0DE6 8B3D 80D1 EEE6 0200 8EF6 F1D0
02E0 : 80D1 EAE6 0204 08E6 F600 00E6 009F 01E6 005E 02E6 005F 03E6 0003 23E0 F6F7 2FD8
0300 : 09CC 0BE6 FA36 0AE6 F91E 09E6 FA36 E0E6 F000 E1E6 0000 80D1 E1E6 0000 E2E6 FFFF
0320 : E3E6 D77B 80D1 E3E6 0000 F0E6 0853 F0F6 EE00 F0E6 0033 F0F6 EE12 F0E6 28B8 F0F6
0340 : EE10 F0E6 0033 F0F6 EE1A F0E6 28F8 F0F6 EE18 F0E6 27C3 F0F6 EE1E F0E6 0033 F0F6
0360 : EE2A F0E6 28F8 F0F6 EE28 F0E6 1007 F0F6 EE2E F0E6 0011 F0F6 EE32 F0E6 28DC F0F6
0380 : EE30 F0E6 2500 F0F6 EE36 5AE6 0126 D8E6 88D1 5BE6 015C B6E6 0000 B7E6 000C B8E6
03A0 : 0000 80D1 CEE6 0095 4AB5 B5B5 F1E6 FDFE F0E6 FF1C 10C8 F1B2 FF1C FC3D 08E6 FA36
03C0 : 00CC 8946 00C4 332D F0E6 D770 C4DA 060C C4DA 04B2 F4F6 FBCA F4F6 FE0E 06F2 FF1C
03E0 : F4E6 0200 444B F4F2 FE0E 4128 F4F6 2CD6 F2E6 00C0 F3E6 FD00 F1E6 017E 84E0 F5E6
0400 : 0B00 C4DA 0456 C4DA 09B8 F2E6 00C0 F3E6 B780 F1E6 22C0 84E0 F5E6 BA80 C4DA 0456
0420 : C4DA 046C 00CA 0686 C4DA 09C2 120D F2E6 00C0 F3E6 FD00 F1E6 017E F4E6 00C4 F5E6
0440 : 0B00 C4DA 0456 00CA 0686 C4DA 09C2 C0DA FFBE C4FA 5416 04DC 65A8 02DC 63B8 3208
0460 : 2018 5208 4018 1128 F63D 00DB F8F2 2CD6 8EF6 2CD6 04E0 00E6 0040 01E6 0041 02E6
0480 : 0042 03E6 0043 83E0 01E0 03DC 21A8 24B8 4208 1208 FA3D 00E6 009F 02E6 005F 03E6
04A0 : 0003 01E0 F1F6 2F50 F8F6 2CD6 89E6 00C4 00DB F5E6 FFFF F4E6 1DFE F5F6 2CD2 F5F6
04C0 : 2CD4 F6E6 DEAD 64B8 F6E6 BEEF 64C4 0200 64A8 76F0 7108 34F0 F1E6 FFFF 1108 F146
04E0 : 0800 179D F1F6 2CD2 23A8 83D4 0200 F846 BEEF 023D F246 DEAD F13D F5F6 2CD2 74B8
0500 : F1F6 2CD2 23A8 2740 122D F5F6 2CD2 64B8 E50D F3F2 2D44 F39A D008 F366 0C00 F346
0520 : 0400 033D F1E6 03FF 113D F1E6 00FF F5F6 2CD2 64B8 F146 03FF 093D F3E6 F3FF F364
0540 : 2D44 F2E6 0400 F274 2D44 B30D 1108 315C 41F0 02E0 F146 0800 092D F2E6 0800 F146
0560 : 2000 042D F2E6 0400 F146 4000 F3E6 F3FF F364 2D44 F274 2D44 00DB C6E1 F675 2FD6
0580 : F3E6 F3FF F364 2D44 F3E6 0400 F374 2D44 13E0 F3F6 2CD6 F1E6 DEAD F2E6 BEEF 03E0
05A0 : 10D7 0010 13B8 23C4 0002 09CC 10D7 0010 4398 53A8 4140 023D 5240 272D F3E6 335C
05C0 : F3F6 2D5A F3E6 8BB6 F3F6 2D5C F6E7 004E F6F7 2D48 F3E6 F3FF F364 2D44 F3E6 2800
05E0 : F374 2D44 03E0 10D7 0010 13B8 23C4 0002 09CC 10D7 0010 4398 53A8 4140 023D 5240
0600 : 042D F3E6 DFFF F364 2D44 00DB 8946 00C4 0D2D D2E1 F2F7 2FD6 F253 2FD6 F1E6 0040
0620 : F1F6 2D44 F3E6 05EB F3F6 2FDA F1E6 02B4 F4E6 00C4 24DC 41A9 51F4 0001 61F4 0002
0640 : 62B9 1308 4018 F446 00C4 F48D F146 02C3 F1FD F3E6 455C F3F6 2D5A F3E6 8CC6 F3F6
0660 : 2D5C F6E7 0013 F6F7 2D48 03E0 F3F6 2FDC F3E6 0037 F3F6 2D58 F2E6 0FA0 02A0 FE3D
0680 : C4DA 057A 00DB 92E1 F2F7 2BA6 F3E7 00F6 C0DA FD68 F267 FFF8 F3E7 0076 C0DA FD36
06A0 : F3E7 00F6 C0DA FD68 2769 F14A 12F1 F2F7 BC82 00CB B0AC F4EC F4E6 0220 F1E6 0200
06C0 : F3E6 FF00 60D7 009F F1F6 2FD0 135C F4F6 2FD0 E04A 80F3 F38A F0F5 40D7 009F F1F6
06E0 : 2FD0 F4FC 00DB F3EC 76F1 C0DA FF1E 75F1 C0DA FF1E 74F1 C0DA FF1E F3FC 00DB E18E
0700 : E19F E09F 01E0 F1F6 2FD0 00DB 67E1 C0DA FF56 C0DA FF60 F7E7 0050 C0DA FF56 C0DA
0720 : FF60 17E1 C0DA FF56 07E1 C0DA FF1E C0DA FF60 C4DA 076C 6169 FC3D 00DB 67E1 C0DA
0740 : FF56 C0DA FF60 F7E7 0050 C0DA FF56 C0DA FF60 17E1 C0DA FF56 C7E1 C0DA FF1E C0DA
0760 : FF60 C4DA 076C 6169 FC3D 00DB 57E1 C0DA FF56 C4DA 06B6 C0DA FF60 00DB F4EC F3EC
0780 : F2EC C4DA 076C 37E1 C0DA FF56 F2E6 0140 C0DA FF64 C4DA 06B6 86F1 C4DA 06B6 96F1
07A0 : C0DA FF60 01E0 F446 A578 213D 37E1 C0DA FF56 F2E6 0144 C0DA FF64 C4DA 06B6 86F1
07C0 : C4DA 06B6 96F1 C0DA FF60 F4F6 B502 37E1 C0DA FF56 F2E6 0142 C0DA FF64 C4DA 06B6
07E0 : 86F1 C4DA 06B6 96F1 C0DA FF60 14F0 F2FC F3FC F4FC 00DB 00DB 00DB F3EC 67E1 C0DA
0800 : FF56 C0DA FF60 27E1 C0DA FF56 F3FC C4DA 06E6 C0DA FF1E C0DA FF60 C4DA 076C 6169
0820 : FC3D 00DB 37E1 C0DA FF56 C4DA 06E6 C4DA 06B6 C0DA FF60 00DB 715E 714E 716E 67E1
0840 : C0DA FF56 C0DA FF60 F7E7 00C7 C0DA FF56 C0DA FF60 00EA 085A 715F C4DA 076C 6169
0860 : FB3D 718A 501C F7E7 0062 C0DA FF56 C0DA FF60 00EA 0878 716F C4DA 076C 6169 FB3D
0880 : 718A 600D F7E7 0060 C0DA FF56 C0DA FF60 00EA 0896 714F C4DA 076C 6169 FB3D 00DB
08A0 : 745C 67E1 C0DA FF56 C0DA FF60 F7E7 00AF C0DA FF56 C4DA 06E6 7599 C0DA FF1E C0DA
08C0 : FF60 C4DA 076C 6169 FC3D 4128 F7E7 00AF C0DA FF56 7599 C0DA FF1E C0DA FF60 C4DA
08E0 : 076C 6169 FC3D 4128 F13D 47E1 C0DA FF56 C0DA FF60 00DB F2EC F3EC F5EC F6EC F8EC
0900 : F8F2 2CD6 25F0 F2F6 2CD6 00E6 0040 01E6 0041 02E6 0042 03E6 0043 57F0 06E1 27F0
0920 : 718A 500E 718A 600C 718A 4006 F1E6 02A0 C4DA 3E9C 00EA 0998 C4DA 08A0 00EA 0998
0940 : 67E1 C0DA FF56 C0DA FF60 27E1 C0DA FF56 C4DA 06E6 6598 7CF1 C0DA FF1E 7DF1 C0DA
0960 : FF1E F6E6 007F 6560 F53D C0DA FF60 F3EC C4DA 076C 6169 FC3D F3FC 4128 0D2D F206
0980 : 0080 DE3D 6109 00E6 0044 01E6 0045 02E6 0046 03E6 0047 D40D 00E6 009F 01E6 005E
09A0 : 02E6 005F 03E6 0003 F8F6 2CD6 F8FC F6FC F5FC F3FC F2FC 00DB 731E 732E C4DA 0200
09C0 : 00DB FCF2 2CE0 FC8A 7002 6B7E 00DB 6B7F FCE6 FFFD FC64 2CD0 40D7 0303 FCF2 3FFC
09E0 : FC46 A578 21EA 0A80 FDF2 2A12 FD0E FDF6 2A12 FDF2 2A0E FD66 FF0F FD5F FDF6 2A0E
0A00 : F2F3 BC82 F18A 2008 FDF2 2A0E FD66 FF0F FD76 0090 FDF6 2A0E FCE6 7878 FCF6 2AFA
0A20 : FCF6 2AFC 2DE0 FD74 2CD0 4DE0 FDF6 2A1A FDF6 2A1C FEE6 FFFD FE64 2CD0 C4DA 0A82
0A40 : FCE6 A494 FCF6 2A22 FDF2 2A1A FD66 0FFF FD76 C000 FDF6 2A1A FDE6 96A8 FDF6 2A26
0A60 : FEF2 2A9A FEEF FEF6 2A9A B78A 7009 FEF2 2A12 FE0F FEF6 2A12 FEE6 1818 FEF6 2A28
0A80 : 00DB 2CE0 FC74 2CD0 FCE6 0C23 FCF6 2A48 FDE6 0C25 FDF6 2A4A FEE6 FFFD FE64 2CD0
0AA0 : 00DB FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0AC0 : FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0AE0 : FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0B00 : F2E6 0415 10D1 884A B971 88BE F1EC F2F3 2BA6 F19A 40FC F1FC F2F6 2BA4 F6F7 2BA2
0B20 : F1F6 2BA0 778A A004 F2F3 2BA6 F19A 40FC 714A 9B88 00DB F2E6 0405 10D1 884A B971
0B40 : 88BE F1EC F2F3 2BA6 F19A 40FC F1FC F2F6 2BA4 F1F6 2BA0 778A A004 F2F3 2BA6 F19A
0B60 : 40FC 714A 9B88 00DB F2E6 0485 F1FF 10D1 884A B971 88BE F1EC F2F3 2BA6 F19A 40FC
0B80 : F1FC F2F6 2BA4 F3F7 2BA0 7C4A 80F1 30EA FD9E F2F3 2BA6 F19A 40FC F2F3 2BA0 714A
0BA0 : 9B88 00DB F2E6 0495 F1FF 10D1 884A B971 88BE F1EC F2F3 2BA6 F19A 40FC F1FC F2F6
0BC0 : 2BA4 F3F7 2BA0 7C4A 80F1 30EA FDDE F2F3 2BA6 F19A 40FC F3F3 2BA1 F2F3 2BA0 714A
0BE0 : 9B88 00DB F4EC F4E6 0220 F1E6 0200 F3E6 FF00 70D7 009F F1F6 2FD0 135C F4F6 2FD0
0C00 : F4F6 2FD0 E04A 80F3 F38A F0F3 F2E6 FF00 70D7 009F F1F6 2FD0 125C F4F6 2FD0 F4F6
0C20 : 2FD0 E04A 80F2 F28A F0F3 40D7 009F F1F6 2FD0 74F1 F4FC 00DB F2EC F3EC F5EC F6EC
0C40 : F8EC F8F2 2CD6 F5F6 FE0E 86E0 FAF2 EE2E FA66 000F 6A4C 664B 07F6 2CD6 00E6 0040
0C60 : 01E6 0041 02E6 0042 03E6 0043 40D7 0003 0646 0000 0F2D 40D7 0003 FAF2 FE0C 5A7C
0C80 : 70D7 0003 FA04 FE00 FA04 FE02 FA04 FE04 FA04 FE06 57F0 37E1 C0DA FF56 27F0 C0DA
0CA0 : FF64 C0DA FDE4 35B8 5208 4128 0D2D 5570 F83D 70D7 0003 0006 0004 0106 0004 0206
0CC0 : 0004 0306 0004 ED0D C0DA FF60 00E6 0040 40D7 0003 0646 0000 092D 40D7 0003 FAF2
0CE0 : FE0C 5A7C 40D7 0003 FA04 FE00 F6E6 0140 F3E6 013C 63D8 3208 F646 0200 FB3D 00E6
0D00 : 009F 01E6 005E 02E6 005F 03E6 0003 F8F6 2CD6 F8FC F6FC F5FC F3FC F2FC 00DB F3EC
0D20 : F4EC F4E6 0220 F1E6 0200 E18F F376 00FF 60D7 009F F1F6 2FD0 F34A F8E0 F4F6 2FD0
0D40 : 135C F38A 70F5 E18E 40D7 009F F1F6 2FD0 F4FC F3FC 00DB E09E 00CC C0DA FF1E 00DB
0D60 : E09F 00DB F3EC 07E1 C0DA FF1E 75F1 C0DA FF1E 74F1 C0DA FF1E F3FC 00DB F5EC F6EC
0D80 : 37E1 C0DA FF56 27F0 C0DA FF64 C0DA FDE4 00D7 00C0 35B8 5208 4128 F83D C0DA FF60
0DA0 : F6FC F5FC 00DB E09F E19F F2E7 00F0 F2F7 2FEB F1E6 0200 F1F6 2FD0 E18E 00DB C0DA
0DC0 : FFA6 F7E6 BA80 F4E6 22C0 F5E6 B780 C0DA FF7C C4DA 06FE C0DA B8D4 09CC C0DA FFA6
0DE0 : 07E0 F4E6 5D40 05E0 C0DA FE38 C4DA 06FE 00DB FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0E00 : 0E32 00C7 4138 00C7 412A 00C7 FCC4 00C5 390C 00C4 2AFF 0320 B616 6F20 206E 1703
0E20 : 06B6 2D53 4533 2020 3020 2D35 3431 302D 5F38 3431 343A 0636 F1E6 0A0D C4DA 0E78
0E40 : 23F1 1A0D 14F0 C17C C4DA 0E68 14F0 817C C4DA 0E68 14F0 417C C4DA 0E68 14F0 C4DA
0E60 : 0E68 F2E7 0020 080D F267 000F F247 0009 01FD 2709 F207 0030 B69A 70FE B67E F2F7
0E80 : FEB0 00DB C4DA 0E38 24F0 5420 157C 06E0 F2E7 0053 C4DA 0E78 F2E7 0050 C4DA 0E78
0EA0 : F2E7 003D C4DA 0E78 47F0 C4DA 0E44 C4DA 0E38 42F0 C4DA 0E44 F2E7 003A C4DA 0E78
0EC0 : F2E7 0020 C4DA 0E78 4298 C4DA 0E44 6108 6540 072D C6F0 FC66 000F F63D C4DA 0E38
0EE0 : E80D C4DA 0E38 00DB F4F2 FBC8 F5F2 FBC6 F7F2 FBC0 C4DA 0E84 F4F2 FBC4 F5F2 FBC2
0F00 : F7F2 FB9E C4DA 0E84 00DB C4DA 0E38 F926 0010 F5E6 0020 06E0 0ADC 4998 C4DA 0E44
0F20 : 6108 C6F0 FC66 000F 023D C4DA 0E38 6540 F33D 00DB 8876 F000 00CC 08C6 FDDE 00CC
0F40 : F0F2 FE12 F3F2 FE16 F2F2 FE14 80D4 0000 90D4 0002 A0D4 0004 B0D4 0006 09E6 FDDC
0F60 : 0BE6 FDDC 0AE6 F610 00CC E2AF E3AF 80D1 E3AF 5AE6 0126 D8E6 88D1 5BE6 015C B6E6
0F80 : 0080 B7E6 0000 B8E6 0000 80D1 CEE6 0000 58E7 0000 C4DA 0E38 F4F2 FFAC C4DA 0E44
0FA0 : 42F0 C4DA 0E44 40F0 F406 0008 C4DA 0E44 43F0 C4DA 0E44 F4F2 FF0E C4DA 0E44 F4F2
0FC0 : FE0C C4DA 0E44 F4F2 FE0E C4DA 0E44 F4F2 FE00 C4DA 0E44 F4F2 FE02 C4DA 0E44 F4F2
0FE0 : FE04 C4DA 0E44 F4F2 FE06 C4DA 0E44 4BF0 C4DA 0E44 4AF0 C4DA 0E44 49F0 C4DA 0E44
1000 : 48F0 C4DA 0E44 C4DA 0E38 28F0 F3E0 4298 C4DA 0E44 3128 FB7D C4DA 0E38 55E0 F1E6
1020 : D770 00D7 0000 4198 033D F502 FF1E F93D C4DA 0E44 55E0 F1E6 D370 00D7 0000 4198
1040 : 4048 033D F502 FF1E F83D C4DA 0E44 C4DA 0E38 C4DA 0EE8 C4DA 0F0A F1E6 0E0C 10D7
1060 : 00C4 2198 11A8 C0DA F85C D6F2 FF1C FCE6 03E8 C4DA 2488 C4FA 0270 6C9A 4002 C4DA
1080 : 1096 F2E7 0040 F2F7 2B12 02E1 F2F7 2B12 F1E6 FC00 00DB F2E7 0020 F275 2B12 52E0
10A0 : 718A F006 6C9A 4019 C0DA F8D0 2128 F83D 02E0 F1F2 2B26 F18A 000C 2128 FA3D 71DF
10C0 : F2F3 2B12 F18A 6005 F2E7 0040 F2F7 2B12 E60D C0DA BB12 C0DA BB12 00DB C0DA FA66
10E0 : 10D1 884A B971 88BE F1EC F2F3 2BD6 F19A 40FC F15E F2F7 2BD6 F1FC F4EC F2F2 2C50
1100 : F4F2 2C82 2420 F4FC F246 07D0 11AD 714A 9B88 C0DA F8DE 10D1 884A B971 88BE F1EC
1120 : F2F3 2BD6 F19A 40FC F15E F2F7 2BD6 F1FC F277 0001 F2E6 01C4 F2F6 2BD4 F2F7 2BD0
1140 : F2F3 2BD6 F19A 40FC F3F3 2BD0 714A 9B88 00DB 6C9A 3016 F19A 0014 F1EC F6F3 DD9D
1160 : F7F3 DD9E F3F6 B616 F6E7 00C4 F6F7 DDDD F3E6 0E15 F3F6 DDCE 80D1 CE6F 6C8A 30FE
1180 : F1FC 00DB 6F42 746F 6441 7061 6974 6576 0673 7352 5476 6172 6B63 6544 4C66 7473
11A0 : 4106 7070 6F43 6564 FF06 0005 0000 0005 00D5 0005 01AA 0012 0000 0012 00D5 0012
11C0 : 01AA 0000 0000 000B 0000 000C 001E 0018 0000 0019 001E 0000 0000 0000 1184 0042
11E0 : A55B 0001 1192 00C0 FFFF 0000 11A1 8E00 0000 00C4 11AA 00C4 11DA 0602 2800 00C4
1200 : 11C6 00C4 11EA 0401 0000 43F0 36D4 0002 67F1 F366 00FF 8CE0 3C1B F3F2 FE0E 4300
1220 : C6D4 000A 36D4 000C 3400 C018 0CDC 33A8 00DB F1E6 A700 76D4 0004 E7C0 26D4 000E
1240 : E541 0F9D 42E0 270B F7F2 FE0E E6D4 0006 D6D4 0008 D700 E018 1EDC 9DD4 0002 DDA8
1260 : 01E0 1170 00DB 82E0 240B FAF2 FE0E A408 E6D4 000A 26D4 000C 2A00 E018 0EDC A2A8
1280 : BAF0 00DB 2AF0 F266 003F 6A7C 5AF0 00DB F1E6 A700 C4DA 1232 283D 76D4 0002 F8C0
12A0 : 04E0 C4DA 1266 C4DA 1284 FA46 0280 1DED 4840 102D 4108 9A00 F946 0280 05ED 9008
12C0 : F946 0280 04ED ED0D 9AF0 D108 F80D F926 0280 FB0D 79F0 7A00 F746 0280 02FD D108
12E0 : 09E0 0EE0 76D4 0002 01E0 1170 00DB 01E0 76D4 0004 F79A F00A E109 76C4 0004 36D4
1300 : 000E E741 058D 0EE1 76C4 0004 F1F2 FF1E 1170 00DB C0DA F8B8 FEE6 0034 FFE6 B5A4
1320 : C0DA FC40 8FB9 F108 E128 FA3D 2EE0 FFE6 B59E C0DA FC4A 4FB8 F208 E128 FA3D 2EE0
1340 : FFE6 DEFE C0DA FC4A 4FB8 F208 E128 FA3D F1E6 4615 12E0 F6F2 DEFE 1620 2038 F1F6
1360 : B584 F2F6 B586 F106 017D 2018 F1F6 B588 F2F6 B58A C0DA FC40 F8F7 B645 C0DA F8C6
1380 : 00DB 26A8 36D4 0002 86F4 000D 0A2D F222 B584 F332 B586 02CD 127C 039D F1E6 FE00
13A0 : 0F0D 3048 FB3D 125C F202 B584 F312 B586 26B8 36C4 0002 08E1 86E4 000D 6E7F 01E0
13C0 : 00DB F7E6 3000 58E0 FEE6 0600 0FE0 C4DA 13D8 8EF6 B58E 00DB F2F2 2CD2 2088 8088
13E0 : 7088 C0DA F9F6 F2E6 FFFF 2088 C4DA 1402 E228 FB3D F128 F9DD 2098 2098 F2F6 2CD2
1400 : 00DB 1088 2088 10D4 0004 20D4 0006 12B8 2208 F29A D004 8F24 2CD2 F2E6 0000 20C4
1420 : 0006 2098 1098 0208 00DB 12E0 030D 02E0 F3F2 B58E F7E6 3000 58E0 FEE6 0600 0FE0
1440 : C4DA 1446 00DB 8088 1088 F1F2 2CD2 1088 8088 7088 C0DA F9F6 F8F2 2CD2 10A8 2088
1460 : 043D 21C4 0004 31C4 0002 21D4 0000 F252 FF1E 042D 2158 022D 02E0 180D 2D08 2D08
1480 : 2D08 2D08 F19A D004 8F24 2CD2 F1E6 0000 FE26 0008 F33D F128 F1DD E0A8 073D 10D4
14A0 : 0002 F8F6 2CD2 2081 21C4 0004 0408 1098 F1F6 2CD2 1098 8098 2270 00DB F5E6 0FFF
14C0 : C4DA 1564 FCE6 DD68 06E0 0DE0 FE46 FFFF 392D FA66 F000 C4DA 158A 31F0 F366 0FFF
14E0 : F166 F000 2B40 013D 1A40 0A2D 6048 2A2D FC46 DD8C 2B9D 5CB8 C208 6CB8 C208 220D
1500 : D108 6048 1A2D 23F0 2108 2540 082D FC46 DD8C 1C9D 5CB8 C208 6CB8 C208 0E0D 53F0
1520 : 6108 F646 000F 0B8D FC46 DD8C 0F9D 5CB8 C208 6CB8 C208 06E0 020D 53F0 16E0 E128
1540 : CADD D40D 01E0 FC46 DD8C 028D F1E6 5900 0C84 FF1E FDF6 DD8E F2E6 DD68 C0DA F9B2
1560 : 1170 00DB 58E0 F7E6 3006 F6E6 0022 A5F0 C45C A470 B2F0 1B7C 884A 1FFA F34A 0FFB
1580 : FEF2 B58E C0DA F950 00DB E088 42E0 2E1B F2F2 FE0E FEF2 FE0C 2700 E810 F1F2 2CD2
15A0 : 1088 E088 2088 C0DA F9F6 C0DA FA24 1098 C0DA FA24 2098 E098 E098 FEF6 2CD2 E098
15C0 : 00DB F246 0080 162D F1E6 931C C4DA 161E F246 0008 1B2D F1E6 9314 C4DA 161E FCEC
15E0 : FCE6 01F4 C4DA 4866 FCFC F1E6 9225 C4DA 161E 0C0D F1E6 9265 C4DA 161E F1E6 931C
1600 : C4DA 161E F1E6 9394 C4DA 161E 00DB C0DA F8DE C0FA FA7A C0DA F8DE C0FA FA88 C0DA
1620 : F8DE C0FA FA96 C0DA F8DE C0FA FAB6 4B4F 5406 7079 2065 1607 06B6 7453 7461 7375
1640 : 0720 B616 3D06 1603 06B6 88BE 2148 1F2D 2248 2A2D 2348 492D 2448 5A2D 2548 392D
1660 : 2648 312D 2748 322D F246 0008 5C2D F246 0009 352D F246 000A 5E2D F246 000B 5D2D
1680 : F246 000C 5D2D F246 000D 5D2D 600D F2F2 B61E F7F3 B622 06E1 739A 3002 F6F3 B626
16A0 : C4DA 07FA 02E0 5C0D F2F2 B61E 06E1 739A 2002 F6F3 B622 C4DA 0824 F6F7 B616 02E0
16C0 : F1E6 1645 4A0D C4DA 06FE 4A0D C4DA 0200 470D C0DA FFA6 C4DA 077C 2F3D 410D C4DA
16E0 : 077C 3E2D C4DA 0838 3B0D F1F2 B622 F3E6 0400 131B 07F6 B646 C4DA 1808 F4F2 B61E
1700 : F5F2 B622 F7F2 B626 C4DA 08F6 02E0 280D F4F2 B61E 645C F5F2 B622 F7F2 B626 C0DA
1720 : FE38 02E0 1D0D C4DA 076C 07E1 F3F6 B616 F1E6 163A 120D C4DA 0270 C4DA 070C 100D
1740 : C4DA 073C 0D0D F1F2 B61E C4DA 0260 C4DA 077C F1F6 B616 F1E6 1631 88BF C4DA 3E9C
1760 : 88BF 00DB B76E C0DA FFA6 C4DA 077C F1EC C4DA 06FE B76F F4FC 00DB F1F2 B61A F1F6
1780 : B646 02E0 739A 2002 F2F2 B622 2088 B76E C4DA 1764 4470 182D 52E0 C4DA 164A 92E0
17A0 : C4DA 164A 32E0 F1E6 0200 F1F6 B61E F1F2 B646 F1F6 B622 8EF6 B626 C4DA 164A 62E0
17C0 : C4DA 164A C4DA 183A B76F 01E6 005E 2098 F246 0022 032D A2E0 C4DA 164A 00DB C4DA
17E0 : 1764 4470 102D C0DA FFA6 F2E6 013B F2F6 B61E FCF6 B622 8EF6 B626 12E0 C4DA 164A
1800 : C4DA 06FE 14E0 00DB F6E6 013B 00D7 00C4 46A9 F1F2 B646 03E0 935C 61F0 915C 767C
1820 : 3670 F106 013B 3018 C4DA 1AF2 00DB 6843 736B 6D75 4520 7272 000A 9088 8088 7088
1840 : 6088 F8E6 0200 09E0 06E0 8EF7 B648 779A A006 FCE6 0006 C4DA 7B40 778A A0FE B76E
1860 : C4DA 28C4 52E0 C4DA 164A 42E0 F1E6 0200 F1F6 B61E F1E6 0900 F1F6 B622 8EF6 B626
1880 : C4DA 164A 62E0 C4DA 164A C4DA 28E4 FCE6 0900 D8F0 E9F0 C4DA 2214 E8F1 C6F0 EDC0
18A0 : C4DA 2832 64F0 8108 9018 78F0 C9F0 F726 FFFE C038 EC8D FCF2 B646 FDE6 FFFE 0EE0
18C0 : C4DA 21E6 C4F0 B76F C640 0D2D FCE6 182E FDE6 0310 C4DA 3856 1CE1 FCF7 B648 FCF3
18E0 : B648 C049 FC3D 6098 7098 8098 9098 00DB 3025 5834 000A 3025 5832 000A 6E49 6176
1900 : 696C 2064 6461 7264 7365 0A73 FF00 FDF2 B61A FEF2 B61C 739A 1007 EDF0 FDF2 FF1C
1920 : FD72 B61E FE72 B620 1CF0 2049 142D FD8A 000B 0EDC CDA8 C088 FCE6 18F0 FDE6 0310
1940 : C4DA 3856 0208 120D FCE6 18FC FDE6 0310 C4DA 3856 0B0D 0EDC 2DA9 2CC0 C088 FCE6
1960 : 18F6 FDE6 0310 C4DA 3856 0208 08E1 00DB 0CE0 C4DA 190E 00DB 1CE0 C4DA 190E 00DB
1980 : 739A 100C FCF2 B61A FDF2 B61C DCF0 FCF2 FF1C FC72 B61E FD72 B620 040D FCF2 B61A
19A0 : FDF2 B61C 739A 3007 FEF2 B626 FC8A 0009 0DDC ECB8 060D 739A 2004 F2F3 B622 0DDC
19C0 : 2CB9 DDF0 CCF0 FC9A 0002 02E1 010D 12E1 2CD0 C4DA 190E 00DB 9088 8088 7088 6088
19E0 : 6CF0 7DF0 08E0 09E0 F626 0020 F706 0020 0F0D C7F0 D8F0 FEE6 0200 C4DA 233E C4F0
1A00 : D5F0 FEE6 0200 F9F0 C4DA 289C 94F0 8108 8640 EF8D 49F0 6098 7098 8098 9098 00DB
1A20 : F3EC F3F2 2CD2 3088 F3FC 00DB F3EC 3098 00D1 F3F6 2CD2 F3FC 00DB 3088 1088 C4DA
1A40 : 1ADE 50D7 009F F3F6 2CD2 40D7 009F 41A9 1098 3098 00DB 3088 1088 1500 6019 C4DA
1A60 : 1A3A 1098 3098 00DB C4DA 1A3A 1108 6019 00DB 03DC 21A8 00DB 3088 1088 C4DA 1ADE
1A80 : F18A 0008 50D7 009F F3F6 2CD2 40D7 009F 21A8 140D 50D7 009F F3F6 2CD2 40D7 009F
1AA0 : 4199 F146 E000 033D 3108 F1E6 C000 50D7 009F F3F6 2CD2 40D7 009F 51A9 1098 3098
1AC0 : 00DB 3088 1088 1500 6019 C4DA 1A78 1098 3098 00DB C4DA 1A78 1208 6019 00DB 76F1
1AE0 : 63F1 537C F376 8000 F367 001F F106 C000 00DB 3088 1088 C4DA 1ADE 50D7 009F F3F6
1B00 : 2CD2 40D7 009F 41B9 1098 3098 00DB 3088 1088 1500 6019 C4DA 1AF2 1098 3098 00DB
1B20 : C4DA 1AF2 1108 6019 00DB 3088 1088 C4DA 1ADE F18A 0008 50D7 009F F3F6 2CD2 40D7
1B40 : 009F 21B8 150D 50D7 009F F3F6 2CD2 40D7 009F 41B9 1108 F146 E000 033D 3108 F1E6
1B60 : C000 50D7 009F F3F6 2CD2 40D7 009F 51B9 1098 3098 00DB 3088 1088 1500 6019 C4DA
1B80 : 1B2A 1098 3098 00DB C4DA 1B2A 1208 6019 00DB FA2A FFF4 086D 5B20 4A30 072D 02ED
1BA0 : FA3A FFFA FA4A FFF4 F4BC 4178 00DB FA3A FFFA 2AF0 F266 7F80 34F0 F366 7F80 3240
1BC0 : 069D 5B50 B550 5B50 4A50 A450 4A50 C4DA 1C62 A320 202D A081 FA46 0018 3CED 182D
1BE0 : 1A70 FA46 0010 0F2D ABF0 B16C 20A1 A14C FA66 FF00 1A70 A2F0 A14C BA70 20A1 216C
1C00 : F19A 4009 03E1 FB66 FF00 1B70 B2F0 020D 34F1 0BE0 02E0 F12A 65F1 036D 5B00 4210
1C20 : 0B0D 30A1 5B30 4230 0B2D 06ED 1091 5091 4091 3109 5018 4018 C4DA 1EA6 3048 03AD
1C40 : 05E0 04E0 0D0D F346 00FF 058D F5F2 FF1E 8AF1 83C0 3128 145C 96F1 147C F14A 5FF4
1C60 : 00DB 2AF0 F24A F6F1 42C0 1A5C 8A7C 883A 37F2 020D 4CF0 5DF0 F166 0040 34F0 F44A
1C80 : F5F1 84C0 135C 837C 883A 37F4 00DB 4CF0 5DF0 ACF0 BDF0 C4DA 1C62 3048 D12D A048
1CA0 : CF2D F17A 65F1 3A00 F326 007E 5B1B FAF2 FE0C 521B F5F2 FE0C FA02 FE0E 5018 4B1B
1CC0 : FA02 FE0E F512 FE0C 421B F502 FE0E 2AF0 34F1 8BF1 BAF1 A5F1 AF0D C4DA 1C74 3048
1CE0 : AF2D 3E00 AB0D FEF0 EF1B FEF2 FE0E FFF2 FE0C 0C0D FE9A F009 FFF2 FF1E FF9A F006
1D00 : F15F E081 F018 F081 020D 0FE0 F15E 4FF0 5EF0 C4DA 1EA0 F14A 56F1 A3F0 24F0 B5F0
1D20 : C4DA 1C74 BA0D C4DA 1C62 F17A 65F1 3048 872D A048 8B2D 3A20 F306 007F 825C ABF0
1D40 : 8A7C 2A70 7B5C FBFE A5F0 755C 745C 9A7C 4A70 F4F6 FE0C F5F6 FE0E 227B F4F2 FE0E
1D60 : 07F2 FF1C 227B F5F2 FE0E FBF6 FE0C 07F2 FF1C 227B FAF2 FE0E 4A1B FBF2 FE0C FAF2
1D80 : FE0E 02E0 AA00 BB10 2210 5B20 4230 3AF1 ABF1 B8F1 847C 00EA 1C38 C4DA 1C74 F18A
1DA0 : 505C 3048 5A2D D4F0 F326 007F C3F0 1CBC 883A 17FD C088 1C5C 3C20 C3F0 1CBC F306
1DC0 : 007F C4DA 1C38 5088 4088 FAE6 7F7F 0BE0 B088 A088 3CF0 F306 007F 4D7C 04E0 00D7
1DE0 : 00C4 8DF4 1E6C 05E0 C4DA 1C38 C4F0 D5F0 C4DA 1C8E A0D4 0004 B0D4 0006 C4DA 1BAE
1E00 : 5088 4088 1EE0 C4DA 1CDA A4F0 B5F0 4098 5098 C4DA 1D26 F43A FFF4 ACF0 BDF0 C4DA
1E20 : 1BB2 ACF0 BDF0 C4F0 D5F0 4A40 043D 5B50 157C 0E2D 5DF0 C4DA 1BAE F4FE A0A8 B0D4
1E40 : 0002 40B8 50C4 0002 C4DA 1B92 4048 D0CD F006 0008 A098 7A5C CA00 4CF0 5DF0 ACF0
1E60 : BDF0 C4DA 1C96 4CF0 5DF0 00DB C5BA D8CF EAE1 FBF3 8B83 9992 A69F B2AC 05E0 F15E
1E80 : 080D 54F0 F5BC F54A F5F1 037D 4081 5018 5081 4550 5450 4550 C4DA 1EA0 00EA 1C56
1EA0 : F3E6 0096 03E1 FBEC FAEC A42B 0C3D A52B 023D 03E0 230D 45F0 B3F1 0AE1 03E1 F326
1EC0 : 0010 A048 0F2D FA46 0008 132D B5F0 4A4C 5A4C A081 BA6C 4B70 B1F0 FB66 FF00 BA6C
1EE0 : 5B70 A081 F306 0008 3A20 3AF1 857C B8F1 847C F19A F003 5108 8019 3018 FAFC FBFC
1F00 : 00DB 4CF0 5DF0 FAE6 3F00 0BE0 F44A FFFA C4DA 1BB2 00DB C4DA 1F02 F3E6 001F 0A0D
1F20 : C4DA 1F02 F3E0 060D C4DA 1F02 020D 4CF0 5DF0 73E0 F2EC 23F0 F16E F48A F007 C4DA
1F40 : 1C78 3048 702D F346 007F 039D 04E0 05E0 6A0D 845C 8BF1 855C F326 007F 3220 39BD
1F60 : F4F2 FF1E 54F0 5F0D C4DA 1F02 F3E6 001F 070D C4DA 1F02 F3E0 030D C4DA 1F02 73E0
1F80 : F2EC 23F0 F16F C4DA 1C78 3048 4C2D F346 007F DC8D 845C 8BF1 855C F326 007F 3220
1FA0 : 18CD 0E3D F19A 500C F947 0080 093D 2748 322D 8049 053D F246 000F 352D B049 302D
1FC0 : F4E6 7FFF F5F2 FF1E F19A 5021 4091 5091 1E0D 3081 0F2D F39A 4005 54F0 04E0 F346
1FE0 : 0010 082D FBEC B4F0 436C 536C 3081 B34C 5B70 FBFC F19A 600B F19A 5009 F28A 4004
2000 : F07B 0C4A 0002 0C4A 5D35 7E29 000A 7E2B BCBA DD5F 0001 DD5F 04EF 549E 0007 549F
2020 : 5048 B216 0001 B217 1D87 98DB 0000 98DB FA03 DE3E 0003 DE3F C5FF C918 0009 C919
2040 : 44CB 1890 0003 1893 3F85 9145 0001 9145 8AAB 76B0 0002 76B2 C182 17F0 0007 17F7
2060 : 342B 9FBE 0003 9FBF 3135 131D 000F 131F 820F 0893 0003 0893 757E AFDE 000D AFDF
2080 : 471E 9A11 0000 9A11 AB87 6BFF 000B 6BFF 78AB 977B 0000 977B D5AA EDB5 0009 EDBD
20A0 : FDBC 4EB8 0003 4EBB 5387 1A5D 000D 1A5D 7437 C991 0002 C993 2F1F 91D9 0005 91DD
20C0 : CE36 B949 0002 B94B C4D1 CCF1 000F CCFF A94F D8C0 0000 D8C0 F277 EFFB 0006 EFFF
20E0 : 9410 00A7 0003 00A7 485D E184 0001 E185 3227 0EA9 0001 0EA9 BEBE F5AD 0004 F5AD
2100 : C834 6805 0003 6807 BF34 7B7D 0007 7B7F 8961 B30B 0002 B30B 008B A39B 0006 A39F
2120 : 30E5 2348 0001 2349 A746 554D 000A 554F BAE5 3299 0000 3299 FFD9 66B8 000A 66BA
2140 : 784B 116A 0003 116B EBCF 2BEC 0003 2BEF EF57 DBDD 0000 DBDD D253 3562 0002 3562
2160 : 96FC 9151 0003 9153 EB19 9A4D 0003 9A4F 73B8 D4AA 0003 D4AB 21FB F22A 0009 F22B
2180 : 9633 F8A5 0003 F8A7 FA9E 9348 000A 934A 1D57 A908 0000 A908 61D1 BFAF 0007 BFAF
21A0 : 36AE DB23 0000 DB23 E49B 3E72 000B 3E7B 9698 3190 0000 3190 BEDF 43A1 0006 43A7
21C0 : 123C DF9D 0002 DF9F DDED 08E9 0004 08ED 5841 915B 0000 915B 13A4 BA28 000E BA2E
21E0 : D04A 89FE 0000 89FE CA7F E0AF 000F E0AF FF88 9511 0000 9511 610A 1D2D 0002 1D2F
2200 : 3217 BB25 0003 BB27 827B 5329 0007 532F A62F 42C8 0000 42C8 6563 858F 0002 858F
2220 : 6F09 7598 0000 7598 7B87 3048 000F 304F F9A5 49DE 0003 49DF 7653 FDA5 0003 FDA7
2240 : 2B45 3D94 0000 3D94 EC91 F736 0008 F73E 4663 BA3A 0001 BA3B 4AF0 9EDF 0003 9EDF
2260 : 8E8B 6DF6 0002 6DF6 94ED 8040 0005 8045 767B 42BE 0003 42BF 64F7 A6B8 0002 A6BA
2280 : 4B93 F836 0002 F836 7D72 3C23 000A 3C2B 3D72 6325 0000 6325 0B9D B5A8 000A B5AA
22A0 : 297F 1BE7 0001 1BE7 82FE 0E35 000B 0E3F E9E8 1213 0003 1213 5F80 CC89 0002 CC8B
22C0 : FA09 7152 0002 7152 7342 AA3C 000B AA3F 8D39 796B 0001 796B 4455 2FB1 0003 2FB3
22E0 : C686 CEAC 0002 CEAE F00E 68AD 000F 68AF ECDB 2412 0001 2413 79EE 35F6 0002 35F6
2300 : 345C 64EA 0003 64EB 8FC2 1A0F 000B 1A0F BFA4 E02F 0003 E02F F427 6FA9 0009 6FA9
2320 : 78F9 34E5 0002 34E7 F853 D769 0004 D76D D021 90A5 0000 90A5 EBFC 7FCF 000F 7FCF
2340 : BCA7 3B5D 0002 3B5F EAE1 2E72 0009 2E7B 1069 3EED 0000 3EED 6401 5901 0000 5901
2360 : 1F7A 6375 0002 6377 1A87 0691 000A 069B 185F 38E8 0003 38EB 40D7 6B65 0000 6B65
2380 : 7656 F60D 0001 F60D ED88 5D6A 000F 5D6F 1ABB 9AF9 0002 9AFB CFD9 3AC1 000C 3ACD
23A0 : 0FB8 30DB 0002 30DB F702 3782 000F 378F BF6A DB5D 0002 DB5F 92F7 92C5 000E 92CF
23C0 : 76A2 F68C 0003 F68F AC90 2DEF 0003 2DEF CA93 1871 0003 1873 D329 06A8 000E 06AE
23E0 : F0FF F285 0003 F287 68CE F344 0005 F345 F739 B45D 0002 B45F 245A FCAF 0002 FCAF
2400 : 0D1B 45F9 0003 45FB D3A9 E7A5 0002 E7A7 0103 2692 0002 2692 A182 93F7 000A 93FF
2420 : 2475 0CD7 0003 0CD7 0B26 078A 000F 078F E037 8D09 0001 8D09 A7C6 0CB7 000C 0CBF
2440 : 0A50 0DCC 0002 0DCE A1D5 C77C 000A C77E A186 1EA2 0000 1EA2 B958 2DCA 0008 2DCA
2460 : 616F A341 0003 A343 A1FF D5B2 000A D5BA 7E9E 73BF 0001 73BF 5436 9CBD 000D 9CBD
2480 : 6D36 750C 0003 750F E1B8 57FB 000A 57FB D4F5 DAC9 0001 DAC9 8BFD DCAA 000A DCAA
24A0 : 9D5B B350 0000 B350 FA9C ECA6 000B ECAF 6A00 072A 0002 072A E54B 2E39 000E 2E3F
24C0 : EEA3 4DDA 0003 4DDB 41ED 7514 0004 7514 43E3 D3B1 0000 D3B1 9986 BBDD 0007 BBDF
24E0 : B5B3 4907 0001 4907 69D3 612C 0007 612F 1B15 1CEB 0000 1CEB 2C5D B3F2 0007 B3F7
2500 : 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
2520 : 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
2540 : 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
2560 : 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
2580 : 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
25A0 : 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
25C0 : 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
25E0 : 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
2600 :
I have MRT Pro.
Before i changed HSA i have read out all HDD stuff, and made a LDR, but if i want sending loader i got this error message:
begin to load LDR ...
Path : ...............................E:\MRTPRO\Seagate U5 Bara\Barracuda 7200.10 Galaxy2D\ST3160815AS-3.CHH-9RXEEEV4\SgLdr.ldr
start writing Cert Code ...
Please switch to the T-stage
Write CertCode : .....................Failure
start writing Cert Table ...
Write Cert Table : ...................Failure
start writing ATA 0 ...
Write ATA 0 : ........................Failure
start writing ATA 1 ...
Write ATA 1 : ........................Failure
start writing HDDIDSTUFF ...
Write HDDIDSTUFF : ...................Failure
Load LDR completed
Please help....
PostPosted: June 24th, 2016, 15:00
Remove cert component loading as part of your loader. Not sure if that is possible in MRT.
PostPosted: June 24th, 2016, 16:11
Can you upload your loader and SA resources? I have worked out the structure of the Seagate F3 loader. Perhaps I could make sense of yours.
PostPosted: June 24th, 2016, 18:15
Buzz HM SFI
(P)SATA Reset
; <----at this point press the key Backspace "<--" or ^Z
after reaching the level of T start to load objects (ovl ,stuff) one at a time
You receive an terminal error 33h?
PostPosted: June 26th, 2016, 3:31
Hello labtech!
With MRT not possible remowe components from loader. :-(
PostPosted: June 26th, 2016, 3:32
Thank you fzakbar!
Here it is!
ST3160815AS-3.CHH-9RXEEEV4.ZIP [1.08 MiB]
Downloaded 531 times
PostPosted: June 26th, 2016, 4:27
...I have worked out the structure of the Seagate F3 loader...
His drive is not F3.
Users browsing this forum: Pi0tR and 67 guests
