 Post subject: HDD problem on ACER 5738zg
PostPosted: June 24th, 2016, 11:55
Hello Ladies and Gentlemen!
Recently, I've encountered a windows error message that my HDD might have problems and I should copy my data to avoid missing those. My HDD is separated on two drives (c: for windows; d: for media) and every time I'm trying to put data on D: my computer sudddenly restars with blue screen. I tried to make a scan with MHDD and in the biggining of the process found some "X" sectors (about 7), but in the end I found out that the scan process cant even be finished because my computer shuts down during the process. I found on one website that scan+remap function can help solving this problem, but this operation(scan+remap) also can't be finnished as computer also shuts down during the procces! If somebody can help me solving this problem I will very much appriciated!!!
 Post subject: Re: HDD problem on ACER 5738zg
PostPosted: June 27th, 2016, 15:04
Драйв умирает. Windows правильно сказала, дату копируй пока не поздно. Если скопировал, то ставь другой винт, а этот продай на запчасти комунибудь.
PostPosted: July 3rd, 2016, 9:04
drHDD, спасибо за совет. Никакие сканирования, ремапы и ирейзы не спасут, да?
PostPosted: July 4th, 2016, 12:52
Ну смотря для чего. Если использовать в ноуте, то я бы не стал в любом случае. Неизвестно когда он навернется. Если как потаскуна, то можно наверное.
Users browsing this forum: No registered users and 102 guests
