 Post subject: samsung HD 252HJ problem
PostPosted: July 7th, 2016, 3:04
My samsung HDD HJ got problem it spins but gives click sound when i change it's position it is also not detected by the pc in fact the PC main borad gives beep when I connect to it but when I use it via USB to IDE device it shows the coneection & then disconnect does mostly when I change it's position i have checked the coild 4R7 the voltages are 2.52 & 1.2 respectively I have alos checeked the TVS diodes looks fine there is nothing burnt the MCU becomes overheated sometime but then becomes normal any suggestion thanks in advance
 Post subject: Re: samsung HD 252HJ problem
PostPosted: July 7th, 2016, 17:35
Clicking sound 99.9% means a head issue.
Try clear head contacts on PCB. If it not helps and you data is important for you, then send message to waqas_ali766
https://forum.hddguru.com/memberlist.php?mode=viewprofile&u=26444
PostPosted: July 10th, 2016, 3:25
Thanks for the tip I did that bit still there is no improvement
PostPosted: July 10th, 2016, 3:40
if you need data from the drive, we can help you.
Data Recovery Pakistan
PostPosted: July 11th, 2016, 7:03
the mcu 88i8826c-bam2 over heats I have installed the heat sink it works very minimal
any suggestion why it gets over heat
PostPosted: July 12th, 2016, 1:18
Thanks for every one not helping ..this made me to figure out & study by myself ..The chip 88i8826c was malfunctioning I replaced it & got the problem fix
Thanks again for not helping & Let me learn
PostPosted: July 12th, 2016, 8:48
I was going to say "You're not welcome," just kidding. Congrats!
Users browsing this forum: Google [Bot] and 71 guests
