 Post subject: ST500DM002 Terminal Error
PostPosted: July 9th, 2016, 4:34
Let me know the error msg (Only PCB)
Phy supports only Yeti 3.*. Drive will hang.
Phy supports only Yeti 3.*. Drive will hang.ΓΏ
Note: I Don't Know whether the PCB is native or not
 Post subject: Re: ST500DM002 Terminal Error
PostPosted: July 9th, 2016, 14:43
Check the SN in ROM
PostPosted: July 12th, 2016, 0:38
The problem is identified
Previous guy changed pcb with patient rom. the Boot rom version is not compatiable with that pcb.
i transferred that rom to another pcb then problem solved
PostPosted: July 19th, 2016, 0:24
Hi , you can check if the SN in CAP is the same as the SN in tag. If yes, the PCB is original.
MRT Data Recovery Tools, which can bear comparison with PC3000 Tools
MRT can support Seagate F3 Head/Zone shielding
http://en.mrtlab.com/contact-us
PostPosted: July 20th, 2016, 1:52
Rom is original but the problem is with PCB
Users browsing this forum: No registered users and 163 guests
