 Post subject: Seagate SSHD ST1000LM014 Issue
PostPosted: August 11th, 2016, 21:11
Does this look like head failure? My experience of these drives is that the board comes live pretty much immediately with the hard drive to follow. This drive had a power surge so its a new board with patient ROM. The drive stays BSY. Could this just be because of head failure, or might the ROM be corrupt? Terminal drops out when LED: 000000 appears but I don't this is the usual LED issue.
RECOV Servo Op=0055 Resp=0005
RECOV Servo Op=0155 Resp=0005
SIM Error 5000 LBA 0000000000097E38 FD 3811611F
RW Error C3160080
(DOS) Table Read FAIL
LED:000000BC FAddr:00004040
Request spin / disc table recovery
Rst 0x40M
Servo Processor Is Reset.
(P) SATA Reset
SIM Error 5000 LBA 0000000000066E3B FD 3811611F
RW Error C3160080
Rst 0x40M
Spin Up
Spin issued
FAIL  Servo Op=0100 Resp=0003
0100 0000 0000 0001 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 03C0 0050 00B6 1DC0 0008 0F6E 0F7A 0F82 109F 0F86 0F82 0F79 0F65 0F4C 0F35 0F30 9EDD FCAC 9234 9740 088C 2D16 9DFF EACC 24EA B1D6 E887 5F63 9468 722F 6F64 1D2B FFFF
RECOV Servo Op=0100 Resp=0005
TCC:0021
RECOV Servo Op=0155 Resp=0005 PASS
RW Error 43110081
Rst 0x40M
Spin Up
Spin issued
 Post subject: Re: Seagate SSHD ST1000LM014 Issue
PostPosted: August 11th, 2016, 21:53
It's SSHD, So, flash on the donor PCB contains donor's flash info. Not sure that is an issue or not.
PostPosted: August 12th, 2016, 12:01
Was the donor PCB the same FW as the patient?
PostPosted: August 12th, 2016, 14:43
May be I could help, but I need to have physical access to drive.
Users browsing this forum: No registered users and 190 guests
