 Post subject: Buy WD GreenPower Entr Vs WD RE3 Entr VS Hitachi ?
PostPosted: July 14th, 2016, 19:16
Hi There
Need a reply soon !!
I have these choices from them to choose:
1- Western Digital WD1002FBYS (1TB SATA 3 Gb/s, 32MB cache RPM 7200, RE3 Enterprise Hard Drives)
2- Western Digital WD2003FYPS (2TB SATA 3 Gb/s, 64MB cache RPM IntelliPower, RE4 Green Power series Enterprise Hard Drives)
3-Hitachi HUA721010KLA330 (1TB SATA 3 Gb/s, 32MB cache RPM 7200 ,Ultrastar A7K1000, ENTERPRISE HARD DISK DRIVES)
4-Hitachi HUA722020ALA331 (2TB SATA 3 Gb/s, 32MB cache RPM 7200, Ultrastar A7K2000 BDE, ENTERPRISE HARD DISK DRIVES)
Choosen selection will be used for OS and Applications and some frequently used data storage for long hours a day. With some possible power failures.
In deciding I am neglecting capacity (1TB/2TB does not matter). Power consumption etc can also be neglected but I need to choose among them with fastest response and reliable.
Enterprise grade series I think much better than normal desktop series but option-2 is Green Power series. Much debated for its unstated low RPM (probably 5200 or 5900 or variable 5200-7200 ). So I feel more inclined on option-1 but its cache is 32MB just half of option-2. I searched on net disk cache is not more important than spindle speed. Faster spindle 7200 is in option-1. For Hitachi HDD's I have not experienced any so far.
My system is
Quadcore 2.66 GHz, Asus P5QL-PRO 8GB DDR-2, Gigabyte R7 360 2GB GDDR, Coolmax 600Watt
So please suggest the one with faster and reliable for my OS, Applications and most frequently use data. SSD is on list but currently I have to choose from above options only.
WD 1TB wd1002fbys specs.pdf [148.6 KiB]
Downloaded 397 times
Ultrastar_A7K1000_final_DS.pdf [271.5 KiB]
Downloaded 404 times
WD 2TB RE4-GP (WD2002FYPS) 2879-701312.pdf [329.96 KiB]
Downloaded 385 times
USA7K2000_DS7K2000_OEMSpec_r1.4.pdf [1.84 MiB]
Downloaded 660 times
 Post subject: Re: Buy WD GreenPower Entr Vs WD RE3 Entr VS Hitachi ?
PostPosted: July 15th, 2016, 15:51
I would definitely stay away from WD Green Series.
I would get higher cache drive.
Personally I would go for the WD2003FYPS.
