 Post subject: ST1000DL002 BUSY need restore data
PostPosted: July 24th, 2016, 12:44
Hi, everybody.
I repair TV sets, more precisely restoration of screens (matrixes).
Last week Ihave big problem. - all of the file a storage can died. There all work, data, clients, and backups.
The body of Seagate Barrakuda ST1000DL002 - 9TT153-301 - CC32 .
The disk is devided on three sections. C:\ - bootable, with system. Since morning I included a computer, I see - Windows I am loaded, turned away, after a while I look... ... Disk Boot failure.
When loading writes the name of the connected disk, but in a setapa it doesn't detektitsya, 0 MB detektitsya more precisely.
I checked a cables, - 0. By other PC a disk small, but having thought to a cut I decided to try to include the second and to copy important on other disk. By other car - the disk met, and data were available.
I copied what there was enough place for. I left, I approached after a while, all and on this PC the disk ceased Windows seems.
I rebooted - disk no more activity .
The sound of the spinning up is perfectly all right.
What was made.
Kind of failure: Without a previous hint of problem, the drive suddenly ceases to talk to the controller (i. e., it cannot be detected by the BIOS when the machine is starting up). The sound of the spinning up is perfectly all right.
I managed to connect to the disk's serial interface, and this is the diagnostic output it gives upon power-up. Hopefully someone qualified can step up and tell me what it actually is that the ST1000DL002s are choking on.
I just have removed a PCB and cleaned it - oxides considerable under pads. After cleaning - the same condition.
And still - its disk doesn't allow is loaded from other disks therefore MHDD, Victoria it is impossible to load. Or they don't see it.
In the terminal of sreezny I changed nothing, only tests.
Here what gives after spinup:
Rst 0x20M
MC Internal LPC Process
(P) SATA Reset
User Data Base  00990F98
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes:  4011A624  40118734
Seg Write Preamble VBM start: 000010A7 end: 000010CE
  Footer - start: 000010D0 end: 000010F7
Seg Read Preamble VBM - start: 000010F9 end: 00001120
  Footer - start: 00001122 end: 00001149
Reconstruction: MCMT Reconstruction Start
  Max number of MC segments 22E0
Nonvolatile MCMT sequence number 0231D99E
[RSRS] 206F
Reconstruction: Completed 1:
[MCMTWS]
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00000041
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000002A
MCMainPOR: MCStateFlags = 00000041
MCMainPOR: Feature Enabled...
Rst 0x20M
LED:000000BD FAddr:00008A20
On command V1 gets very big log. T give start and end only...
V1
User Slip Defect List
                         log log   log     phys   phys
        LBA    span   cumm   cyl  hd  sctr zn   cyl   sctr     SFI      PBA
           0      0      0     0  0     0   0      0     0        A            0
       BDBB1      1      1   2BD  1    49   0    2BD    4A   11DDF2        BDBB2
       BDD0A      1      2   2BC  1    23   0    2BC    24   11DF1A        BDD0C
       BDFE3      1      3   2BB  1   17D   0    2BB   17E   11E046        BDFE6
       BE13C      1      4   2BA  1   157   0    2BA   158   11E16E        BE140
       BE295      1      5   2B9  1   131   0    2B9   132   11E296        BE29A
       BE3EE      1      6   2B8  1   10B   0    2B8   10C   11E3C2        BE3F4
      125221      5      B   486  1    9F   0    486    A4    5B074       12522C
      125376      5     10   485  1    79   0    485    7E    5B1A0       125386
      1254CB      5     15   484  1    53   0    484    58    5B2C8       1254E0
      22CBE1      1     16   834  0   116   0    834   117    92A84       22CBF7
      22CD36      2     18   835  0    F0   0    835    F2    9338E       22CD4E
      22CE8B      1     19   836  0    CB   0    836    CC    93021       22CEA4
      22CFE0      1     1A   837  0    A5   0    837    A6    92CB4       22CFFA
      22D135      1     1B   838  0    7F   0    838    80    92903       22D150
      22D28A      2     1D   839  0    59   0    839    5B    93210       22D2A7
      22D3DF      1     1E   83A  0    34   0    83A    35    92EA3       22D3FD
      22D534      1     1F   83B  0     E   0    83B     F    92AF2       22D553
      22D805      2     21   83C  0   164   0    83C   166    9316B       22D826
      22D95A      1     22   83D  0   13F   0    83D   140    92DFE       22D97C
      22DAAF      1     23   83E  0   119   0    83E   11A    92A4D       22DAD2
      22DC04      2     25   83F  0    F3   0    83F    F5    93357       22DC29
      22DD59      1     26   840  0    CE   0    840    CF    92FEA       22DD7F
      22DEAE      1     27   841  0    A8   0    841    A9    92C7D       22DED5
      22E003      1     28   842  0    82   0    842    83    928CF       22E02B
      22E158      2     2A   843  0    5C   0    843    5E    931D9       22E182
      22E2AD      1     2B   844  0    37   0    844    38    92E6C       22E2D8
      22E402      1     2C   845  0    11   0    845    12    92ABB       22E42E
      22E6D3      2     2E   846  0   167   0    846   169    93134       22E701
      22E828      1     2F   847  0   142   0    847   143    92DC7       22E857
      22E97D      1     30   848  0   11C   0    848   11D    92A16       22E9AD
     E5D4DAF      1   7031 426FC  1    99   F  4293C    9A    20913      E5DBDE0
     E5D4E5D      1   7032 426FB  1    86   F  4293B    87    20C7B      E5DBE8F
     E5D4F0A      2   7034 426FA  1    72   F  4293A    74    20FE3      E5DBF3E
     E9A3A13      1   7035 443F1  1    28   F  44631    29    35EA0      E9AAA48
     E9A3AB7      1   7036 443F0  1    16   F  44630    17    36126      E9AAAED
     E9A3B5A      2   7038 443EF  1     3   F  4462F     5    36352      E9AAB92
     E9A3CB5      1   7039 443EE  1    A9   F  4462E    AA    3623C      E9AACEE
     E9A3D58      2   703B 443ED  1    96   10  4462D    98    364AD      E9AAD93
     E9D4D44      1   703C 42E23  2    2F   10  43063    30     B9D3      E9DBD80
     E9D4DE3      1   703D 42E24  2    1D   10  43064    1E     B5D0      E9DBE20
     E9D4E82      2   703F 42E25  2     B   10  43065     D     BEC6      E9DBEC1
     E9D4FD3      1   7040 42E26  2    AC   10  43066    AD     B660      E9DC013
     E9D5072      1   7041 42E27  2    9A   10  43067    9B     B2A0      E9DC0B3
     E9D5111      2   7043 42E28  2    88   10  43068    8A     BB96      E9DC154
Head 0: entries    482        slips      C19
Head 1: entries   17A4        slips     5C7E
Head 2: entries    326        slips      7AC
  Total Entries   1F4C  Total Slips     7043
On V10 too big
V10
P List
  phy   phy    log length
head   cyl    cyl in symb  SFI  flags
   1    2B8    2B8  363   11DA3C 80 scr fill
   1    2B9    2B9  363   11DA3C 80 scr fill
   1    2BA    2BA  363   11DA3C 88 scr fill
   1    2BB    2BB  363   11DA3C 88 scr fill
   1    2BC    2BC  363   11DA3C 80 scr fill
   1    2BD    2BD  363   11DA3C 80 scr fill
   1    484    484 3966    574B2  8
   1    485    485 173E    574B2  8
   1    485    485  C75    58BF0  C G to P
   1    485    485 15B3    59865  8
   1    486    486 3966    574B2  8
   0    834    834  42A    9242C 80 scr fill
   0    835    835  42A    9242D 80 scr fill
   0    836    836  42A    9242D 80 scr fill
   0    837    837  42A    9242D 80 scr fill
   0    838    838  42A    9242E 80 scr fill
   0    839    839  42A    9242E 80 scr fill
   0    83A    83A  42A    9242F 80 scr fill
   0    83B    83B  42A    9242F 80 scr fill
   0    83C    83C  42A    9242F 80 scr fill
   0    83D    83D  42A    92430 80 scr fill
   0    83E    83E  42A    92430 80 scr fill
   0    83F    83F  42A    92431 80 scr fill
   0    840    840  42A    92431 80 scr fill
   0    841    841  42A    92431 80 scr fill
   0    842    842  42A    92432 80 scr fill
   0    843    843  42A    92432 80 scr fill
   0    844    844  42A    92433 80 scr fill
   0    845    845  42A    92433 80 scr fill
   0    846    846  42A    92433 80 scr fill
   0    847    847  42A    92434 80 scr fill
  phy   phy    log length
   1  42946  42706  3E9    2002F 80 scr fill
   1  42947  42707  3E9    2002F 80 scr fill
   2  43063  42E23  3F1     ADDC 80 scr fill
   2  43064  42E24  3F1     ADDE 80 scr fill
   2  43065  42E25  3F1     ADE0 88 scr fill
   2  43066  42E26  3F1     ADE2 88 scr fill
   2  43067  42E27  3F1     ADE4 80 scr fill
   2  43068  42E28  3F1     ADE6 80 scr fill
   2  434F9  432B9 1B72    1E4DE 10
   2  434FA  432BA 1B72    1E4DE 10
   2  434FB  432BB 1B72    1E4DE 10
   2  434FC  432BC 1B72    1E4DE 10
   2  434FD  432BD 1B72    1E4DE 10
   2  434FE  432BE 1B72    1E4DE 10
   2  434FF  432BF 1B72    1E4DE 10
   1  4462D  443ED  345    35644 80 scr fill
   1  4462E  443EE  345    35644 80 scr fill
   1  4462F  443EF  345    35644 88 scr fill
   1  44630  443F0  345    35644 80 scr fill
   1  44631  443F1  345    35644 80 scr fill
   0  455D7  45397 24E8    204B0  8
   0  455D8  45398  BDF    204B0  8
   0  455D8  45398  CF3    2108F  C G to P
   0  455D8  45398  C16    21D82  8
   0  455D9  45399 24E8    204B0  8
Head 0 Entries: 526
Head 1 Entries: 1859
Head 2 Entries: 32D
  Total Entries: 20AC
F3 T>
On Ctrl+X gets...
ATA  15 Cmds
Ts(ms)     dT(ms)   Op Cnt  LBA
         0 99999999 00 0000 000000000000
         0        0 00 0000 000000000000
RW  32 Cmds
Ts(ms)     dT(ms)   xT(ms)  Type Option Mode  St EC       Info
      8651 99999999        1 04  005041 000000 1 00000080 SRV_MEM Type 6 Addr 000000E7 Cnt 0001
      8652        1        0 04  005041 000000 1 00000080 SRV_MEM Type 8 Addr 0000E2F4 Cnt 0003
      8652        0        0 04  005041 000000 1 00000080 SRV_MEM Type 6 Addr 401E003B Cnt 0001
      8652        0        0 04  005041 000000 1 00000080 SRV_MEM Type 8 Addr 0000E348 Cnt 0003
      8652        0        0 04  005041 000000 1 00000080 SRV_MEM Type 8 Addr 0000E34E Cnt 0003
      8652        0        0 04  005041 000000 1 00000080 SRV_MEM Type 8 Addr 0000E354 Cnt 0003
      8652        0        0 04  005041 000000 1 00000080 SRV_MEM Type 6 Addr 401E0025 Cnt 0001
      8652        0        0 04  005041 000000 1 00000080 SRV_MEM Type 8 Addr 0000E240 Cnt 0003
      8652        0        0 04  005041 000000 1 00000080 SRV_MEM Type 6 Addr 401E0007 Cnt 0001
      8652        0        0 04  005041 000000 1 00000080 SRV_MEM Type 8 Addr 0000E258 Cnt 0003
      8652        0        1 04  005041 000000 1 00000080 SRV_MEM Type 6 Addr 401E00A6 Cnt 0001
      8653        1        0 04  005041 000000 1 00000080 SRV_MEM Type 8 Addr 0000E27C Cnt 0003
      8653        0        0 04  005041 000000 1 00000080 SRV_MEM Type 6 Addr 401E00A7 Cnt 0001
      8653        0        0 04  005041 000000 1 00000080 SRV_MEM Type 8 Addr 0000E294 Cnt 0003
      8663       10        5 12  005041 000000 1 00000080 TEMP 31 degC
      8669        6        7 02  005041 000000 1 00000080 XFR WR SYS LBA B 00000002FD5D L 00000001 BO 000000 BES 003E03F.003E07E.003E03F
      8676        7       10 02  002241 000000 1 00000080 XFR RD SYS LBA B 00000002FD86 L 00000001 BO 000000 BES 0047B00.0047D7F.0047B00
      8697       21       10 02  002241 000000 1 00000080 XFR RD SYS LBA B 00000002FDAC L 00000001 BO 000000 BES 0047B00.0047B3F.0047B00
      8707       10       10 02  002241 000000 1 00000080 XFR RD SYS LBA B 00000002FDAC L 00000001 BO 000000 BES 0047B00.0047B3F.0047B00
      8727       20       11 02  002241 000000 1 00000080 XFR RD SYS LBA B 00000003019F L 00000002 BO 000000 BES 0047B80.0047BFF.0047B80
      8738       11       10 02  005041 000000 1 00000080 XFR WR SYS LBA B 00000003019F L 00000002 BO 000000 BES 0047B80.0047BFF.0047B80
      8758       20       10 02  002241 000000 1 00000080 XFR RD SYS LBA B 00000002FDAC L 00000001 BO 000000 BES 0047B02.0047B41.0047B02
      8768       10       10 02  005041 000000 1 00000080 XFR WR SYS LBA B 00000002FDAC L 00000001 BO 000000 BES 0047B02.0047B41.0047B02
      8788       20       10 02  002241 000000 1 00000080 XFR RD SYS LBA B 00000002FDAC L 00000001 BO 000000 BES 0047B01.0047B40.0047B01
      8798       10       10 02  005041 000000 1 00000080 XFR WR SYS LBA B 00000002FDAC L 00000001 BO 000000 BES 0047B01.0047B40.0047B01
      8818       20       12 02  002241 000000 1 00000080 XFR RD SYS LBA B 00000002913D L 00000008 BO 000000 BES 0047B00.0047D7F.0047B00
      8830       12        7 02  005041 000000 1 00000080 XFR WR SYS LBA B 000000064821 L 00000002 BO 000000 BES 004AA40.004AABF.004AA40
      8838        8        2 02  005041 000000 1 00000080 XFR WR SYS LBA B 00000002913D L 00000008 BO 000000 BES 0047B00.0047CFF.0047B00
      8840        2       10 02  005041 000000 1 00000080 XFR WR SYS LBA B 00000006455C L 00000008 BO 000000 BES 0047B00.0047CFF.0047B00
      8860       20        8 02  002241 000000 1 00000080 XFR RD SYS LBA B 00000002FD41 L 00000004 BO 000000 BES 0047B00.0047BFF.0047B00
      8868        8       10 02  002241 000000 1 00000080 XFR RD SYS LBA B 00000002FD41 L 00000004 BO 000000 BES 0047C00.0047CFF.0047C00
      8878       10       10 02  005041 000000 1 00000080 XFR WR SYS LBA B 00000002FD41 L 00000004 BO 000000 BES 0047C00.0047CFF.0047C00
 Post subject: Re: ST1000DL002 BUSY need restore data
PostPosted: July 27th, 2016, 15:50
For MHDD oto work, the BIOS has to be in Legacy/IDE mode.
As far as the drive, likely it is building up bad sectors.
Can you test heads in terminal, please?
PostPosted: July 28th, 2016, 4:39
which command?
PostPosted: July 28th, 2016, 5:55
F3 T>/7X
PostPosted: July 29th, 2016, 16:06
hii there
i update very good solution in 1 step for this prb
i can't share in public
communicate with me on skype or whatsapp
Skype ID : hpwlab
whatsapp : +201283689946
http://www.hpwlab.com
Users browsing this forum: No registered users and 125 guests
