 Post subject: SAMSUNG HD103SJ shows a smart problem
PostPosted: July 30th, 2016, 9:45
I've experienced a few problems with rebooting to my win 7 system. Regular booting failed, safe mode worked. After running some work, looks like standard win 7 run creates a problem, which chkdsk /f /r corrects. Whenever I ran chkdsk, standard boot becomes available again, sometimes for a single boot session.
I've installed HDDScan 3.3 and ran it from a safe mode session (It failed to start on a standard win7 session), and the S.M.A.R.T. test shows the following single problem:
Current Pending Errors Count
Value=100
Worst=100
Raw(hex)=0000000000-0003
Threshold=000
Is this problem curable?
Is it critical?
Should I consider replacing my HD?
SAMSUNG HD103SJ-S246JDWSB26709-SMART.pdf [248 KiB]
Downloaded 441 times
 Post subject: Re: SAMSUNG HD103SJ shows a smart problem
PostPosted: July 30th, 2016, 17:14
Try a full surface scan. HDDScan can do it, but MHDD (DOS) would be better. This will identify any "slow" sectors.
PostPosted: July 31st, 2016, 5:53
Thanks for your prompt reply.
I entered my syste, using the MHDD boot disk and got the list of drives shown in the attach pic.
Which one should I choose?
PostPosted: July 31st, 2016, 21:15
Your drive is not showing. Have enabled BIOS setting to IDE/Legacy mode?
PostPosted: August 1st, 2016, 3:53
I searched for this option in my BIOS settings and failed to find it
Please see the following two screenshots:
PostPosted: August 13th, 2016, 0:28
It has been a while since I used the old Award BIOS, but from memory I recall that the setting is in under Integrated Peripherals, normally there should be options there to select between IDE (Legacy) / AHCI / RAID modes.
PostPosted: August 13th, 2016, 5:23
The drive is set to IDE. "Legacy" isn't added to this term and the only other option is RAId.
Users browsing this forum: Google [Bot] and 235 guests
