 Post subject: Cleared G-list, recovered data. Still only zeros. Normal?
PostPosted: May 7th, 2017, 7:48
Hi. In relation to a project I am working on I have been doing the following on a WD2500AVJS:
Wiped the disk (dban, three pass)
Verified in a hex viewer that there is all zeros over the disk
Cleared the G-list using PC-3000
Scanned and recovered aprox. 100 leftover files (from previously marked bad sectors), using PC-3000
So far as expected, but.. when looking at the disk again in the hex-viewer, it´s still all zeros. Is this normal? Or should I see the previously marked bad sectors now sinc the G-list has been cleared?
All input appreciated! Thanks
-Espen
 Post subject: Re: Cleared G-list, recovered data. Still only zeros. Normal
PostPosted: May 7th, 2017, 16:09
An ATA Enhanced Secure Erase will also erase the sectors in the G-list.
PostPosted: May 8th, 2017, 6:32
Thanks. But the question is more if it is natural that a hex viewer only sees zeros after the G-list had been cleared. I would expect the hex viewer to be able to see data from the previously marked bad sectors since the G-list now has been cleared and the data is present at the user area.
Or am I wrong?
PostPosted: May 8th, 2017, 17:53
Examine the drive again, and see if the g-list has entries again. Maybe the drive´s housekeeping has marked those blocks as bad again
PostPosted: December 25th, 2017, 17:45
Banned User
but it doesn't erase the g-list itself
apparently nothing can edit the g-list (except scam apps for millionaires like pc3000)
even powerful allegedly "low level" apps like mhdd are powerless against the g-list
Users browsing this forum: No registered users and 157 guests
