 Post subject: Is recovery possible in this case?
PostPosted: August 4th, 2016, 17:50
Hey everyone! I'm not the sharpest knife in the drawer when it comes to this stuff, so I figured I'd create an account here to ask some people who know what they are talking about!
So older versions of firefox used to store internet history in a file called history.dat. When you clear the private data from the browser, the data from the file is also cleared. Since the file isn't technically being deleted, just "wiped", does that mean recovery of that history is impossible? (I mean, the file creation date stays the same after clearing private data, so I assuming it is the same file) I just tried using Recuva to see if it worked with a test, but I just got a few PNG files that said "Files data could not be found on disk". Anything at all you can tell me would be greatly appreciated.
Also, this is assuming the recovery attemept is immediately or soon after the file is cleared
Thanks!!
 Post subject: Re: Is recovery possible in this case?
PostPosted: August 4th, 2016, 22:49
In the current version of Firefox, browsing history is kept in places.sqlite in the user profile, according to this.
The places.sqlite file contains all your Firefox bookmarks and lists of all the files you've downloaded and websites you’ve visited.
I don't know if you can use "Restore previous version" on that but on my Win7 system, there are no previous versions. Previous versions is not available in XP and may not be enabled on other versions of Windows (See System protection settings for System Restore).
PostPosted: August 5th, 2016, 1:13
Try a sector-level test.
Create a history.dat file in the normal way and then use a disc editor (eg DMDE freeware) to determine the sectors occupied by the file (or you could use one of several other methods for locating these sectors). Then clear the private data in your browser and re-examine those same sectors.
PostPosted: August 5th, 2016, 14:52
The version of firefox I want to figure this out for is version 2, and I guess places.sqlite didn't come around until version 3. Plus this is on XP as well, so I guess according to what you posted, there is no previous versions.
PostPosted: August 5th, 2016, 14:54
Hm, would a guy with not much experience with forensics or that kind of stuff be able to do this, do you think? I'm going to read up on this though, that seems like a good idea.
PostPosted: August 6th, 2016, 5:04
It's easy in DMDE.
    Launch DMDE
    Select your physical disk
    Check the Show Partitions box
    Double-click the desired volume
    Expand the Root
    Navigate to your desired file
    Double-click the desired file group in the left pane
    Double-click the desired file in the top right pane
    The bottom right pane should now identify the LBA of the first sector of the file
PostPosted: August 6th, 2016, 9:44
It's easy in DMDE.
    Launch DMDE
    Expand the Root
Awesome, so I found the desired file. I'm not sure what I should be looking for, though.
The LBA says 13331200.. anything else I should note? I'm afraid I know very little of what this all means. (sorry)
PostPosted: August 6th, 2016, 16:01
The LBA (Logical Block Address) is the sector where the file is located. The contents of this sector are the beginning of the file. Save the file (use Windows explorer or DMDE) and use a hex editor (eg HxD) to view it. The contents should be the same in both cases.
Now exit DMDE and delete your private data in Firefox. Then ...
    Launch DMDE
    Uncheck the Show Partitions box
    Editor -> Goto offset
      Sector = 13331200
      Sector offset = 0
      From Start/End
      Dec
You should now see the contents of sector 13331200. Examine the next few sectors (using the Page Down key). Do you still see your original data?
https://mh-nexus.de/en/hxd/
PostPosted: August 6th, 2016, 17:06
    Launch DMDE
      Sector = 13331200
      Sector offset = 0
      From Start/End
      Dec
I tried twice, and in both cases all the data was still to be found. So I guess that means its not overwritten.
The first file was written to sector 13331200 and the second to 18811611. Seems pretty "far apart" to me. Why do people say things like "Don't use firefox if you want to find old firefox history" or something of that nature, it seems to me each file has no impact on another whatsoever in this case.
Also, with DMDE , am I able to search a keyword through an entire drive and see if there are undeleted data that way?
PostPosted: August 6th, 2016, 23:23
Tools -> Search for String in Object
PostPosted: August 7th, 2016, 9:05
Is it okay to ignore all cyclic redundancy checks?
PostPosted: August 7th, 2016, 20:43
I would guess then that it's creating a new, empty, history file before it deletes the old one. Now it's just a matter of determining an identifiable characteristic of the file type to be able to search for it.
PostPosted: August 7th, 2016, 22:15
Well, the mozilla file description says its written in a complex format called "Mork". Not sure if that is useful.
So if I find this identifiable characteristic, will I be able to search the entire disk, deleted and undeleted, for all firefox files that have not been overwritten?
Users browsing this forum: Google [Bot] and 91 guests
