 Post subject: Changing the serial number of a HDD
PostPosted: September 6th, 2015, 12:34
Is it possible to change the serial number (not volume serial number) of a HDD? And if it is possible how can this be done?
 Post subject: Re: Changing the serial number of a HDD
PostPosted: September 7th, 2015, 4:32
Which software is used for WD ?
PostPosted: September 7th, 2015, 5:00
HDDHackr can do it, if you know how.
PostPosted: September 7th, 2015, 10:12
I got a failed -Toshiba MK6465GSX FW: GJ003M which was installed in a Vehicle diagnostics device. After imaging the drive with few bad sectors I installed the imaged drive in the device but the app is asking for the Serial number and Model of the failed drive. So now I got a new Toshiba MQ01ABD100, tried to change using EDIT HDD ID and now it shows the new drive model as "UNDER CONSTRUCTION". It doesn't auto detect so after selecting the family it shows the the model and serial of the old. Shouldn't it ID automatically as the old drive after its changed? Is there any thread that explains how to go about it?
PostPosted: August 19th, 2016, 18:08
i have a WDC WD1600AAJB-00J3A0 and i need to change the serial number. Any guide, help please?
PostPosted: August 19th, 2016, 19:45
HDDSuperTool can do it, if you know how.
http://www.sdcomputingservice.com/hddsupertool
PostPosted: August 20th, 2016, 1:07
use wdr in wd hard disk ... r u in india plz contct me
PostPosted: August 20th, 2016, 9:36
Any guide?
PostPosted: August 20th, 2016, 9:37
No i am in Greece. Can you help me or guide me?
PostPosted: August 20th, 2016, 16:27
Use HDDSuperTool's scripts to read module 02, then modify it and write it back.
PostPosted: August 21st, 2016, 1:50
We'll do it for you, free of charge.
Send us the drive/bring it to any of our labs in Athens or Thessaloniki and the desired s/n and we'll do it for you within the day.
Users browsing this forum: Google [Bot] and 83 guests
