 Post subject: Seagate ST1000LM010 not detected
PostPosted: November 26th, 2013, 23:57
File comment: photo attached
It sudenlly happens, I noticed that the bios and explorer in win 7 did not detect these external HDD, I only used for photos and picasa as a viewer/manager.
I notice that device and printers detect the "Y" adapter as seagate goflex, one led on the adapter turns ON and I can feel the HDD spining but no strange noises.
Tried to connect it using a sata and power cable to Main board and still not showing on explorer.
Please if someone have any input, let me know.
 Post subject: Re: Seagate ST1000LM010 not detected
PostPosted: November 27th, 2013, 3:34
Try taking the drive out of the chassis and connecting via SATA.
See if it s connected by the PC BIOS.
Also,you can download MHDD from this site and test with that.
PostPosted: November 27th, 2013, 5:16
If connecting directly to the motherboard still makes the drive undetectable, you may have some firmware issue probably.
If your data is valuable, I would also get a proper diagnosis and quote from a pro.
PostPosted: November 27th, 2013, 5:22
As you already tried to conect it directly and still no detection, I will also give a vote for firmware problem.
http://www.rescue-it.se
PostPosted: November 27th, 2013, 10:12
Often one weak/bad head can make it seem like a firmware issue, too.
Careful how much power cycling goes on and on..
PostPosted: November 27th, 2013, 17:06
That's not exactly what I asked, or what he said :-)
I asked him to connect via SATA and check if it would appear in BIOS, not in explorer!
It quite possibly is a fw issue, but at least it might help narrow our options down.
PostPosted: December 26th, 2015, 10:21
i got same issue but i solved.
"Sim error 1009"
i rewrite sys17a and sys133 file with Y-modem..
it resurrected.
PostPosted: December 27th, 2015, 5:35
r-read
w- write
i read some files from proper same model hard drive. with " r17A" "r133" "r28" "r35"
and after "w" it. w17A, .......
i use Hyperterminal's Y-modem..
PostPosted: December 27th, 2015, 10:36
excellent Mikail13.
But to a novice hyperterminal Y modem........ and the process of r and w please explain in detail.......
also, can the same treatment applied to other model of HDD having SIM error.
we have high expectation from U...Mikail13.
PostPosted: December 28th, 2015, 9:07
Anyone, please explain the tricks.
PostPosted: December 29th, 2015, 12:06
excellent............................... splidit.
Kudos to you.
PostPosted: January 22nd, 2016, 23:39
Great work as always. Thank you Spildit.
PostPosted: August 23rd, 2016, 22:50
hi, everyone, my Seagate ST1000LM010 had not detected. Can anyone send me(csfaifai@gmail.com) the files ("r17A" "r133" "r28" "r35") for restoring?
thank you so much for your help in advance.
PostPosted: August 24th, 2016, 5:18
Are you sure you want to DIY ?
I hope you know and understand the consequences.
PostPosted: August 24th, 2016, 12:20
If you will write those files - you will loose your data.
Users browsing this forum: No registered users and 150 guests
