 Post subject: Hitachi USB Drive SATA Connections
PostPosted: August 30th, 2016, 19:14
I have a pretty new Toshiba USB Drive MQ03UBB300 that I need to put a SATA connection onto as there are no compatible SATA boards (unless you know different). I have included a picture of what I think described the layout of the Toshiba USB:-
W = Write
R = Read
P = Power
G = Ground
From left to right as you look at the usb connection, I presume its A+ A- B- B+
Can anyone with electrical knowledge (aka @fzabkar) confirm this.
 Post subject: Re: Hitachi USB Drive SATA Connections
PostPosted: August 31st, 2016, 1:56
HI
No....The G is +5V, P are USB2.0 connections, W and R are USB3.0 connections. GND (Ground) are the 2 connections at the left side of P.
www.datasave.ro
PostPosted: August 31st, 2016, 2:37
http://pinoutsguide.com/PortableDevices/micro_usb_3_connector_pinout.shtml
PostPosted: August 31st, 2016, 4:11
Banned User
W = Write
R = Read
P = Power
G = Ground
Can you need http://www.cnx-software.com/2014/03/25/ ... explained/
I am from cuudulieuocung.org and I am currently banned from this forum for creating multiple accounts to promote my crappy website.
PostPosted: August 31st, 2016, 10:15
http://toshiba.semicon-storage.com/ap-e ... bbxxx.html
There seems to be a SATA based model, but it has not quite hit the markets yet. Hard to find.
https://eshop.macsales.com/item/Toshiba/MQ03ABB300/
PostPosted: August 31st, 2016, 13:08
Thanks for all the above (and the PM). Learned a lot about these USB connections.
Users browsing this forum: Bing [Bot], DIAGS4711 and 249 guests
