 Post subject: F3 commands Useless at ST3500320AS
PostPosted: August 26th, 2016, 11:19
Everthing seems normal. Hdd spins. there is no weird sound.
Looks like firmware bug but F3 commands are useless.
Bios doesn't identify the HDD seagate st3500320as
Please help..
F3 T>m0,2,2,,,,,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewr
ite Retries = 00C8
User Partition Format 5% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 000
00080, Elapsed Time 0 mins 05 secs
User Partition Format Successful - Elapsed Time 0 mins 05 secs
F3 T>m0,6,3,,,,,22
ite Retries = 00C8
User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 000
 Post subject: Re: F3 commands Useless at ST3500320AS
PostPosted: August 29th, 2016, 13:00
PCB motor Chip(smooth) is always overheat. i think that problem is motor seized. i cooled the PCB with fan.
Bios rarely sees hard drive but often don't.
i want to update the firmware to SD1A.. classic ways seem impossible..
SD15 is troublemaker.
can i do it via Seagate Tools or any other?
PostPosted: August 29th, 2016, 13:39
send spin down/up commands, if motor is really seized you will get error messages.
PostPosted: August 29th, 2016, 14:12
i think motor spins but also forced. Smooth chip fries my hand. it hurts.
When i hit the U it takes 10 second to message..
no other error message...
PostPosted: August 29th, 2016, 15:26
Banned User
I also think like you need cooling PCB
I am from cuudulieuocung.org and I am currently banned from this forum for creating multiple accounts to promote my crappy website.
PostPosted: August 30th, 2016, 5:51
i update firmware via seagate's boot firmware cd with success
Bios and device manager sees hdd anymore.
later i want to format user partition .
Z spin down o.K.
U spin up failed..
Motor stops. seized forever.. typicall noise hearing.
no spin at all..
PostPosted: September 5th, 2016, 7:10
i try to re-spin the motor on the water Closet :)....
There is any dust after the have a bath later the 2 hours.
problem of Head stuck the on platter solved.
Drive spins and seems normally on Device Manager.. MBR needs to be fix.
Drive seems 7 mb..
and also seems "RAP subfile error 201c" every attempt.
Please help
PostPosted: September 10th, 2016, 3:12
Drive LBA 0
seems only 7 gb..
PostPosted: September 10th, 2016, 7:30
What Are You Talking About .Somethings Like Bath Etc Does Not even Make Sense
PostPosted: September 13th, 2016, 6:10
the bath is only dust-free area i have.
do you know "RAP subfile error 201c"
PostPosted: October 5th, 2016, 8:05
Data is succefully recovered.
*3 times head stuck.
* Device Manager doesn't see the hdd. you must wait at least 4 minute.
* PCB burned. Needs PCB cooling with fan.
* Firmware update is usefull.
* Severally disk seems 8 gb at DM. m0,6,3,,,,,22 fix this problem.
* at last sector copy and reverse copy with DMDE. There ar many bad sector but i recover important files and folder.
PostPosted: October 5th, 2016, 8:15
It is good that you got the data recovered. But, in the future, if a PCB is overheating, it is best to simply transfer the ROM to a healthy donor PCB and safely image the drive without risk of sudden power failure, head crashes and stiction.
PostPosted: October 5th, 2016, 8:34
You're right but second PCB was overheated too.
Maybe my PSU is broken..
viewtopic.php?f=1&t=34263
Users browsing this forum: Google [Bot] and 68 guests
