 Post subject: Some noob questions about reading overwritten data
PostPosted: August 27th, 2016, 15:04
I've been reading so much contradicting information online, I really have no idea whats true and what isn't anymore. (Also, I should clarify that viewing them would suffice, I don't necessarily have to recover them) The hdd in question is a HGST Travelstar 5K250 HTS542516K9SA00 - hard drive - 160 GB.
1. One of the things I read stated that sometimes its possible to read overwritten data as long as its "only a couple layers deep". Does that mean if it is overwritten once by Windows, I can still use software to view it? Or would it involve striping away at the physical hdd? Keep in mind I'm talking about notepad type files with plain text.
2. If a text file is "partially overwritten", would I be able to view the text that wasn't overwritten in a program like DMDE or something similar?
3. What software would be capable of reading (in plain english like a hex editor) the overwritten data and the partially overwritten data?
4. I've read some articles talking about how hdd's never write to the exact same place more than once. What does this mean regarding overwritten data?
 Post subject: Re: Some noob questions about reading overwritten data
PostPosted: August 27th, 2016, 16:54
Didn't the following thread answer most of your questions?
viewtopic.php?f=1&t=33909
PostPosted: August 27th, 2016, 17:39
Not the ones I listed above.
PostPosted: August 27th, 2016, 19:53
Not true. Once sectors are overwritten, they're gone forever.
Theoritically speaking, you could be able to see data of partially not-overwritten files using some hex viewer (or DMDE).
See answer 2. There are plenty of freeware hex editors.
This is ridiculous. If that was correct, then HDDs would work sort-of like CD-Rs: write data -> reach maximum capacity -> turn in read-only mode.
HDDs can read and write for as long as they're healthy.
PostPosted: August 28th, 2016, 17:22
Thanks!
PostPosted: August 28th, 2016, 18:24
Let's assume binfile is a portion of a binary file and textfile is a portion of a text file.
We can create a hybrid textbin or bintext file as follows:
    copy /b binfile + textfile bintext
    copy /b textfile + binfile textbin
Now view these files in a hex editor (eg HxD freeware) or in a word processor (eg Windows Wordpad or DOS Edit).
PostPosted: August 28th, 2016, 23:26
I think what was meant by this question is that the data, during subsequent re-writes, gets shifted around. Maybe not the precise same spot, but a few nm off-target so to speak.
But, yes of course, sectors are reused unlike CD-R.
Users browsing this forum: Google [Bot] and 92 guests
