 Post subject: Ide SSD HELP !
PostPosted: August 29th, 2016, 19:55
Hi
I have a old arcade mobo which had a 40 go ide hdd .
I want to clone this to a 64gb IDE SSD ,( for faster loading time reasons ) but I don't know if the mobo will take a SSD ???????
Can anyone advise if this will work [img][img]https://s17.postimg.org/oinu4wskr/image.jpg[/img]
 Post subject: Re: Ide SSD HELP !
PostPosted: August 29th, 2016, 21:46
What's the model no. ?
PostPosted: August 30th, 2016, 3:58
You would be much better with a IDE -> Compact flash adapter. This will eliminate any compatibility problems that a SSD might give you.
Example https://www.amazon.com/Syba-SD-CF-IDE-Connects-3-5-Inch-Interface/dp/B000YUMLPI
Web: https://www.day1data.de
PostPosted: August 30th, 2016, 4:38
Where do I get the model number ?
PostPosted: August 30th, 2016, 4:56
AISI, an IDE SSD should ideally have no compatibility problems.
OTOH, most CF cards will identify themselves as removable rather than fixed devices, in which case Windows will only see the first partition.
Users browsing this forum: No registered users and 84 guests
