 Post subject: ST2000DM001 Barracuda 7200.14 Congen ?
PostPosted: September 9th, 2016, 3:35
Can someone provide correct congen command for ST2000DM001 to disable reallocation
It has V4 Entries and V40 No Entries
The output of F at T-Level
F3 T>F
RWErrorRecovery Mode Page
RWErrorRecovery Group
Byte:009A: RWRecoveryFlags = C0
Byte:009A: Bit:0, DISABLE_CORRECTION = 0
Byte:009A: Bit:1, DISABLE_TRANSFER_ON_ERROR = 0
Byte:009A: Bit:2, POST_ERROR = 0
Byte:009A: Bit:3, ENABLE_EARLY_RECOVERY = 0
Byte:009A: Bit:4, READ_CONTINUOUS = 0
Byte:009A: Bit:5, TRANSFER_BLOCK = 0
Byte:009A: Bit:6, READ_SPARING_ENABLED = 1
Byte:009A: Bit:7, WRITE_SPARING_ENABLED = 1
Byte:009B: ReadRetries = 14
Byte:009C: CorrectionSpan = FF
Byte:009D: HeadOffset = 00
Byte:009E: DataStrobeOffset = 00
Byte:00A0: WriteRetries = 05
Byte:00A2: RecoveryLimitMSB = FF
Byte:00A3: RecoveryLimitLSB = FF
FormatParameters Mode Page
FormatParameters Group
Byte:00A6: TracksPerZoneMSB = 00
Byte:00A7: TracksPerZoneLSB = 01
Byte:00A8: AltSectorsPerZoneMSB = 00
Byte:00A9: AltSectorsPerZoneLSB = 00
Byte:00AA: AltTracksPerZoneMSB = 00
Byte:00AB: AltTracksPerZoneLSB = 00
Byte:00AC: AltTracksPerVolumeMSB = 00
Byte:00AD: AltTracksPerVolumeLSB = 02
Byte:00AE: SectorsPerTrackMSB = 00
Byte:00AF: SectorsPerTrackLSB = 03
Byte:00B0: BytesPerSectorMSB = 10
Byte:00B1: BytesPerSectorLSB = 00
Byte:00B2: InterleaveMSB = 00
Byte:00B3: InterleaveLSB = 01
Byte:00B4: TrackSkewMSB = 00
Byte:00B5: TrackSkewLSB = 00
Byte:00B6: CylinderSkewMSB = 00
Byte:00B7: CylinderSkewLSB = 00
Byte:00B8: FormatFlags = 40
DriveGeometry Mode Page
DriveGeometry Group
Byte:00BE: CylindersMSB = 00
Byte:00BF: CylindersMDB = 00
Byte:00C0: CylindersLSB = 04
Byte:00C1: Heads = 05
Byte:00C2: WritePrecompMSB = 00
Byte:00C3: WritePrecompMDB = 00
Byte:00C4: WritePrecompLSB = 00
Byte:00C5: ReducedCurrentMSB = 00
Byte:00C6: ReducedCurrentMDB = 00
Byte:00C7: ReducedCurrentLSB = 00
Byte:00C8: StepRateMSB = 00
Byte:00C9: StepRateLSB = 00
Byte:00CA: LandingZoneMSB = 00
Byte:00CB: LandingZoneMDB = 00
Byte:00CC: LandingZoneLSB = 00
Byte:00CD: PositionLocking = 00
Byte:00CE: RotationalOffset = 00
Byte:00D0: RotationRateMSB = 1C
Byte:00D1: RotationRateLSB = 20
VerifyError Mode Page
VerifyError Group
Byte:00D6: VerifyRecoveryFlags = 00
Byte:00D6: Bit:0, VE_DISABLE_CORRECTION = 0
Byte:00D6: Bit:1, VE_DISABLE_TRANSFER_ON_ERROR = 0
Byte:00D6: Bit:2, VE_POST_ERROR = 0
Byte:00D6: Bit:3, VE_ENABLE_EARLY_RECOVERY = 0
Byte:00D7: VerifyRetryCount = 14
Byte:00D8: VerifyCorrectionSpan = FF
Byte:00DE: VerifyTimeLimitMSB = FF
Byte:00DF: VerifyTimeLimitLSB = FF
CacheControl Mode Page
CacheControl Group
Byte:00E2: CacheFlags = 14
Byte:00E2: Bit:0, READ_CACHING_DISABLED_ON_POWER_UP = 0
Byte:00E2: Bit:1, MULTIPLICATION_FACTOR = 0
Byte:00E2: Bit:2, WRITE_CACHING_ENABLED_ON_POWER_UP = 1
Byte:00E2: Bit:4, DISCONTINUITY = 1
Byte:00E2: Bit:5, CACHING_ANALYSIS_PERMITTED = 0
Byte:00E2: Bit:6, ABORT_PREFETCH = 0
Byte:00E2: Bit:7, DISABLE_ADAPTIVE_READ_AHEAD = 0
Byte:00E3: RetentionPriority = 00
Byte:00E4: DisablePrefetchLengthMSB = FF
Byte:00E5: DisablePrefetchLengthLSB = FF
Byte:00E6: MinPrefetchMSB = 00
Byte:00E7: MinPrefetchLSB = 00
Byte:00E8: MaxPrefetchMSB = FF
Byte:00E9: MaxPrefetchLSB = FF
Byte:00EA: MaxPrefetchCeilingMSB = FF
Byte:00EB: MaxPrefetchCeilingLSB = FF
Byte:00EC: SpecialCacheFlags = 90
Byte:00EC: Bit:5, READ_LOOKAHEAD_DISABLED_ON_POWER_UP = 0
Byte:00EC: Bit:7, FORCE_SEQUENTIAL_WRITE = 1
Byte:00ED: CacheSegmentNum = 20
Byte:00EE: CacheSegSizeMSB = 00
Byte:00EF: CacheSegSizeLSB = 00
Byte:00F1: NonCacheSegSizeMSB = 00
Byte:00F2: NonCacheSegSizeMDB = 00
Byte:00F3: NonCacheSegSizeLSB = 00
ControlMode Mode Page
ControlMode Group
Byte:00F6: LogFlags = 02
Byte:00F7: QueueFlags = 00
Byte:00F8: AllegianceFlags = 00
Byte:00FA: RAERHoldOffMSB = 00
Byte:00FB: RAERHoldOffLSB = 00
Byte:00FC: BusyTimeoutMSB = 00
Byte:00FD: BusyTimeoutLSB = 00
Byte:00FE: ExtendedDstestTimeMSB = 00
Byte:00FF: ExtendedDstestTimeLSB = 00
PowerCondition Mode Page
PowerCondition Group
Byte:0103: PowerFlags = 02
Byte:0103: Bit:0, STANDBY = 0
Byte:0103: Bit:1, IDLE = 1
Byte:0104: IdleTimerMSB = 00
Byte:0105: IdleTimerNMSB = 00
Byte:0106: IdleTimerNLSB = 00
Byte:0107: IdleTimerLSB = 05
Byte:0108: StandbyTimerMSB = 00
Byte:0109: StandbyTimerNMSB = 00
Byte:010A: StandbyTimerNLSB = 8C
Byte:010B: StandbyTimerLSB = A0
BackgroundMediaScan Mode Page
BGMS Group
Byte:010F: BGMSBusIdleIn100ms = 05
Byte:0110: OtherScanFlags = 00
Byte:0110: Bit:0, IRAW_ENABLE = 0
Byte:0110: Bit:1, IRAW_DISABLE_REASSIGNMENTS = 0
Byte:0110: Bit:2, RESERVED_ZONE_BGKGND_SCAN_CONTROL = 0
Byte:0110: Bit:3, PARITY_VALIDITY_SCAN_CONTROL_BIT = 0
Byte:0111: IRAWWriteCachePercentage = 00
Byte:0112: IRAWDelayInMilliSecs = 00
Byte:0113: IRAWMaxQDepth = 00
Byte:0114: BGMSFlags = 00
Byte:0114: Bit:1, BGMS_DISABLE_DATA_REFRESH = 0
Byte:0114: Bit:2, BGMS_DISABLE_TEMPERATURE_LIMITATION = 0
Byte:0115: BGMSECCTLevel = 3A
Byte:011C: ReadAfterWriteControl = 31
Byte:011C: Bit:0, MP_RAW_ENABLE_BIT = 1
Byte:011C: Bit:1, MP_RAW_TRIP_1ST_N_WRITES = 0
Byte:011C: Bit:2, MP_RAW_FORCE_RAW_MODE = 0
Byte:011C: Bit:3, MP_RAW_UDS_DEBUG_MODE = 0
Byte:011C: Bit:4, MP_RAW_DISABLE_AR_ON_GOOD_READ = 1
Byte:011C: Bit:5, MP_RAW_DISABLE_SOFT_AR = 1
Byte:011C: Bit:6, MP_RAW_DISABLE_SERIAL_DEBUG_MSG = 0
Byte:011D: NWritesAfterSWDFail = 08
Byte:011E: NWritesAfterRAWFail = 08
Byte:011F: NWritesAfterIRAWFail = 08
Byte:0120: N1stWrites = 00
Byte:0121: RAWOnColdThreshold = 05
Byte:0122: RAWOnHotThreshold = 44
Byte:0123: RAWATAMode = 02
Byte:0124: RAWVerifyNSectors = 00 00 01 00
Byte:0128: RAWVerifyNSectorsATAMode3 = 00 00
Byte:012A: NWritesAfterSWDSumFail = 08
Byte:012C: SWDControl = 01
Byte:012C: Bit:0, MP_SWD_ENABLE_BIT = 1
Byte:012C: Bit:1, MP_SWD_DONT_REPORT_BIT = 0
Byte:012C: Bit:2, MP_SWD_DEBUG_MODE_BIT = 0
Byte:012D: SWDDvgasEventsBeforeFail = 08
Byte:012E: SWDRvgasEventsBeforeFail = 08
Byte:012F: SWDFvgasEventsBeforeFail = 08
Byte:0130: SWDSumOfEventsBeforeFail = 08
Byte:0134: DOSOughtToScanThreshold = 10
Byte:0135: DOSNeedToScanThreshold = 20
Byte:0136: DOSNeedToGraceMilliseconds = 14 00
Byte:0138: DOSNeedToRegraceMilliseconds = 2C 01
Byte:013A: DOSNeedToMinimumScanMilliseconds = E8 03
Byte:013C: RAWOnForNPowerCycles = 00 00
Byte:013E: RAWOnForNHours = 00 00
Byte:0140: RAWOnForNSpinups = 00 00
Byte:0144: ScanThresholdMultiplier = 80
Byte:0145: STENeedToScanThresholdMultiplier = 04
Byte:0146: DOSMet0Threshold = 08
Byte:0147: DOSMet1Threshold = 01
Byte:014C: DOSSTEScanMaxCyl = 0F
Byte:014D: DOSMaxRetryCount = 01
Byte:014E: DOSWFSThreshold = 05
Byte:014F: DOSECCTLevel = 0A
UnifiedDebugGeneral Mode Page
UDSGeneral Group
Byte:0152: Revision = 00
Byte:0153: GlobalTraceTriggerFlags = 50
Byte:0153: Bit:3, UDS_GEN_SVIN_BIT = 0
Byte:0153: Bit:4, UDS_GEN_SVEN_BIT = 1
Byte:0153: Bit:5, UDS_GEN_GTGE_BIT = 0
Byte:0153: Bit:6, UDS_GEN_TREN_BIT = 1
Byte:0153: Bit:7, UDS_GEN_TGTD_BIT = 0
Byte:0154: MethodParameterFlags = 00
Byte:0154: Bit:7, UDS_CLR = 0
Byte:0158: DetailedExternalTriggerFlags = 00
Byte:015A: ErrorTypeMSB = 00
Byte:015B: ErrorTypeLSB = 00
Byte:015C: ErrorLBABigEndian = 00 00 00 00 00 00 00 00
Byte:0168: AutomaticTraceSaveFlags = 80
Byte:0168: Bit:5, UDS_GEN_INTR_BIT = 0
Byte:0168: Bit:6, UDS_GEN_DTFS_BIT = 0
Byte:0168: Bit:7, UDS_GEN_TSEN_BIT = 1
Byte:016A: MSBAutomaticTraceSaveIntervalInMinutes = 00
Byte:016B: LSBAutomaticTraceSaveIntervalInMinutes = 78
Byte:016C: MSBMinimumIdleTimeBeforeAutoTraceSaveInMilliseconds = 00
Byte:016D: LSBMinimumIdleTimeBeforeAutoTraceSaveInMilliseconds = C8
Byte:016E: TimestampFormatIdentifierMSB = 00
Byte:016F: TimestampFormatIdentifierLSB = 00
Byte:0170: CustomerSystemTimeInCustUniqueFormat = 00 00 00 00 00 00 00 00
DriveNativeInfo Mode Page
DriveNativeInfo Group
Byte:0192: PartNumber = 30 32 37 4A 4A 30 44 54 58
'027JJ0DTX'
Byte:019B: PartNumberWhitespacePad = 20 20 20 20 20 20 20 00
Byte:01A3: PartNumberPad = 00
Byte:01A4: ProcessControlVersion = 00 00
Byte:01A6: CongenConfigurationState = 01
Byte:01A7: WrittenCount = 00
Byte:01A8: InternalSeagateModelNumber =
53 54 32 30 30 30 44 4D 30 30 31 20 20 20 20 20
20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
'ST2000DM001 '
Byte:01D0: BuildFlags = 01 00
Byte:01D0: Bit:0, QNR_SUPPORTED = 1
Byte:01D2: RealTimeUpdatedFlags = 08 00
Byte:01D2: Bit:3, CONGEN_READ_FROM_MEDIA = 1
Byte:01D4: CongenLastWriteCaller = 04
ANSIBackgroundMediaScan Mode Page
ANSIBackgroundMediaScan Group
Byte:01DC: BGMSFlags = 01
Byte:01DC: Bit:0, BGMS_ENABLE = 1
Byte:01DD: Prescan = 00
Byte:01DD: Bit:0, BGMS_PRESCAN = 0
Byte:01DE: BGMSIntervalTimeHoursMSB = 00
Byte:01DF: BGMSIntervalTimeHoursLSB = 18
Byte:01E0: PrescanTimeoutHoursMSB = 00
Byte:01E1: PrescanTimeoutHoursLSB = 18
UDSFastTraceClassesLevels Mode Page
UDSFastTrace Group
Byte:01EC: Revision = 00
Byte:01ED: FastTraceLevels_0 = 11
Byte:01EE: FastTraceLevels_1 = 11
Byte:01EF: FastTraceLevels_2 = 11
Byte:01F0: FastTraceLevels_3 = 11
Byte:01F1: FastTraceLevels_4 = 11
Byte:01F2: FastTraceLevels_5 = 11
Byte:01F3: FastTraceLevels_6 = 11
Byte:01F4: FastTraceLevels_7 = 12
Byte:01F5: FastTraceLevels_8 = 11
Byte:01F6: FastTraceLevels_9 = 11
Byte:01F7: FastTraceLevels_10 = 11
Byte:01F8: FastTraceLevels_11 = 11
Byte:01F9: FastTraceLevels_12 = 11
Byte:01FA: FastTraceLevels_13 = 11
Byte:01FB: FastTraceLevels_14 = 11
Byte:01FC: FastTraceLevels_15 = 11
Byte:01FD: FastTraceLevels_16 = 11
Byte:01FE: FastTraceLevels_17 = 11
Byte:01FF: FastTraceLevels_18 = 11
Byte:0200: FastTraceLevels_19 = 11
Byte:0201: FastTraceLevels_20 = 11
Byte:0202: FastTraceLevels_21 = 11
Byte:0203: FastTraceLevels_22 = 11
Byte:0204: FastTraceLevels_23 = 11
Byte:0205: FastTraceLevels_24 = 11
Byte:0206: FastTraceLevels_25 = 11
Byte:0207: FastTraceLevels_26 = 11
Byte:0208: FastTraceLevels_27 = 11
Byte:0209: FastTraceLevels_28 = 11
Byte:020A: FastTraceLevels_29 = 11
Byte:020B: FastTraceLevels_30 = 11
Byte:020C: FastTraceLevels_31 = 11
UDSTraceBufferConfig Mode Page
UDSBuffer Group
Byte:0214: Revision = 00
Byte:0218: MinimumAllocationInTraceBlocksMSB_0 = 00
Byte:0219: MinimumAllocationInTraceBlocksLSB_0 = 05
Byte:021A: TraceBufferControlFlags1_0 = 80
Byte:021C: MinimumAllocationInTraceBlocksMSB_1 = 00
Byte:021D: MinimumAllocationInTraceBlocksLSB_1 = 00
Byte:021E: TraceBufferControlFlags1_1 = 00
Byte:0220: MinimumAllocationInTraceBlocksMSB_2 = 00
Byte:0221: MinimumAllocationInTraceBlocksLSB_2 = 00
Byte:0222: TraceBufferControlFlags1_2 = 00
Byte:0224: MinimumAllocationInTraceBlocksMSB_3 = 00
Byte:0225: MinimumAllocationInTraceBlocksLSB_3 = 00
Byte:0226: TraceBufferControlFlags1_3 = 00
Byte:0228: MinimumAllocationInTraceBlocksMSB_4 = 00
Byte:0229: MinimumAllocationInTraceBlocksLSB_4 = 00
Byte:022A: TraceBufferControlFlags1_4 = 00
Byte:022C: MinimumAllocationInTraceBlocksMSB_5 = 00
Byte:022D: MinimumAllocationInTraceBlocksLSB_5 = 00
Byte:022E: TraceBufferControlFlags1_5 = 00
Byte:0230: MinimumAllocationInTraceBlocksMSB_6 = 00
Byte:0231: MinimumAllocationInTraceBlocksLSB_6 = 00
Byte:0232: TraceBufferControlFlags1_6 = 00
Byte:0234: MinimumAllocationInTraceBlocksMSB_7 = 00
Byte:0235: MinimumAllocationInTraceBlocksLSB_7 = 00
Byte:0236: TraceBufferControlFlags1_7 = 00
Byte:0238: MinimumAllocationInTraceBlocksMSB_8 = 00
Byte:0239: MinimumAllocationInTraceBlocksLSB_8 = 00
Byte:023A: TraceBufferControlFlags1_8 = 00
Byte:023C: MinimumAllocationInTraceBlocksMSB_9 = 00
Byte:023D: MinimumAllocationInTraceBlocksLSB_9 = 00
Byte:023E: TraceBufferControlFlags1_9 = 00
Byte:0240: MinimumAllocationInTraceBlocksMSB_10 = 00
Byte:0241: MinimumAllocationInTraceBlocksLSB_10 = 00
Byte:0242: TraceBufferControlFlags1_10 = 00
Byte:0244: MinimumAllocationInTraceBlocksMSB_11 = 00
Byte:0245: MinimumAllocationInTraceBlocksLSB_11 = 00
Byte:0246: TraceBufferControlFlags1_11 = 00
Byte:0248: MinimumAllocationInTraceBlocksMSB_12 = 00
Byte:0249: MinimumAllocationInTraceBlocksLSB_12 = 00
Byte:024A: TraceBufferControlFlags1_12 = 00
Byte:024C: MinimumAllocationInTraceBlocksMSB_13 = 00
Byte:024D: MinimumAllocationInTraceBlocksLSB_13 = 00
Byte:024E: TraceBufferControlFlags1_13 = 00
Byte:0250: MinimumAllocationInTraceBlocksMSB_14 = 00
Byte:0251: MinimumAllocationInTraceBlocksLSB_14 = 00
Byte:0252: TraceBufferControlFlags1_14 = 00
Byte:0254: MinimumAllocationInTraceBlocksMSB_15 = 00
Byte:0255: MinimumAllocationInTraceBlocksLSB_15 = 00
Byte:0256: TraceBufferControlFlags1_15 = 00
Byte:0258: MinimumAllocationInTraceBlocksMSB_16 = 00
Byte:0259: MinimumAllocationInTraceBlocksLSB_16 = 00
Byte:025A: TraceBufferControlFlags1_16 = 00
Byte:025C: MinimumAllocationInTraceBlocksMSB_17 = 00
Byte:025D: MinimumAllocationInTraceBlocksLSB_17 = 00
Byte:025E: TraceBufferControlFlags1_17 = 00
Byte:0260: MinimumAllocationInTraceBlocksMSB_18 = 00
Byte:0261: MinimumAllocationInTraceBlocksLSB_18 = 00
Byte:0262: TraceBufferControlFlags1_18 = 00
Byte:0264: MinimumAllocationInTraceBlocksMSB_19 = 00
Byte:0265: MinimumAllocationInTraceBlocksLSB_19 = 00
Byte:0266: TraceBufferControlFlags1_19 = 00
Byte:0268: MinimumAllocationInTraceBlocksMSB_20 = 00
Byte:0269: MinimumAllocationInTraceBlocksLSB_20 = 00
Byte:026A: TraceBufferControlFlags1_20 = 00
Byte:026C: MinimumAllocationInTraceBlocksMSB_21 = 00
Byte:026D: MinimumAllocationInTraceBlocksLSB_21 = 00
Byte:026E: TraceBufferControlFlags1_21 = 00
Byte:0270: MinimumAllocationInTraceBlocksMSB_22 = 00
Byte:0271: MinimumAllocationInTraceBlocksLSB_22 = 00
Byte:0272: TraceBufferControlFlags1_22 = 00
Byte:0274: MinimumAllocationInTraceBlocksMSB_23 = 00
Byte:0275: MinimumAllocationInTraceBlocksLSB_23 = 00
Byte:0276: TraceBufferControlFlags1_23 = 00
Byte:0278: MinimumAllocationInTraceBlocksMSB_24 = 00
Byte:0279: MinimumAllocationInTraceBlocksLSB_24 = 00
Byte:027A: TraceBufferControlFlags1_24 = 00
Byte:027C: MinimumAllocationInTraceBlocksMSB_25 = 00
Byte:027D: MinimumAllocationInTraceBlocksLSB_25 = 00
Byte:027E: TraceBufferControlFlags1_25 = 00
Byte:0280: MinimumAllocationInTraceBlocksMSB_26 = 00
Byte:0281: MinimumAllocationInTraceBlocksLSB_26 = 00
Byte:0282: TraceBufferControlFlags1_26 = 00
Byte:0284: MinimumAllocationInTraceBlocksMSB_27 = 00
Byte:0285: MinimumAllocationInTraceBlocksLSB_27 = 00
Byte:0286: TraceBufferControlFlags1_27 = 00
Byte:0288: MinimumAllocationInTraceBlocksMSB_28 = 00
Byte:0289: MinimumAllocationInTraceBlocksLSB_28 = 00
Byte:028A: TraceBufferControlFlags1_28 = 00
Byte:028C: MinimumAllocationInTraceBlocksMSB_29 = 00
Byte:028D: MinimumAllocationInTraceBlocksLSB_29 = 00
Byte:028E: TraceBufferControlFlags1_29 = 00
Byte:0290: MinimumAllocationInTraceBlocksMSB_30 = 00
Byte:0291: MinimumAllocationInTraceBlocksLSB_30 = 00
Byte:0292: TraceBufferControlFlags1_30 = 00
Byte:0294: MinimumAllocationInTraceBlocksMSB_31 = 00
Byte:0295: MinimumAllocationInTraceBlocksLSB_31 = 00
Byte:0296: TraceBufferControlFlags1_31 = 00
Byte:0298: MinimumAllocationInTraceBlocksMSB_32 = 00
Byte:0299: MinimumAllocationInTraceBlocksLSB_32 = 00
Byte:029A: TraceBufferControlFlags1_32 = 00
Byte:029C: MinimumAllocationInTraceBlocksMSB_33 = 00
Byte:029D: MinimumAllocationInTraceBlocksLSB_33 = 00
Byte:029E: TraceBufferControlFlags1_33 = 00
Byte:02A0: MinimumAllocationInTraceBlocksMSB_34 = 00
Byte:02A1: MinimumAllocationInTraceBlocksLSB_34 = 00
Byte:02A2: TraceBufferControlFlags1_34 = 00
Byte:02A4: MinimumAllocationInTraceBlocksMSB_35 = 00
Byte:02A5: MinimumAllocationInTraceBlocksLSB_35 = 00
Byte:02A6: TraceBufferControlFlags1_35 = 00
Byte:02A8: MinimumAllocationInTraceBlocksMSB_36 = 00
Byte:02A9: MinimumAllocationInTraceBlocksLSB_36 = 00
Byte:02AA: TraceBufferControlFlags1_36 = 00
Byte:02AC: MinimumAllocationInTraceBlocksMSB_37 = 00
Byte:02AD: MinimumAllocationInTraceBlocksLSB_37 = 00
Byte:02AE: TraceBufferControlFlags1_37 = 00
Byte:02B0: MinimumAllocationInTraceBlocksMSB_38 = 00
Byte:02B1: MinimumAllocationInTraceBlocksLSB_38 = 00
Byte:02B2: TraceBufferControlFlags1_38 = 00
Byte:02B4: MinimumAllocationInTraceBlocksMSB_39 = 00
Byte:02B5: MinimumAllocationInTraceBlocksLSB_39 = 00
Byte:02B6: TraceBufferControlFlags1_39 = 00
Byte:02B8: MinimumAllocationInTraceBlocksMSB_40 = 00
Byte:02B9: MinimumAllocationInTraceBlocksLSB_40 = 00
Byte:02BA: TraceBufferControlFlags1_40 = 00
Byte:02BC: MinimumAllocationInTraceBlocksMSB_41 = 00
Byte:02BD: MinimumAllocationInTraceBlocksLSB_41 = 00
Byte:02BE: TraceBufferControlFlags1_41 = 00
Byte:02C0: MinimumAllocationInTraceBlocksMSB_42 = 00
Byte:02C1: MinimumAllocationInTraceBlocksLSB_42 = 00
Byte:02C2: TraceBufferControlFlags1_42 = 00
Byte:02C4: MinimumAllocationInTraceBlocksMSB_43 = 00
Byte:02C5: MinimumAllocationInTraceBlocksLSB_43 = 00
Byte:02C6: TraceBufferControlFlags1_43 = 00
Byte:02C8: MinimumAllocationInTraceBlocksMSB_44 = 00
Byte:02C9: MinimumAllocationInTraceBlocksLSB_44 = 00
Byte:02CA: TraceBufferControlFlags1_44 = 00
Byte:02CC: MinimumAllocationInTraceBlocksMSB_45 = 00
Byte:02CD: MinimumAllocationInTraceBlocksLSB_45 = 00
Byte:02CE: TraceBufferControlFlags1_45 = 00
Byte:02D0: MinimumAllocationInTraceBlocksMSB_46 = 00
Byte:02D1: MinimumAllocationInTraceBlocksLSB_46 = 00
Byte:02D2: TraceBufferControlFlags1_46 = 00
Byte:02D4: MinimumAllocationInTraceBlocksMSB_47 = 00
Byte:02D5: MinimumAllocationInTraceBlocksLSB_47 = 00
Byte:02D6: TraceBufferControlFlags1_47 = 00
Byte:02D8: MinimumAllocationInTraceBlocksMSB_48 = 00
Byte:02D9: MinimumAllocationInTraceBlocksLSB_48 = 00
Byte:02DA: TraceBufferControlFlags1_48 = 00
Byte:02DC: MinimumAllocationInTraceBlocksMSB_49 = 00
Byte:02DD: MinimumAllocationInTraceBlocksLSB_49 = 00
Byte:02DE: TraceBufferControlFlags1_49 = 00
Byte:02E0: MinimumAllocationInTraceBlocksMSB_50 = 00
Byte:02E1: MinimumAllocationInTraceBlocksLSB_50 = 00
Byte:02E2: TraceBufferControlFlags1_50 = 00
Byte:02E4: MinimumAllocationInTraceBlocksMSB_51 = 00
Byte:02E5: MinimumAllocationInTraceBlocksLSB_51 = 00
Byte:02E6: TraceBufferControlFlags1_51 = 00
Byte:02E8: MinimumAllocationInTraceBlocksMSB_52 = 00
Byte:02E9: MinimumAllocationInTraceBlocksLSB_52 = 00
Byte:02EA: TraceBufferControlFlags1_52 = 00
Byte:02EC: MinimumAllocationInTraceBlocksMSB_53 = 00
Byte:02ED: MinimumAllocationInTraceBlocksLSB_53 = 00
Byte:02EE: TraceBufferControlFlags1_53 = 00
Byte:02F0: MinimumAllocationInTraceBlocksMSB_54 = 00
Byte:02F1: MinimumAllocationInTraceBlocksLSB_54 = 00
Byte:02F2: TraceBufferControlFlags1_54 = 00
Byte:02F4: MinimumAllocationInTraceBlocksMSB_55 = 00
Byte:02F5: MinimumAllocationInTraceBlocksLSB_55 = 00
Byte:02F6: TraceBufferControlFlags1_55 = 00
Byte:02F8: MinimumAllocationInTraceBlocksMSB_56 = 00
Byte:02F9: MinimumAllocationInTraceBlocksLSB_56 = 00
Byte:02FA: TraceBufferControlFlags1_56 = 00
Byte:02FC: MinimumAllocationInTraceBlocksMSB_57 = 00
Byte:02FD: MinimumAllocationInTraceBlocksLSB_57 = 00
Byte:02FE: TraceBufferControlFlags1_57 = 00
Byte:0300: MinimumAllocationInTraceBlocksMSB_58 = 00
Byte:0301: MinimumAllocationInTraceBlocksLSB_58 = 00
Byte:0302: TraceBufferControlFlags1_58 = 00
Byte:0304: MinimumAllocationInTraceBlocksMSB_59 = 00
Byte:0305: MinimumAllocationInTraceBlocksLSB_59 = 00
Byte:0306: TraceBufferControlFlags1_59 = 00
Byte:0308: MinimumAllocationInTraceBlocksMSB_60 = 00
Byte:0309: MinimumAllocationInTraceBlocksLSB_60 = 00
Byte:030A: TraceBufferControlFlags1_60 = 00
Byte:030C: MinimumAllocationInTraceBlocksMSB_61 = 00
Byte:030D: MinimumAllocationInTraceBlocksLSB_61 = 00
Byte:030E: TraceBufferControlFlags1_61 = 00
Byte:0310: MinimumAllocationInTraceBlocksMSB_62 = 00
Byte:0311: MinimumAllocationInTraceBlocksLSB_62 = 00
Byte:0312: TraceBufferControlFlags1_62 = 00
Byte:0314: MinimumAllocationInTraceBlocksMSB_63 = 00
Byte:0315: MinimumAllocationInTraceBlocksLSB_63 = 00
Byte:0316: TraceBufferControlFlags1_63 = 00
Byte:0318: MinimumAllocationInTraceBlocksMSB_64 = 00
Byte:0319: MinimumAllocationInTraceBlocksLSB_64 = 00
Byte:031A: TraceBufferControlFlags1_64 = 00
Byte:031C: MinimumAllocationInTraceBlocksMSB_65 = 00
Byte:031D: MinimumAllocationInTraceBlocksLSB_65 = 00
Byte:031E: TraceBufferControlFlags1_65 = 00
Byte:0320: MinimumAllocationInTraceBlocksMSB_66 = 00
Byte:0321: MinimumAllocationInTraceBlocksLSB_66 = 00
Byte:0322: TraceBufferControlFlags1_66 = 00
Byte:0324: MinimumAllocationInTraceBlocksMSB_67 = 00
Byte:0325: MinimumAllocationInTraceBlocksLSB_67 = 00
Byte:0326: TraceBufferControlFlags1_67 = 00
Byte:0328: MinimumAllocationInTraceBlocksMSB_68 = 00
Byte:0329: MinimumAllocationInTraceBlocksLSB_68 = 00
Byte:032A: TraceBufferControlFlags1_68 = 00
Byte:032C: MinimumAllocationInTraceBlocksMSB_69 = 00
Byte:032D: MinimumAllocationInTraceBlocksLSB_69 = 00
Byte:032E: TraceBufferControlFlags1_69 = 00
Byte:0330: MinimumAllocationInTraceBlocksMSB_70 = 00
Byte:0331: MinimumAllocationInTraceBlocksLSB_70 = 00
Byte:0332: TraceBufferControlFlags1_70 = 00
Byte:0334: MinimumAllocationInTraceBlocksMSB_71 = 00
Byte:0335: MinimumAllocationInTraceBlocksLSB_71 = 00
Byte:0336: TraceBufferControlFlags1_71 = 00
Byte:0338: MinimumAllocationInTraceBlocksMSB_72 = 00
Byte:0339: MinimumAllocationInTraceBlocksLSB_72 = 00
Byte:033A: TraceBufferControlFlags1_72 = 00
Byte:033C: MinimumAllocationInTraceBlocksMSB_73 = 00
Byte:033D: MinimumAllocationInTraceBlocksLSB_73 = 00
Byte:033E: TraceBufferControlFlags1_73 = 00
Byte:0340: MinimumAllocationInTraceBlocksMSB_74 = 00
Byte:0341: MinimumAllocationInTraceBlocksLSB_74 = 00
Byte:0342: TraceBufferControlFlags1_74 = 00
Byte:0344: MinimumAllocationInTraceBlocksMSB_75 = 00
Byte:0345: MinimumAllocationInTraceBlocksLSB_75 = 00
Byte:0346: TraceBufferControlFlags1_75 = 00
Byte:0348: MinimumAllocationInTraceBlocksMSB_76 = 00
Byte:0349: MinimumAllocationInTraceBlocksLSB_76 = 00
Byte:034A: TraceBufferControlFlags1_76 = 00
Congen Mode Page
Congen Group
Byte:0350: NumDefaultATCyls = FF 3F
Byte:0352: NumDefaultATHeads = 10 00
Byte:0354: NumDefaultATSectors = 3F 00
Byte:0356: NumECCBytesForLongCmds = 00 00
Byte:0358: MaximumMultipleSize = 10
Byte:0359: LogicalSectorAlignment = 00
Byte:035A: PIOModeTiming = 00 02
Byte:035C: DMAModeTiming = 00 02
Byte:035E: NumCurrentATCyls = FF 3F
Byte:0360: NumCurrentATHeads = 10 00
Byte:0362: NumCurrentATSectors = 3F 00
Byte:0364: CurrentMultipleSize = 10 00
Byte:0366: MultiwordDMAModesSupported = 0F
Byte:0366: Bit:0, MULTIWORD_DMA_MODE_0_SUPPORTED = 1
Byte:0366: Bit:1, MULTIWORD_DMA_MODE_1_SUPPORTED = 1
Byte:0366: Bit:2, MULTIWORD_DMA_MODE_2_SUPPORTED = 1
Byte:0366: Bit:3, ENABLE_RLIST = 1
Byte:0367: UltraDMAModesSupported = 7F
Byte:0367: Bit:0, ULTRA_DMA_MODE0_SUPPORTED = 1
Byte:0367: Bit:1, ULTRA_DMA_MODE1_AND_BELOW_SUPPORTED = 1
Byte:0367: Bit:2, ULTRA_DMA_MODE2_AND_BELOW_SUPPORTED = 1
Byte:0367: Bit:3, ULTRA_DMA_MODE3_AND_BELOW_SUPPORTED = 1
Byte:0367: Bit:4, ULTRA_DMA_MODE4_AND_BELOW_SUPPORTED = 1
Byte:0367: Bit:5, ULTRA_DMA_MODE5_AND_BELOW_SUPPORTED = 1
Byte:0367: Bit:6, ULTRA_DMA_MODE6_AND_BELOW_SUPPORTED = 1
Byte:0368: AdvancedPIOModesSupported = 03 00
Byte:0368: Bit:0, PIO_MODE_3_SUPPORTED = 1
Byte:0368: Bit:1, PIO_MODE_4_SUPPORTED = 1
Byte:036A: MinimumMultiwordDMACycleTime = 78 00
Byte:036C: RecommendedMultiwordDMACycleTime = 78 00
Byte:036E: MinimumPIOTimeWithoutFlowControl = 78 00
Byte:0370: MinimumPIOTimeWithFlowControl = 78 00
Byte:0372: QDepth = 00 00
Byte:0374: SATACapabilities = 0E 04
Byte:0375: Bit:0, SATA_NCQ_SUPPORTED = 0
Byte:0375: Bit:1, HOST_INITIATED_PHY_POWER_MANAGEMENT_SUPPORTED = 0
Byte:0375: Bit:2, SATA_PHY_EVENT_COUNTERS_SUPPORTED = 1
Byte:0375: Bit:3, UNLOAD_WHILE_NCQ_CMDS_OUTSTANDING_SUPPORTED = 0
Byte:0375: Bit:4, NCQ_PRIORITY_SUPPORTED = 0
Byte:0378: SATAFeaturesSupported = 4C 00
Byte:0378: Bit:2, DMA_AUTOACTIVATE_SUPPORTED = 1
Byte:0378: Bit:3, DEVICE_INITIATED_POWER_MANAGEMENT_SUPPORTED = 1
Byte:0378: Bit:6, PRESERVE_SETTINGS_ON_COMRESET_SUPPORTED = 1
Byte:0378: Bit:7, NCQ_AUTOSENSE_SUPPORTED = 0
Byte:037A: SATAFeaturesEnabled = 40 00
Byte:037A: Bit:2, DMA_AUTOACTIVATE_ENABLED = 0
Byte:037A: Bit:3, DEVICE_INITIATED_POWER_MANAGEMENT_ENABLED = 0
Byte:037A: Bit:6, PRESERVE_SETTINGS_ON_COMRESET_ENABLED = 1
Byte:037C: MajorVersionNumber = F0 01
Byte:037C: Bit:1, ATAPI_1_SUPPORTED = 0
Byte:037C: Bit:2, ATAPI_2_SUPPORTED = 0
Byte:037C: Bit:3, ATAPI_3_SUPPORTED = 0
Byte:037C: Bit:4, ATAPI_4_SUPPORTED = 1
Byte:037C: Bit:5, ATAPI_5_SUPPORTED = 1
Byte:037C: Bit:6, ATAPI_6_SUPPORTED = 1
Byte:037C: Bit:7, ATAPI_7_SUPPORTED = 1
Byte:037D: Bit:0, ATAPI_8_ACS_SUPPORTED = 1
Byte:037E: MinorVersionNumber = 29 00
Byte:0380: CommandSetSupported = 6B 34
Byte:0380: Bit:0, SMART_SUPPORTED = 1
Byte:0380: Bit:1, SECURITY_MODE_FEATURE_SET_SUPPORTED = 1
Byte:0380: Bit:5, WRITE_CACHE_SUPPORTED = 1
Byte:0380: Bit:6, READ_LOOKAHEAD_SUPPORTED = 1
Byte:0381: Bit:2, HOST_PROTECTED_AREA_SUPPORTED = 1
Byte:0381: Bit:4, WRITE_BUFFER_CMD_SUPPORTED = 1
Byte:0381: Bit:5, READ_BUFFER_CMD_SUPPORTED = 1
Byte:0381: Bit:6, NOP_CMD_SUPPORTED = 0
Byte:0382: CommandSetsSupported = 09 7D
Byte:0382: Bit:1, READ_WRITE_DMA_QUEUED_SUPPORTED = 0
Byte:0382: Bit:3, ADVANCED_POWER_MANAGEMENT_SUPPORTED = 1
Byte:0382: Bit:5, POWER_UP_IN_STANDBY_SUPPORTED = 0
Byte:0382: Bit:6, RESERVE1 = 0
Byte:0383: Bit:0, SET_MAX_SECURITY_EXTENSION_SUPPORTED = 1
Byte:0383: Bit:1, AUTO_ACOUSTIC_MANAGEMENT_SUPPORTED = 0
Byte:0383: Bit:2, FOURTYEIGHT_BIT_SUPPORTED = 1
Byte:0383: Bit:3, DCO_COMMAND_SETS_SUPPORTED = 1
Byte:0383: Bit:4, FLUSH_CACHE_SUPPORTED = 1
Byte:0383: Bit:5, FLUSH_CACHE_EXT_SUPPORTED = 1
Byte:0384: CommandSetSupportedExtension = 63 41
Byte:0384: Bit:0, SMART_ERROR_LOGGING_SUPPORTED = 1
Byte:0384: Bit:1, SMART_SELF_TEST_SUPPORTED = 1
Byte:0384: Bit:2, MEDIA_SERIALNUMBER_SUPPORTED = 0
Byte:0384: Bit:4, STREAMING_FEATURE_SET_SUPPORTED = 0
Byte:0384: Bit:6, FUA_WRITE_EXT_COMMANDS_SUPPORTED = 1
Byte:0384: Bit:7, FUA_WRITE_QUEUED_EXT_COMMANDS_SUPPORTED = 0
Byte:0385: Bit:0, SIXTYFOUR_BIT_WWN_SUPPORTED = 1
Byte:0385: Bit:3, AV_LITE_SUPPORTED = 0
Byte:0385: Bit:4, AV_LITE_RC_WC_SUPPORTED = 0
Byte:0385: Bit:5, IDLE_IMMEDIATE_UNLOAD_SUPPORTED = 0
Byte:0386: CommandSetEnabled = 69 34
Byte:0386: Bit:0, SMART_ENABLED = 1
Byte:0386: Bit:1, SECURITY_MODE_FEATURE_SET_ENABLED = 0
Byte:0386: Bit:5, WRITE_CACHE_ENABLED = 1
Byte:0386: Bit:6, READ_LOOKAHEAD_ENABLED = 1
Byte:0387: Bit:2, HOST_PROTECTED_AREA_ENABLED = 1
Byte:0388: CommandSetsEnabled = 09 BC
Byte:0388: Bit:3, ADVANCED_POWER_MANAGEMENT_ENABLED = 1
Byte:0388: Bit:5, RESERVE = 0
Byte:0388: Bit:6, SET_FEATURES_SPINUP_REQUIRED_ENABLED = 0
Byte:0388: Bit:7, ADDRESS_OFFSET_RESERVED_AREA_BOOT = 0
Byte:0389: Bit:0, SET_MAX_SECURITY_EXTENSION_ENABLED = 0
Byte:0389: Bit:1, AUTO_ACOUSTIC_MANAGEMENT_ENABLED = 0
Byte:038A: CommandSetEnabledExtension = 63 41
Byte:038A: Bit:2, MEDIA_SERIALNUMBER_IS_VALID = 0
Byte:038B: Bit:3, AV_LITE_ENABLED = 0
Byte:038B: Bit:4, AV_LITE_RC_WC_ENABLED = 0
Byte:038C: FreeFallSensitivity = 00 00
Byte:038E: CurrentAPMValue = 80 80
Byte:0390: MasterPasswordRevisionCode = FE FF
Byte:0392: AcousticLevel = 00 D0
Byte:0394: StreamMinRequestSize = 00 00
Byte:0396: StreamXferTimeDMA = 00 00
Byte:0398: StreamAccessLatency = 00 00
Byte:039A: StreamPerformanceGranularity = 00 00 00 00
Byte:039E: StreamXferTimePIO = 00 00
Byte:03A0: Max512ByteUnitsPerDownloadMicrocode = 00 00
Byte:03A2: PhysicalLogicalSectorSize = 03 60
Byte:03A2: Bit:0, TWO_X_LOG_SECTORS_PER_PHY_SECTOR_B0 = 1
Byte:03A2: Bit:1, TWO_X_LOG_SECTORS_PER_PHY_SECTOR_B1 = 1
Byte:03A2: Bit:2, TWO_X_LOG_SECTORS_PER_PHY_SECTOR_B2 = 0
Byte:03A2: Bit:3, TWO_X_LOG_SECTORS_PER_PHY_SECTOR_B3 = 0
Byte:03A3: Bit:4, DEV_LOG_SEC_LEN_GREATER_THAN_256W = 0
Byte:03A3: Bit:5, DEV_HAS_MUL_LOG_SECTORS_PER_PHY_SECTOR = 1
Byte:03A4: AVLiteWorstCaseTimer = 00 00
Byte:03A6: WordsPerLogicalSector = 00 01 00 00
Byte:03AA: ATACommandSetSupportedExt2 = 0E 40
Byte:03AA: Bit:1, WRITE_READ_VERIFY_SUPPORTED = 1
Byte:03AA: Bit:2, WRITE_UNCORRECTABLE_SUPPORTED = 1
Byte:03AA: Bit:3, READ_AND_WRITE_DMA_EXP_GPL_COMMANDS_SUPPORTED = 1
Byte:03AA: Bit:5, FREEFALL_SENSOR_SUPPORTED = 0
Byte:03AA: Bit:6, SENSE_DATA_REPORTING_SUPPORTED = 0
Byte:03AA: Bit:7, EXTENDED_POWER_CONDITIONS_SUPPORTED = 0
Byte:03AC: ATACommandSetEnabledExt2 = 08 40
Byte:03AC: Bit:1, WRITE_READ_VERIFY_ENABLED = 0
Byte:03AC: Bit:3, READ_AND_WRITE_DMA_EXP_GPL_COMMANDS_ENABLED = 1
Byte:03AC: Bit:5, FREEFALL_SENSOR_ENABLED_BY_DEFAULT = 0
Byte:03AC: Bit:6, SENSE_DATA_REPORTING_ENABLED = 0
Byte:03AC: Bit:7, EXTENDED_POWER_CONDITIONS_ENABLED = 0
Byte:03AE: ATATransportMajorRevisionNumber = 08 10
Byte:03B0: ATATransportMinorRevisionNumber = 00 00
Byte:03B2: ATSMARTDefaultFlags = 01 00
Byte:03B2: Bit:0, SMARTDEFAULTON = 1
Byte:03B4: ATSMARTConfig =
0F 00 06 00 03 00 00 00 32 00 14 00 33 00 0A 00
0F 00 1E 00 32 00 00 00 13 00 61 00 32 00 14 00
32 00 00 00 3A 00 00 00 22 00 2D 00 32 00 00 00
32 00 00 00 32 00 00 00 22 00 00 00 1A 00 00 00
12 00 00 00 10 00 00 00 3E 00 00 00 32 00 63 00
32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 32 00 00 00 0F 00 00 00 32 00 00 00
Byte:03B4: SMART1Status = 0F 00
Byte:03B6: SMART1Threshold = 06
Byte:03B8: SMART2Status = 03 00
Byte:03BA: SMART2Threshold = 00
Byte:03BC: SMART3Status = 32 00
Byte:03BE: SMART3Threshold = 14
Byte:03C0: SMART4Status = 33 00
Byte:03C2: SMART4Threshold = 0A
Byte:03C4: SMART5Status = 0F 00
Byte:03C6: SMART5Threshold = 1E
Byte:03C8: SMART6Status = 32 00
Byte:03CA: SMART6Threshold = 00
Byte:03CC: SMART7Status = 13 00
Byte:03CE: SMART7Threshold = 61
Byte:03D0: SMART8Status = 32 00
Byte:03D2: SMART8Threshold = 14
Byte:03D4: SMART9Status = 32 00
Byte:03D6: SMART9Threshold = 00
Byte:03D8: SMART10Status = 3A 00
Byte:03DA: SMART10Threshold = 00
Byte:03DC: SMART11Status = 22 00
Byte:03DE: SMART11Threshold = 2D
Byte:03E0: SMART12Status = 32 00
Byte:03E2: SMART12Threshold = 00
Byte:03E4: SMART13Status = 32 00
Byte:03E6: SMART13Threshold = 00
Byte:03E8: SMART14Status = 32 00
Byte:03EA: SMART14Threshold = 00
Byte:03EC: SMART15Status = 22 00
Byte:03EE: SMART15Threshold = 00
Byte:03F0: SMART16Status = 1A 00
Byte:03F2: SMART16Threshold = 00
Byte:03F4: SMART17Status = 12 00
Byte:03F6: SMART17Threshold = 00
Byte:03F8: SMART18Status = 10 00
Byte:03FA: SMART18Threshold = 00
Byte:03FC: SMART19Status = 3E 00
Byte:03FE: SMART19Threshold = 00
Byte:0400: SMART20Status = 32 00
Byte:0402: SMART20Threshold = 63
Byte:0404: SMART21Status = 32 00
Byte:0406: SMART21Threshold = 00
Byte:0408: SMART22Status = 00 00
Byte:040A: SMART22Threshold = 00
Byte:040C: SMART23Status = 00 00
Byte:040E: SMART23Threshold = 00
Byte:0410: SMART24Status = 00 00
Byte:0412: SMART24Threshold = 00
Byte:0414: SMART25Status = 00 00
Byte:0416: SMART25Threshold = 00
Byte:0418: SMART26Status = 32 00
Byte:041A: SMART26Threshold = 00
Byte:041C: SMART27Status = 0F 00
Byte:041E: SMART27Threshold = 00
Byte:0420: SMART28Status = 32 00
Byte:0422: SMART28Threshold = 00
Byte:0424: SMART29Status = 00 00
Byte:0426: SMART29Threshold = 00
Byte:0428: SMART30Status = 00 00
Byte:042A: SMART30Threshold = 00
Byte:042E: SCTCommandSetSupported = 81 30
Byte:042E: Bit:0, SCT_SUPPORTED_COMMAND_SET = 1
Byte:042E: Bit:1, SCT_SUPPORTED_LONG_SECTOR_ACCESS = 0
Byte:042E: Bit:2, SCT_SUPPORTED_LBA_SEGMENT_ACCESS = 0
Byte:042E: Bit:3, SCT_SUPPORTED_ERROR_RECOVERY_CONTROL = 0
Byte:042E: Bit:4, SCT_SUPPORTED_FEATURES_CONTROL = 0
Byte:042E: Bit:5, SCT_SUPPORTED_DATA_TABLE = 0
Byte:0430: SCTFanControlMaxOperatingTemp = 37
Byte:0431: SCTFanControlOverRangeTemp = 3C
Byte:0432: SCTFanControlUnderRangeTemp = 0A
Byte:0433: SCTFanControlMinOperatingTemp = 0E
Byte:0434: SCTVendorFlags = 05 00
Byte:0434: Bit:0, SCT_VENDORFLAGS_SEATOOLS = 1
Byte:0434: Bit:1, SCT_VENDORFLAGS_WRITE_SAME = 0
Byte:0434: Bit:2, SCT_VENDORFLAGS_CORRECTABLE_BIT = 1
Byte:0435: Bit:7, SCT_VENDORFLAGS_DEBUG_MODE = 0
Byte:0436: SCTTimerReadDefault = FF FF
Byte:0438: SCTTimerWriteDefault = FF FF
Byte:043A: SCTTenMsecCount = 00
Byte:043B: SCTPerformanceFlags = 00
Byte:043C: SCTTempDataTableSize = 00 00
Byte:043E: SCTSamplingPeriod = 00 00
Byte:0440: SCTInterval = 01 00
Byte:0442: ATAPadSlewRate = 00
Byte:0443: ATAIORDYPadControl = 00
Byte:0444: PreampHotTweak = 00
Byte:0445: PreampColdTweak = 00
Byte:0446: LubeMitigationRetries = 00 00
Byte:0448: LengthOfWriteSpaceToFlush = 00 00
Byte:044A: LengthOfWriteCommandToTriggerFlush = 00 00
Byte:044C: NDSLBAThresholdA = 00 00
Byte:044E: NDSLBAThresholdB = 00 00
Byte:0450: NDSPartitionDependencies = 00 00
Byte:0452: NDSODOffsetConfig = 00
Byte:0453: NDSIDOffsetConfig = 00
Byte:0454: APMTimer1mSec = 10 27
Byte:0456: APMTimer2mSec = 30 75
Byte:0458: APMStandByTimer = 20 00
Byte:045A: TimerForDither = 1E 00
Byte:045C: ReadDelayMinimum = 00
Byte:045D: WriteDelayMinimum = 00
Byte:045E: WriteDelayIncremental = 00
Byte:045F: ReadDelayIncremental = 00
Byte:0460: FeatureFlags = 81 00 00 28
Byte:0460: Bit:0, WRITE_CONFIG_DATA_TO_FLASH = 1
Byte:0460: Bit:1, SPINUP_WRITE_FAULT_THRESHOLDS_ENABLED = 0
Byte:0460: Bit:2, IOEDC_CHECK_ENABLED = 0
Byte:0460: Bit:3, IOEDC_ERROR_ENABLED = 0
Byte:0460: Bit:4, DOWNLOAD_MICROCODE_FUTURE_USE_ONLY = 0
Byte:0460: Bit:5, SUPPRESS_SERIAL_PORT_PRINTS = 0
Byte:0460: Bit:6, DRQ_CLEAR_ON_PIO_READ_ERR_SUPPORTED = 0
Byte:0460: Bit:7, OFFLINE_SEEK_AWAY = 1
Byte:0461: Bit:0, DELAY_SLEEP_STANDBY_CMDCOMPLETE = 0
Byte:0461: Bit:1, IDLE_IMMEDIATE_UNLOAD_EMERGENCY = 0
Byte:0461: Bit:2, ENABLE_ALLOW_RAW_ERROR_RATE_UPDATE = 0
Byte:0461: Bit:3, OP_SHOCK_DETECTION_ENABLED = 0
Byte:0461: Bit:4, LOG99_CONTROL = 0
Byte:0461: Bit:5, READ_WRITE_LONG_EXTENDED_ENABLED = 0
Byte:0461: Bit:6, WRITE_REORDERING_DISABLED = 0
Byte:0461: Bit:7, ALLOW_AAM_FEATURE_SET = 0
Byte:0462: Bit:0, DATA_LOG_ENABLED = 0
Byte:0462: Bit:1, HOST_STREAM_RECORD_FIRST_ERROR_BLOCK = 0
Byte:0462: Bit:2, SAVE_ATA_COMMAND_HISTORY_TO_DISC = 0
Byte:0462: Bit:3, EIB_ON_POWERUP = 0
Byte:0462: Bit:4, LEFT_JUSTIFY_SERIAL_NUMBER = 0
Byte:0462: Bit:5, SUN_MICRO_MODEL_NUMBER_UPDATE = 0
Byte:0462: Bit:6, REVERTING_TO_POWER_ON_DEFAULTS_SUPPORTED = 0
Byte:0462: Bit:7, RIGHT_JUSTIFY_FIRMWARE_REVISION = 0
Byte:0463: Bit:0, SEGMENT_INITIALIZED = 0
Byte:0463: Bit:1, DISPLAY_SMART_COMMANDS_ON_SERIAL_PORT_ENABLED = 0
Byte:0463: Bit:2, DISABLE_SMART_AUTO_UPDATES = 0
Byte:0463: Bit:3, DISABLE_LEGACY_READ_WRITE_LONG = 1
Byte:0463: Bit:4, VERSION_ENFORCEMENT_SUPPORTED = 0
Byte:0463: Bit:5, ENABLE_MICKEY_CERT = 1
Byte:0463: Bit:6, RETAIN_AMPS_VALUE_ON_DOWNLOAD = 0
Byte:0464: PerformanceFlags = 04 23
Byte:0464: Bit:0, REDUCED_RAW_TRANSITION_FLUSH = 0
Byte:0464: Bit:1, REDUCED_AV_RETRIES = 0
Byte:0464: Bit:2, ID_READ_PARAMETERS_FROM_CAP = 1
Byte:0464: Bit:4, VJIT_DISABLED = 0
Byte:0464: Bit:5, ZERO_LATENCY_RD_ENABLED = 0
Byte:0465: Bit:0, DAR_ENABLED = 1
Byte:0465: Bit:1, OFFLINE_SPARING_ENABLED = 1
Byte:0465: Bit:2, JIT3 = 0
Byte:0465: Bit:3, JIT2 = 0
Byte:0465: Bit:4, JIT1 = 0
Byte:0465: Bit:5, JIT0 = 1
Byte:0465: Bit:6, DISABLE_IDLE_ACTIVITY = 0
Byte:0465: Bit:7, ENABLE_SELF_SEEK = 0
Byte:0466: AggressivelyScanThisManyTimes = 00 00
Byte:0468: LongSeekEventTime = FF FF
Byte:046A: SleepStandbyDelay = 00 00
Byte:046C: CustomerUniques = 00 00 00 00
Byte:0470: CustomerType = 00 00 00 00
Byte:0474: AdditionalSATAFeatureConfig = 43 00 00 00
Byte:0474: Bit:0, SATA_FORCE_EARLY_STATUS = 1
Byte:0474: Bit:1, SATA_EARLY_STATUS_FORCE_COMRESET = 1
Byte:0474: Bit:2, SATA_INTRACOMMAND_PHY_MANAGEMENT_ENABLED = 0
Byte:0474: Bit:3, SATA_ENABLE_PHY_PM_CALIBRATION = 0
Byte:0474: Bit:4, SATA_ENABLE_SPI_VIS_MODE = 0
Byte:0474: Bit:5, SATA_ENABLE_RERR_TESTING = 0
Byte:0474: Bit:6, SATA_ENABLE_SSC = 1
Byte:0474: Bit:7, SATA_EYE_DIAGRAM_TEST = 0
Byte:0475: Bit:0, SATA_DISABLE_PRIMITIVE_SCRAMBLING = 0
Byte:0475: Bit:1, SATA_ULTRA_AGGRESSIVE_INTER_COMMAND_PHY_SUPPORTED = 0
Byte:0475: Bit:2, SATA_ULTRA_AGGRESSIVE_INTRA_COMMAND_PHY_SUPPORTED = 0
Byte:0475: Bit:3, SATA_HOST_PHY_PM_AND_DEVICE_PHY_PM_CAN_COEXIST = 0
Byte:0475: Bit:5, DISABLE_READ_PINNING = 0
Byte:0475: Bit:6, DISABLE_WRITE_PINNING = 0
Byte:0475: Bit:7, ENABLE_TEMPERATURE_TRANSMISSION = 0
Byte:0478: FactoryODScanMBytes = 00 00
Byte:047A: FactoryIDScanMBytes = 00 00
Byte:047C: MaxDSTSelfTestTime = 54 15
Byte:047E: DSTShortTestTimeLimit = 3C 00
Byte:0480: BootFlagsForROM = 0A 00
Byte:0480: Bit:0, BOOT_FLAG_POWER_ON_IN_STANDBY = 0
Byte:0480: Bit:1, BOOT_FLAG_PARTIAL_OOB = 1
Byte:0480: Bit:2, USE_SMALL_ID_FORMAT = 0
Byte:0480: Bit:3, LOW_CURRENT_SPINUP = 1
Byte:0482: TimerForPriorityDitherMins = 01
Byte:0483: TimerForMustHonorPriorityDitherMins = 14
Byte:0484: HostStreamJumpSizeInSectors = 00 00
Byte:0486: HostStreamTotalJumpSteps = 00
Byte:0487: SerialDebugLevel = 00
Byte:0488: DefaultStandbyTimer = 00
Byte:0489: ATAInterSectorTime = 08
Byte:048A: StandbyDelayBeforePostingStatus = 00 00
Byte:048C: StandbyPostingStatusFlags = 04 00
Byte:048C: Bit:0, ENABLE_WAIT_FOR_DRIVE_SPINDOWN_BEFORE_POSTING_STATUS_AFTER_STANDBY = 0
Byte:048C: Bit:1, ENABLE_HEADS_ON_RAMP_BEFORE_POSTING_STATUS_AFTER_STANDBY = 0
Byte:048C: Bit:2, ENABLE_DELAY_BEFORE_POSTING_STATUS_AFTER_STANDBY = 1
Byte:048F: LTTCPowerOnHours = 50
Byte:0490: DebugAddress0 = 00 00 00 00
Byte:0494: DebugValue0 = 00 00 00 00
Byte:0498: DebugAddress1 = 00 00 00 00
Byte:049C: DebugValue1 = 00 00 00 00
Byte:04A0: MaxDSTUnrecoverableFailures = 00 00
Byte:04A2: APMTimer3mSec = 28 43
Byte:04A4: LongCompletionEventTime = FF FF
Byte:04A6: EIB_DebugFlags = 00
Byte:04A6: Bit:0, EIB_WRT_MSG_ENABLE = 0
Byte:04A6: Bit:1, EIB_SWD_MSG_ENABLE = 0
Byte:04A6: Bit:2, EIB_SIM_MSG_ENABLE = 0
Byte:04A6: Bit:3, EIB_DEBUG_MSG_ENABLE = 0
Byte:04A7: EPCTimerIdle1Threshold100ms = 00 00
Byte:04A9: EPCTimerIdle2Threshold100ms = 00 00
Byte:04AB: EPCTimerIdle3Threshold100ms = 00 00
Byte:04AD: EPCTimerStandbyThreshold100ms = 00 00
Byte:04AF: EPCTimerMinThreshold100ms = 00 00
Byte:04B1: MediaCacheControl = 03
Byte:04B1: Bit:0, ID_BLOCK_MEDIA_CACHE_SUPPORTED = 1
Byte:04B1: Bit:1, ID_BLOCK_MEDIA_CACHE_ENABLED = 1
Byte:04B2: MediaScratchPadControl = 00
Byte:04B2: Bit:0, ID_BLOCK_MEDIA_SCRATCHPAD_SUPPORTED = 0
Byte:04B2: Bit:1, ID_BLOCK_MEDIA_SCRATCHPAD_ENABLED = 0
Byte:04B3: EPCDisabledMinTimerThreshold100ms = 00 00
Byte:04B5: EPCIdle1MinTime100ms = 00 00
Byte:04B7: EPCIdle2MinTime100ms = 00 00
Byte:04B9: EPCIdle3MinTime100ms = 00 00
Byte:04BB: EPCStandbyMinTime100ms = 00 00
Byte:04BD: WorkloadTracing = 01
Byte:04BE: Expansion = 00 00
Users browsing this forum: No registered users and 61 guests
