 Post subject: SSHD ST500LM000 KO
PostPosted: September 26th, 2016, 4:09
Hi, first, thank you for the great forum.
I have patient hdd:
ST500LM000, PN: 1EJ162-286, FW: AS12, NAND: Samsung K9LCGY8S1B-HCK0
And the donor hdd:
ST500LM000, PN: 1EJ162-038, FW: DEM9, NAND: Toshiba TH58TEG6DCJBA4C
ST1000LM014, PN: 1EJ164-040, FW: DEMD, NAND: Toshiba TH58TEG6DCJBA4C
As I think (and read on the forum), that there is wrong the NAND flash. On the serial console I can see:
ERROR: Flash Led 9C17 - RestoreALFTablesToDRAM Failed - could not recover data from Tables Clump
Clump Parametrics:
Clump = 0191
DataType = 00A3
ModeFlag = 02
EraseCount = ABBA232A
EraseFailCount = 03
ProgramFailCount = 01
WeakReadCount = 0B
UncorrectableECCError = 05
---SOC PSM Command History---
Cmd#/PsmCmd Clump Offset Length LbaMid LbaLow LbaBits39To32 Options Status DestClump DestOffset
0000 0191 0010 06B7 0000 0010 0000 C000 0001 C207 8680
0700 0191 0000 06C7 0000 0000 0000 C000 0001 C207 8680
0600 0018 0000 1000 0000 0000 0000 C000 0080 C207 8680
0500 0008 0560 0001 0000 0000 0000 C000 0080 C207 8680
0400 0008 0570 0001 0000 0000 0000 C000 0080 C207 8680
Flash Statistics:
BridgePSMDriverID = 0x0006
FlashID ECA7 947E 64C4
Flash Manufacturer: Samsung
Flash Capacity = 00008 GB MLC
Combo Mode
NumberOfClumps = 0x0800
LBAsPerCluster = 0x0010
LBAsPerClumpMLC = 0x2000
LBAsPerClumpSLC = 0x1000
ClustersPerClumpMLC = 0x0200
ClustersPerClumpSLC = 0x0100
DefragClumpThresholdInSectors = 0x1000
UserSLCMaxSizeInClumps = 0x0300
NumberOfPotentiallyWrittenClusters = 0x0004
DefectListRevisionKey 0x0002
SLC Clumps 0x0342
ALFRecorder:
End of ALF Recorder Trace
Ant that's all. No F3 console. Changing of the PCB did not help.
Is there any way:
a) how to download all firmwares from the patient PCB, and restore it to the donor PCB?
b) is possibility with some short circuit or something how to ignore this "RestoreALFTablesToDRAM" check and spin-up the disk?
c) is really the NAND flash dad, If i buy the same NAND and change it on the PCB, it will help? Or is something important saved on this NAND chip?
d) is any way, how to restore the data from the patient disk in my home environment?
Thank you, for any answers and helps.
 Post subject: Re: SSHD ST500LM000 KO
PostPosted: September 26th, 2016, 14:28
A) I am using pc3000 to do it.
b) no
c) no. it is media cash in nand.
d) no. unless you will buy something like pc3000. It should have support for this problem soon.
Users browsing this forum: Google [Bot] and 137 guests
