can someone please provide me this loder wd10jmvw-11s5xs0
October 4th, 2016, 12:16
thanks in advance .. brothers
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 4
Cyl Count............................... : 256
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 256 Kb
Flash ROM dir reading................... : Ok (Active)
Flash ROM dir reading (Ext)............. : Ok
Modules directory address............... : 70 587
SA regions address...................... : by default
SA Translator loading................... : Ok
ROM Modules:
ROM version............................. : 03.52C
ROM F/W version......................... : 00030052
Overlay F/W version..................... : 03.52C
Servo F/W version....................... : TP.46
Heads configuration..................... : by map
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
Re: can someone please provide me this loder wd10jmvw-11s5x
October 4th, 2016, 12:32
It is a Firebird, by the looks of things. You can download it from the resources on our website - https://www.recoveryforce.com/data-reco ... resources/
PM me for the password.
October 4th, 2016, 14:01
Why can't you use the search
Its already in the forum since FEB 2014 by Sean (pcimage)
viewtopic.php?p=191771#p191771
And by MindMergepk again from NOV 2014
viewtopic.php?p=207427#p207427
October 4th, 2016, 15:39
jermy wrote:Why can't you use the search
i used the search before i ask ..
the first link is not working with me
the sec is not same fw i need
i need this :
if someone have it pls provide it to me :)
lcoughey
i pm you .. for the password
thanks to you all guys
October 4th, 2016, 15:53
There is at least 1 with the exact version you are looking for on my site. Have fun.
