 Post subject: Problems after replace head
PostPosted: October 8th, 2016, 9:33
Hi everyone,
I have to try replace a head from a new HDD to a HDD with a crash head.
The replacement is done ... but the hard disc will not work with the new head ?
I have take a identical hard disc.
Is there something that i must do after that i have replace the head ?
thx!
Tim
 Post subject: Re: Problems after replace head
PostPosted: October 8th, 2016, 11:20
what is the drive model and make ?
what make you think you should replace heads ?
did you replace head in clean environment ?
what was the symptom of drive prior to changing head ?
Data Recovery Pakistan
PostPosted: October 8th, 2016, 12:47
Model: WD15NMVW-11AV3S2 WESTERN DIGITAL 1.5TB USB 3.0 DCM: HBMTJHKB
I did in clean environment.
Symptom is clicking ... HD was dropped on the floor.
PostPosted: October 8th, 2016, 13:10
If you put it back to the donor do they work ?
PostPosted: October 8th, 2016, 13:37
Not tried but when i have replace the head ... is there something that is must to do ?
PostPosted: October 8th, 2016, 16:04
should examine the original heads.
Users browsing this forum: No registered users and 52 guests
