 Post subject: ST1000DM003 hdd showing only 32 MB size
PostPosted: October 11th, 2016, 2:32
I have Seagate ST1000DM003 hdd which is showing 32 MB only, running smoothly no sound.
terminal shows following details when we power on the hdd :-
Boot 0x40M
Spin Up[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 40125B28 40122F00
Seg Write Preamble VBM start: 0000204A end: 00002091
Footer - start: 00002093 end: 000020DA
Seg Read Preamble VBM - start: 000020DC end: 00002123
Footer - start: 00002125 end: 0000216C
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 0A61
Nonvolatile MCMT sequence number 010AA616
[RSRS] 03C6
Reconstruction: Completed 0: HeadPtr was unwritten
[MCMTWS]
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00000041
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000002A
MCMainPOR: MCStateFlags = 00000041
MCMainPOR: Feature Enabled...
PowerState = IDLE1
PowerState = IDLE2
Any help appreciated....
 Post subject: Re: ST1000DM003 hdd showing only 32 MB size
PostPosted: October 11th, 2016, 4:12
GigaByte BIOS bug results in loss of 1TB capacity:
http://www.hddoracle.com/viewtopic.php?f=59&t=150&p=275
PostPosted: October 11th, 2016, 5:33
Boot 0x40M
Trans.
Rst 0x40M
Spin Up
(P) SATA Reset
MCMainPOR: Start:
[RSRS] 03C6
[MCMTWS]
PowerState = IDLE1
PowerState = IDLE2
Well,
You Have PC3K For Sure i Know That ,So USe The Setmax Feature And Save To SA Area .But if thats Not a Issue then you have a firmware issue or a head issue
