 Post subject: Maxtor 6L200R0 number of heads and read size
PostPosted: October 9th, 2016, 18:27
First, this is just an informational question, as I am trying to understand information about a drive that is not in my possession.
I have been talking with someone that has a Maxtor 6L200R0 that is failing, and the ddrescue log provided looks like it has 6 heads with 2 heads failing (see the image). It was hard to see at first because it looks like this drive has about 1MB read size per head. I had to max out the settings on my viewing tool to see it the pattern. Does this sound correct for this drive? I am used to seeing 50-100MB size reads per head. I think I figured my head skipping algorithm could handle down to 20MB read size per head with the default settings. A drive like this would not work well with the default settings for my head skipping algorithm, and trying to explain how to know what to change the settings to would be about impossible to explain to a novice :(
http://www.hddsuperclone.com
Home of HDDSuperClone
 Post subject: Re: Maxtor 6L200R0 number of heads and read size
PostPosted: October 9th, 2016, 19:34
FWIW, here is one way to determine the desired parameters for a healthy drive, but I would not do it with yours.
How to determine number of heads using HD Tune:
http://www.hddoracle.com/viewtopic.php? ... 650&p=1796
PostPosted: October 10th, 2016, 18:14
Even if the read size cannot be verified, can someone at least confirm how many heads this model drive has? I looked online but did not find any specs for this model that included the number of heads. Specs for some close models had either 4 or 6 heads, but nothing for this model.
PostPosted: October 11th, 2016, 19:57
What is serial number of this drive?
PostPosted: October 11th, 2016, 20:32
If you can read SA module 0x1F/31 ("DISK") with HDDSuperTool, then you will see the number of heads. We were able to do this at the HDD Oracle using freeware methods.
44 49 53 4B 02 00 03 00 04 00 05 00 FF FF FF FF  DISK
FF FF FF FF 00 88 BD 17 04 00 04 00 00 88 BD 17
                        ^^^^^^^^^^^ heads?
3C 00 3C 00 34 4C 42 32 4C 56 47 35 20 20 20 20  <.<.4LB2LVG5
^^^^^^^^^^^ head map?
20 20 20 20 20 20 20 20 61 4D 74 78 72 6F 36 20          aMtxro6
32 4C 30 30 30 50 20 20 20 20 20 20 20 20 20 20  2L000P
20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 00
64 00 32 00 4E 00 00 00 00 00 00 00 00 00 00 00
PostPosted: October 12th, 2016, 18:06
This is the information I was provided:
Device Model: Maxtor 6L200R0
Serial Number: L50FB9MG
If you can read SA module...
As stated in the first post the drive is NOT in my possession. The drive is still likely part of an active recovery attempt by a beginner that I was trying to help, and there is no way I am going to ask for special commands to be run on it. It will be lucky if the drive does not get killed before the best recovery image is achieved :shock:
PostPosted: October 13th, 2016, 16:50
5 heads
PostPosted: October 13th, 2016, 19:06
drHDD wrote:
5 heads
I have adjusted the display on the viewer to get the pattern lined up better, and I think 5 heads does match the pattern (2 heads are weak). That would confirm that the read size per head is a little over 1MB, according to calculations from the log file. The default skip size for the head skipping algorithm of HDDSuperClone would not work well for a drive like this. It would induce runaway skipping which would cause skip resets, although it is stated in the manual that if there are skip resets then the settings may need to be changed.
PostPosted: October 13th, 2016, 20:34
I'm a little confused by the arithmetic.
    LBA 64000 = CHS 961/4/0
    LBA 159037 = CHS 1060/4/1319
That's 100 tracks at 1320 SPT, ie 132000 LBAs. However, the LBA count only increases by 95037. Perhaps I'm having a brain fart?
Users browsing this forum: Majestic-12 [Bot] and 96 guests
