 Post subject: HD seen in BIOS but not in OS
PostPosted: October 21st, 2016, 9:55
Strange problem;
All of a sudden my secondary drive (Seagate Barracuda 3TB) has disappeared.
It shows up in my BIOS but it doens't show in Windows 10.  Not even under "disk Management".
I have tried changing SATA cable and Ports and no luck. (BIOS sees the port move.)  I have also tried it in another computer with the same results.  I have tried the Seagate tool and a couple of other utilities and no luck, They don't even see the drive.
When the drive is connected, the computer is slow to load the BIOS.  When the drive is unplugged it boots at normal speed.
I can hear the drive spin. (Would this rule out the control board?)
Any ideas?
Thanks guys!
 Post subject: Re: HD seen in BIOS but not in OS
PostPosted: October 21st, 2016, 10:10
Hello neighbour! :)
The dreaded ST3000DM001 strikes again. Probably bad heads+media damage. The more you work with it/power it on, the lower the odds of a successful recovery.
PostPosted: October 31st, 2016, 5:23
Is it shows 3TB in bios? and model No correct in Bios?
PostPosted: January 24th, 2017, 17:18
iwapete,
hi
i have same problem
what was your hdd problem?
PostPosted: January 24th, 2017, 18:43
Spildit, thanks
actually no important data in it but it will be nice if i can repair it by myself without data lost
few days ago it showed bad sector after updating irst driver in windows and after it, bad sectors grows and now drive is invisible in windows. bios and seatools shows it but can't even check it with seatools. it returns "device is not responding to command,power failure or connection problem". device is spining. When the drive is connected, the computer is slow to load the BIOS. When the drive is unplugged it boots at normal speed.
no sign of fried part on board.
can u or anyone help pls
PostPosted: January 24th, 2017, 19:00
Auch, the famous DaMn drive :oops: :evil: :twisted:
If you're trying to save the drive, then most likely will not happen.
you "might" be able to save it temporarily just enough to rescue the data, but not for reuse
Users browsing this forum: No registered users and 160 guests
