 Post subject: ST500DM002 Not Detect In Bios !!!!
PostPosted: October 23rd, 2016, 8:41
My Hard Disk Not Detect In Bios & OS !
i,m clear smart and use m0,2,2,,,,,22 To Fix This But Not Working !
after turn on HDD See write this on Hyper Terminal :
Boot 0x40M
Spin Up
TCC-0022[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-0022
(P) SATA Reset
MCMTFileHandler: EXCEPTION: Failed MCMT read request
MCMainPOR: EXCEPTION: SIM aborted prior to MCMT read
MCMainPOR: EXCEPTION: POR Failed General
MCMainPOR: Feature Disabled...
PowerState = IDLE1
PowerState = IDLE2
APM disabled by SPort
ASCII Diag mode
F3 T>
F3 T>/7
F3 7>X
HighPowerMode
TCC-0022Status 0001 Req 0002
Head 00 Resistance 0183
Head 01 Resistance 00F0
F3 7>
PCB heads resistance Working Fine !
How Can Fix This ?
I Search On Forum But Not Find Command To Fix This , i,m not hearing Clicking Noise After Plug in Sata and turn on hdd .
Sorry English Not My First Language .
Thanks , Regards .
 Post subject: Re: ST500DM002 Not Detect In Bios !!!!
PostPosted: October 23rd, 2016, 16:15
F3 7>X
HighPowerMode
what is your intent, if you just want to fix it for future use, forget it.
if you are after data from this drive, best is to send to a DR Company.
drive has atleast 1 weak head and required clean room work.
good luck.
Data Recovery Pakistan
PostPosted: October 24th, 2016, 1:28
ITS SHOW MCMT TRY WRITE THIS MODULE AND HARD DISK DETECT AGAIN IN BIOS
MCMT MODULE ST500DM002.rar [105.6 KiB]
Downloaded 782 times
PostPosted: October 24th, 2016, 12:09
Humm,
Volume 3 ,Head 0 sys File .How about trying to disable SMP Setting ? :)
PostPosted: October 25th, 2016, 5:42
Hello :cry: I,Can Fix This !!!!
Translator Regenerator But This Error !!!!!!!!
Rst 0x10M
RW: Disc Ctlr Initialization Completed.
No HOST FIS-ReadyStatusFlags 2002A1A5
ASCII Diag mode
F3 T>
ASCII Diag mode
How Can i Fix this and get my data !
PostPosted: October 25th, 2016, 9:52
FIRST BACKUP PLIST AND NG LIST AND TRY ON T LEVEL m0,6,2,,,,,22 - and m0,6,3,,,,,22
PostPosted: October 25th, 2016, 9:56
No HOST FIS-ReadyStatusFlags is a problem with some of FIDs, another words - System Files
First, try 'V40' to check for NRG defects...
PostPosted: October 25th, 2016, 16:56
with a weak head more you try to write more problem you will create.
Users browsing this forum: Google [Bot] and 46 guests
