 Post subject: HITACHI HTS725032A9A364 strange smart tests results
PostPosted: November 20th, 2016, 13:15
Hi!
I have strange problem with my disk. Extended offline SMART test is Completed always without error but Short offline SMART test is showing Completed: read failure. And the LBA of first Error shows: 625152530. But the mediasize in sectors is 625142448. So it looks like it reporting error in LBA outside the disk drive. I tried MHDD and it doesing find any bad sector on disk. (as it scans from 0 to 625142448). Do you know how to recover from this ?
diskinfo -v /dev/da2
/dev/da2
512 # sectorsize
320072933376 # mediasize in bytes (298G)
625142448 # mediasize in sectors
0 # stripesize
0 # stripeoffset
38913 # Cylinders according to firmware.
255 # Heads according to firmware.
63 # Sectors according to firmware.
HITACHI HT100606PCKC04VPK0PJDJ # Disk ident.
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Hitachi Travelstar 7K500
Device Model: HITACHI HTS725032A9A364
Serial Number: 100606PCKC04Vxxxxxxx
LU WWN Device Id: 5 000cca 5b7eaxxxx
Firmware Version: PC3ZC70F
User Capacity: 320,072,933,376 bytes [320 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 7200 rpm
Form Factor: 2.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS T13/1699-D revision 6
SATA Version is: SATA 2.6, 1.5 Gb/s (current: 1.5 Gb/s)
Local Time is: Sun Nov 20 18:12:27 2016 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 645) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 91) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 062 Pre-fail Always - 0
2 Throughput_Performance 0x0005 100 100 040 Pre-fail Offline - 0
3 Spin_Up_Time 0x0007 189 189 033 Pre-fail Always - 3
4 Start_Stop_Count 0x0012 098 098 000 Old_age Always - 3556
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 100 100 040 Pre-fail Offline - 0
9 Power_On_Hours 0x0012 069 069 000 Old_age Always - 13862
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 098 098 000 Old_age Always - 3438
191 G-Sense_Error_Rate 0x000a 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 2789802081
193 Load_Cycle_Count 0x0012 083 083 000 Old_age Always - 170081
194 Temperature_Celsius 0x0002 171 171 000 Old_age Always - 32 (Min/Max 1/60)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 247
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 1
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
223 Load_Retry_Count 0x000a 100 100 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed: read failure 60% 13861 625152530
# 2 Extended offline Completed without error 00% 13845 -
# 3 Short offline Completed: read failure 60% 13844 625152530
# 4 Extended offline Completed without error 00% 13843 -
# 5 Short offline Completed: read failure 40% 13841 625152530
# 6 Short offline Aborted by host 10% 13841 -
# 7 Short offline Completed: read failure 50% 12236 625152530
# 8 Short offline Completed without error 00% 12116 -
# 9 Short offline Completed without error 00% 12102 -
#10 Vendor (0x50) Completed without error 00% 0 -
3 of 4 failed self-tests are outdated by newer successful extended offline self-test # 2
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Users browsing this forum: Google [Bot] and 49 guests
