 Post subject: Long terminal output with Fail=op and LED interpretation
PostPosted: November 20th, 2016, 11:32
I have got a 7200.12 hard disk. When powered it tends to be busy.
In udma terminal I get big message -
Is it heads related or firmware ? How can I address this ? First step will be to short read channel and get drd dsc.
but rest of the message might indicate head failure
[0x00000000][0x0000B67C][0x0000BA10]
Trans.
Rst 0x10M
MC Internal LPC Process
Spin Up
FAIL Op=0165 Resp=0005
FAIL Op=0165 Resp=0007
FAIL Op=0900 Resp=0005
FAIL Op=0600 Resp=0005
(P) SATA Reset
MediaPartition:
Host LBA Length Disc LBA Length Start Cyl Head
Media Partition 00000000 0099F770 00000000 00133EEE 00000000 00000000
MC 00000000 00989AF8 00000000 0013135F 00000000 00000000
MSP 009984F8 00000A68 0013309F 0000014D 000006E1 00000001
User Partition 0099F770 00133EEE 000006D6 00000001
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 060DBEBC 060DA1A8
Seg Write Preamble VBM start: 00000D3C end: 00000D63
Footer - start: 00000D65 end: 00000D8C
Seg Read Preamble VBM - start: 00000D8E end: 00000DB5
Footer - start: 00000DB7 end: 00000DDE
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 22E0
Nonvolatile MCMT sequence number 00BBE9F6
[RSRS] 1777 DiscLba 000CD514 RW_RTL FFFFFFFF
Reconstruction: Completed 1:
[MCMTWS]
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00000041
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000012A
MCMainPOR: MCStateFlags = 00000041
MCMainPOR: Feature Enabled...
MSP MainPOR:
MSP Init Metadata
Buf Bytes/VBM 00000208 DBA Base 06000000
Metadata size in bytes 0040
Num Segments 0053
Logical Sector Alignment 00000000
MSP Reconstruction
MSP Read ScratchPad Section 0000 DiscLBA 0013309F BlkSize 00000A60 Num Segments 00000053 DiscLba 0013309F RW_RTL 000F4240
Starting LBA of RW Request=0013309F Length=0000014C
ProcessRWError -Read- at LBA 0013309F Sense Code=C3160080
RTL exceeded
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 0013309F
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000000
MSP Reconstruction: EXCEPTION: Read MSP Segment Error
Segment 0000StartLBA 009984F8 ErrorLBA 009984F8
Error in MSP Header
Continue MSP Read, PreError Segment Cnt0000
Num Segments 0053
No valid segments found
MSP Read ScratchPad Section 0001 DiscLBA 001330A3 BlkSize 00000A40 Num Segments 00000052 DiscLba 001330A3 RW_RTL 000F4240
Starting LBA of RW Request=001330A3 Length=00000148
ProcessRWError -Read- at LBA 001330A3 Sense Code=43110081
RTL exceeded
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 001330A3
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000001
Segment 0001StartLBA 00998518 ErrorLBA 00998518
Error in MSP Header
Num Segments 0053
MSP Read ScratchPad Section 0002 DiscLBA 001330A7 BlkSize 00000A20 Num Segments 00000051 DiscLba 001330A7 RW_RTL 000F4240
Starting LBA of RW Request=001330A7 Length=00000144
ProcessRWError -Read- at LBA 001330A7 Sense Code=C3160080
RTL exceeded
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 001330A7
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000002
Segment 0002StartLBA 00998538 ErrorLBA 00998538
Error in MSP Header
Num Segments 0053
MSP Read ScratchPad Section 0003 DiscLBA 001330AB BlkSize 00000A00 Num Segments 00000050 DiscLba 001330AB RW_RTL 000F4240
Starting LBA of RW Request=001330AB Length=00000140
ProcessRWError -Read- at LBA 001330AB Sense Code=C3160080
RTL exceeded
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 001330AB
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000003
Segment 0003StartLBA 00998558 ErrorLBA 00998558
Error in MSP Header
Num Segments 0053
MSP Read ScratchPad Section 0004 DiscLBA 001330AF BlkSize 000009E0 Num Segments 0000004F DiscLba 001330AF RW_RTL 000F4240
Starting LBA of RW Request=001330AF Length=0000013C
ProcessRWError -Read- at LBA 001330AF Sense Code=C3160084
RTL exceeded
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 001330AF
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000004
Segment 0004StartLBA 00998578 ErrorLBA 00998578
Error in MSP Header
Num Segments 0053
MSP Read ScratchPad Section 0005 DiscLBA 001330B3 BlkSize 000009C0 Num Segments 0000004E DiscLba 001330B3 RW_RTL 000F4240
Starting LBA of RW Request=001330B3 Length=00000138
ProcessRWError -Read- at LBA 001330B3 Sense Code=C3160080
RTL exceeded
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 001330B3
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000005
Segment 0005StartLBA 00998598 ErrorLBA 00998598
Error in MSP Header
Num Segments 0053
MSP Read ScratchPad Section 0006 DiscLBA 001330B7 BlkSize 000009A0 Num Segments 0000004D DiscLba 001330B7 RW_RTL 000F4240
Starting LBA of RW Request=001330B7 Length=00000134
ProcessRWError -Read- at LBA 001330B7 Sense Code=43110081
RTL exceeded
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 001330B7
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000006
Segment 0006StartLBA 009985B8 ErrorLBA 009985B8
Error in MSP Header
Num Segments 0053
MSP Read ScratchPad Section 0007 DiscLBA 001330BB BlkSize 00000980 Num Segments 0000004C DiscLba 001330BB RW_RTL 000F4240
Starting LBA of RW Request=001330BB Length=00000130
ProcessRWError -Read- at LBA 001330BB Sense Code=C3160080
RTL exceeded
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 001330BB
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000007
Segment 0007StartLBA 009985D8 ErrorLBA 009985D8
Error in MSP Header
Num Segments 0053
MSP Read ScratchPad Section 0008 DiscLBA 001330BF BlkSize 00000960 Num Segments 0000004B DiscLba 001330BF RW_RTL 000F4240
Starting LBA of RW Request=001330BF Length=0000012C
ProcessRWError -Read- at LBA 001330BF Sense Code=C3160080
RTL exceeded
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 001330BF
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000008
Segment 0008StartLBA 009985F8 ErrorLBA 009985F8
Error in MSP Header
Num Segments 0053
MSP Read ScratchPad Section 0009 DiscLBA 001330C3 BlkSize 00000940 Num Segments 0000004A DiscLba 001330C3 RW_RTL 000F4240
Starting LBA of RW Request=001330C3 Length=00000128
ProcessRWError -Read- at LBA 001330C3 Sense Code=C3160080
RTL exceeded
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 001330C3
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000009
Segment 0009StartLBA 00998618 ErrorLBA 00998618
Error in MSP Header
Num Segments 0053
MSP Read ScratchPad Section 000A DiscLBA 001330C7 BlkSize 00000920 Num Segments 00000049 DiscLba 001330C7 RW_RTL 000F4240
Starting LBA of RW Request=001330C7 Length=00000124
ProcessRWError -Read- at LBA 001330C7 Sense Code=C3160080
RTL exceeded
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 001330C7
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000000A
Segment 000AStartLBA 00998638 ErrorLBA 00998638
Error in MSP Header
Num Segments 0053
MSP Read ScratchPad Section 000B DiscLBA 001330CB BlkSize 00000900 Num Segments 00000048 DiscLba 001330CB RW_RTL 000F4240
Starting LBA of RW Request=001330CB Length=00000120
ProcessRWError -Read- at LBA 001330CB Sense Code=C3160080
RTL exceeded
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 001330CB
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000000B
Segment 000BStartLBA 00998658 ErrorLBA 00998658
Error in MSP Header
Num Segments 0053
MSP Read ScratchPad Section 000C DiscLBA 001330CF BlkSize 000008E0 Num Segments 00000047 DiscLba 001330CF RW_RTL 000F4240
Starting LBA of RW Request=001330CF Length=0000011C
ProcessRWError -Read- at LBA 001330CF Sense Code=C3160080
RTL exceeded
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 001330CF
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000000C
Segment 000CStartLBA 00998678 ErrorLBA 00998678
Error in MSP Header
Num Segments 0053
MSP Read ScratchPad Section 000D DiscLBA 001330D3 BlkSize 000008C0 Num Segments 00000046 DiscLba 001330D3 RW_RTL 000F4240
Starting LBA of RW Request=001330D3 Length=00000118
ProcessRWError -Read- at LBA 001330D3 Sense Code=C3160080
RTL exceeded
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 001330D3
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000000D
Segment 000DStartLBA 00998698 ErrorLBA 00998698
Error in MSP Header
Num Segments 0053
MSP Read ScratchPad Section 000E DiscLBA 001330D7 BlkSize 000008A0 Num Segments 00000045 DiscLba 001330D7 RW_RTL 000F4240
Starting LBA of RW Request=001330D7 Length=00000114
ProcessRWError -Read- at LBA 001330D7 Sense Code=C3160080
RTL exceeded
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 001330D7
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000000E
Segment 000EStartLBA 009986B8 ErrorLBA 009986B8
Error in MSP Header
Num Segments 0053
MSP Read ScratchPad Section 000F DiscLBA 001330DB BlkSize 00000880 Num Segments 00000044 DiscLba 001330DB RW_RTL 000F4240
Starting LBA of RW Request=001330DB Length=00000110
ProcessRWError -Read- at LBA 001330DB Sense Code=C3160080
RTL exceeded
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 001330DB
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000000F
Segment 000FStartLBA 009986D8 ErrorLBA 009986D8
Error in MSP Header
Num Segments 0053
MSP Read ScratchPad Section 0010 DiscLBA 001330DF BlkSize 00000860 Num Segments 00000043 DiscLba 001330DF RW_RTL 000F4240
Starting LBA of RW Request=001330DF Length=0000010C
ProcessRWError -Read- at LBA 001330DF Sense Code=C3160080
FAIL Op=0155 Resp=0007
FAIL Op=008F Resp=0003
FAIL Op=000E Resp=0007
FAIL Op=0006 Resp=0003
LED:000000BD FAddr:00007A4C
Users browsing this forum: No registered users and 38 guests
