 Post subject: ST9500423AS
PostPosted: March 12th, 2016, 11:12
The drive in topic needed heads swap. After heads replacement clicks three times then keep spinning.
Terminal :
EarlySpinup Enabled
Rst 0x10M
ExecuteSpinRequest
LED:00000067 FAddr:00380338
Any suggestions ?
Thanks in advance
ROM file:
Data.rar [433.46 KiB]
Downloaded 420 times
 Post subject: Re: ST9500423AS
PostPosted: March 12th, 2016, 11:35
Ahmed ,
Why Do You think i Needed Head Replacement in first place .Anyways Now Is The Translator Working ? .Can You Check "User Track Slip List " Aka Translator in Terminal .Are You Able to Go To Terminal in First Place Now ?
PostPosted: March 12th, 2016, 11:44
Amarbir wrote:
Ahmed ,
The drive was coming clicks then spin down. Surely it was a heads problem.
Now after heads swap it clicks three times then coming to READY and keep spinning. No ID
I suspect the ROM has changed in another DR firm. But the customer insist that he didn't.
PostPosted: March 12th, 2016, 11:56
unknown wrote:
Amarbir wrote:
Ahmed ,
OK,
I Am Coming To Skype To Help You With This Case :mrgreen:
PostPosted: March 12th, 2016, 14:46
Case solved. :)
Thank you Amarbir my friend :D
PostPosted: March 12th, 2016, 14:52
unknown wrote:
Case solved. :)
Nice,
You are welcome ahmed .Tell me the story on skype tommorow .Was a tough nut to crack .
PostPosted: March 12th, 2016, 14:56
Sure I will.
Data needed was 24MB :mrgreen:
PostPosted: March 12th, 2016, 15:00
unknown wrote:
Sure I will.
Lol ,
That all bloddy hell and we both slogged like anything hee hee .Anyways its nice skype the end end things done on skype i am active
PostPosted: December 10th, 2016, 14:34
Hi. Can you please tell me the solution for a case ? I have the same problem on my drive.
Thank you!
Users browsing this forum: Google [Bot] and 62 guests
