Help ROM original hard drive wd 250GB
December 4th, 2016, 13:11
My hard drive die wd250js ROM.
I need to recover data, give me this hard drive ROM original
Looking forward to your help
Thank you
Re: Help ROM original hard drive wd 250GB
December 4th, 2016, 14:17
Spildit wrote:Uhhhmmm..... Why am i getting this feeling that i know you from somewhere ?
:hmmm:
Well, where on the world are you located ? Vietnam ?
Why do you think the ROM is damaged ? Did you made something to it ?
Does the drive spin at all ? Does it click ?
Did you try a PCB replacement with ROM swapping and you damaged the chip ?
Tell us more about the drive and what it's doing. At least tell us if it's spinning at all.
I exchanged PCB hard drive spinning up normally
I exchanged ROM chip on the hard drive does not spin
You help me
December 4th, 2016, 14:33
Have you checked the ROM solder joints to make sure it's been put on correctly.
December 4th, 2016, 16:01
Spildit wrote:
datasevices wrote:I exchanged PCB hard drive spinning up normally
You help me
The attachment wd3.jpg is no longer available
Do you have any way to READ ROM on the CHIP (external programmer) ?
DUMP the ROM with something like this : - http://www.hddoracle.com/viewtopic.php?f=117&t=865
If it doesn't work try to move ROM back to the other PCB. Do you have access to SA with non-native ROM + donnor overlay 11 ?
I have used the external ROM programming
I have used the external ROM programming, because the original ROM White , you have ROM help me
December 4th, 2016, 16:53
if hdd spin normally with other pcb
this mean recover data is very easy in this case
but clarifiy these points
1- can you read SA modules by new pcb
if not then write any good rom so you can access SA modules
read them all
and i have very good way to recover data in these old L-shapped even with no original rom
but Extract modules or at least key modules from SA
December 4th, 2016, 22:36
I can't stress enough, if you are not used to changing ROM chips, check the solder joints first.
December 5th, 2016, 16:08
Are these close enough?
You may need to edit the head map for the 160GB ROM.
WDxx00JS-xxNCB1.7z
(255.82 KiB) Downloaded 526 times
December 8th, 2016, 11:13
fzabkar wrote:Are these close enough?
oh my good friend, Lord will bless you
Thank you very much :D :D :D
