 Post subject: WD20NMVW-59AV3s3
PostPosted: January 26th, 2017, 4:45
Some time ago i get a drive like in topic with a problem of no option to access to data. Disk is conneted by USB 3.0 so i can't test this drive with MHDD. I try to get to data using dmde but i get information about invalid parameters. I try to set parameters manually but can't find them.
Is there a sense of this play? May be there is other solution.
Best Regards,
 Post subject: Re: WD20NMVW-59AV3s3
PostPosted: January 26th, 2017, 17:51
If you have to set parameters, that means that the device needs proper examinations
Is the drive making unusual noise ? (Clicking, beeping, buzzing Etc.)
If the dive makes any unusual noise, the stop to power on the drive
If data has any value, then send it to a Data Recovery pro
The best way to examine the drive would be with a SATA board
Users browsing this forum: No registered users and 184 guests
