Recover data off corrupted external hard drive
January 29th, 2017, 13:35
Good day, I recently used VeraCrypt to encrypt an external hard drive (Seagate 1TB) and long story short, the drive is now corrupted and unfortunately I do not have a complete backup of the drive. Windows 10 does not recognize the drive and wants me to format it. I believe it is in RAW state.
I have used a number of free tools (Recuva, TestDisk, Mini Tool Power Data Recovery, M3 Data Recovery) and a paid one (Kroll Ontrack EasyRecovery) to try to recover the data, to no avail.
EasyRecovery detected and recovered the most number of files but I was not able to open them because they all seem to be corrupted. What is unusual is I used EasyRecovery to recover a number of deleted files off the main hard drive, as a test, and I still could not open/play them either. That leads me to believe there may be an issue with EasyRecovery but I am doing further research into this.
Could you please advise what my next step should be before I contact a local professional data recovery shop for estimate? It will not do me any good if they are able to recover the files and I am not able to open them.
Thank you very much!
Re: Recover data off corrupted external hard drive
March 10th, 2017, 11:30
"...I recently used VeraCrypt to encrypt an external hard drive..." My first guess is that the data recovery programs cannot interpret, cannot un-encrypt, the files.
March 10th, 2017, 12:31
It could be that drive is failing due to bad sector or FW problem or it could be that master key or critical data is damaged.
I would suggest to send it to Decent DR company and get the estimate.
good luck.
March 10th, 2017, 12:56
RolandJS wrote:"...I recently used VeraCrypt to encrypt an external hard drive..." My first guess is that the data recovery programs cannot interpret, cannot un-encrypt, the files.
Exactly this. Of course the data isn't recognized by Windows or data recovery software. It's ENCRYPTED!!!
If you used veracrypt + a password to encrypt, then you'll logically need to use veracrypt along with the password to get the data back.
