 Post subject: WD MyBook 2TB external drive (encrypted) dead [FIXED]
PostPosted: January 3rd, 2017, 12:57
This really isn't a "need help" post, rather it's a "I managed to fix it, maybe it might help someone else".
Received a 2TB 3.5" external WD MyBook system, and alas it was not turning on at all, and of course the drive data was encrypted. Didn't have a lot of viable options but I decided I'd try repair the USB bridge board and had success.
Turns out it was the SMPS controller on the board that had blown. I got lucky this time. If you do a voltage test and see 0V on both legs of the on/off switch button on the logic board, then there's a reasonable chance it might just need the SMPS controller changed, trick is you'll need a donor ( at least until I take the time to evaluate a possible replacement ).
Have a YouTube video of the process: https://www.youtube.com/watch?v=yufLqOl ... aDfC_63dFY
You have a backup...right? | Tech Repairs on YouTube
 Post subject: Re: WD MyBook 2TB external drive (encrypted) dead [FIXED]
PostPosted: January 3rd, 2017, 20:24
Spildit wrote:
Thanks for sharing !!!
Sometimes a simple electronic repair can save a lot of trouble !
Regards.
I consider myself insanely lucky that the shot-in-the-dark worked. I must put the time in though to find out what that SM controller is, or at least a suitable replacement.
Users browsing this forum: No registered users and 378 guests
