 Post subject: ST9320325AS connects but only 0-byte size
PostPosted: January 3rd, 2017, 13:07
On my linux recovery system, a 320GB Seagate 2.5" drive intermittently shows up with the following on powerup;
Jan 4 03:09:13 REC01 kernel: [8424027.545807] ata4.00: HPA support seems broken, skipping HPA handling
Jan 4 03:09:13 REC01 kernel: [8424027.545817] ata4.00: ATA-8: ST9320325AS, 0003, max UDMA/133
Jan 4 03:09:13 REC01 kernel: [8424027.545823] ata4.00: 0 sectors, multi 16: LBA NCQ (depth 31/32)
Jan 4 03:09:13 REC01 kernel: [8424027.546643] ata4.00: configured for UDMA/133 (device error ignored)
Jan 4 03:09:13 REC01 kernel: [8424027.551231] ata4: EH complete
Jan 4 03:09:13 REC01 kernel: [8424027.551435] scsi 3:0:0:0: Direct-Access ATA ST9320325AS 0003 PQ: 0 ANSI: 5
Jan 4 03:09:13 REC01 kernel: [8424027.552036] sd 3:0:0:0: [sdc] 0 512-byte logical blocks: (0 B/0 B)
Jan 4 03:09:13 REC01 kernel: [8424027.552223] sd 3:0:0:0: [sdc] Write Protect is off
Jan 4 03:09:13 REC01 kernel: [8424027.552232] sd 3:0:0:0: [sdc] Mode Sense: 00 3a 00 00
Jan 4 03:09:13 REC01 kernel: [8424027.552312] sd 3:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jan 4 03:09:13 REC01 kernel: [8424027.552552] sd 3:0:0:0: Attached scsi generic sg2 type 0
Jan 4 03:09:13 REC01 kernel: [8424027.553207] sd 3:0:0:0: [sdc] Attached SCSI disk
What are the possible causes, and what possible recovery options?
You have a backup...right? | Tech Repairs on YouTube
 Post subject: Re: ST9320325AS connects but only 0-byte size
PostPosted: January 3rd, 2017, 18:50
You need software which could work with system area
PostPosted: January 3rd, 2017, 19:10
I'm presuming that'll be via the serial port of the drive?
What generally causes this fault?
PostPosted: January 3rd, 2017, 20:17
Spildit wrote:
0-LBA. If the drive is not clicking / making strange noises most likely it have DAMAGED TRANSLATOR very typical on Seagate F3 arch drives.
You need at least something like this :
http://www.hddoracle.com/viewtopic.php?f=46&t=192
http://www.hddoracle.com/viewtopic.php?f=6&t=193
and post the terminal LOG.
DO NOT ISSUE ANY COMMANDS YET.
Attempting to regen translator without checking first for Non-Resident G-List entries on your drive might cause partial access to user area.
To understand the translator sub-system in general - http://www.hddoracle.com/viewtopic.php?f=46&t=1402
Thanks for the links - have a serial terminal cable on hand, now a case of setting up time to do it, I'll be back in the near future, I hope (assuming client wants to proceed).
PostPosted: January 3rd, 2017, 20:45
With all due respect, have you been open with your customer about your lack of the tools, knowledge and experience required to be working on their drive?
PostPosted: January 3rd, 2017, 20:56
ABSOLUTELY NOT. I'm going to go at their drive with a sledge hammer to align the thing-a-me-bob and charge them a non-refundable $15,000 to even try.
I'm not even going to bother.
PostPosted: January 3rd, 2017, 20:58
Spildit wrote:
Ok.
Please let us know if you want to proceed.
You will need to check non-resident G-List for entries and attempt to rebuild translator.
Regards and have a nice day.
Will do, thank you. Most likely I'll outsource this one but it seems at this point the client "believes" they have a backup of the important things, of course, such matters are subject to change on whim as most workshops are aware.
Users browsing this forum: No registered users and 461 guests
