 Post subject: WD20EARS - PCB swap did not help
PostPosted: January 4th, 2017, 9:41
Hello.
I have a WD20EARS-00MVWB0 drive, 2 years ago it was damaged after a shorcut in power source. The PCB has no signs of damage, but drive does not detect or spin.
Now I tried to repair it. There was no important data on this drive. I found a replacement PCB in online store and bought it. Mine was 2060-771698-002 Rev P1, and I received 2060-771698-002 Rev A. Lot description and other online sources told that revP1 and revA are compatible.
So I transferred ROM chip and replaced PCB (and cleaned contacts by the way).
Now drive spins up, but then begins to repeatingly click for 3-4 seconds. Then it appears in device manager as WD20EARS, but in drive management I see it as "uninitialized". "Initialize" command results in "i/o error" popup.
Other disk management programs either do not see it, or report "invalid geometry" or zero size.
Question is:
- Is it a sign that something is wrong with HDD itself or ROM, and there's no point of fixing it?
- or could it be incompatibility of PCB (rev P2 and rev A)?
 Post subject: Re: WD20EARS - PCB swap did not help
PostPosted: January 4th, 2017, 13:12
Could you show pcb's photos?
PostPosted: January 4th, 2017, 15:15
Here they are.
File comment: old PCB
File comment: new PCB
PostPosted: January 4th, 2017, 23:09
HDD can be keep spin with new PCB? PCB compatible
PostPosted: January 5th, 2017, 7:57
No, it does not spin after detection.
PostPosted: January 5th, 2017, 15:17
i got same issue.
i try 3 pcb but it's useless.
PostPosted: January 6th, 2017, 9:00
Any chance the original board only had a damaged TVS (D3, shorted), or 0R link (R67, higher ohms) and nothing else wrong?
You have a backup...right? | Tech Repairs on YouTube
PostPosted: January 6th, 2017, 11:40
I checked D3, R67 and R64 on original PCB with a multimeter. R67 and R64 about 0-1ohm (cheap multimeter cannot measure better), D3 works as diode.
PostPosted: January 6th, 2017, 14:51
I tested D3, R67 and R64 with multimeter. Resistors are 0-1ohms (multimeter cannot measure better), D3 works as diode.
PostPosted: January 7th, 2017, 9:21
What about the tvs located above r64? You need to test that one as well.
PostPosted: January 7th, 2017, 10:49
One above R64 also works as diode, conducts in one direction and does not conduct in opposite. I use diode test mode on multimeter.
Users browsing this forum: No registered users and 271 guests
