 Post subject: WD5000BMVV My Passport not recognized
PostPosted: January 17th, 2017, 16:34
This drive came out of a My Passport with the slow response issue. I soldered on a SATA port and cleared the relo list and disabled background surface scan using hddsupertool.
Afterwards I converted it back to USB to avoid encryption and the drive is now recognized by the computer, but it has no filesystem and ddrescue doesn't read any good blocks (skips everything).
Does this mean the USB firmware is probably corrupted? I have tried a second identical PCB with the original U12 & U14 chips but same result. I have verified that there is no password set on the drive. Would it be possible to get a clean firmware to flash to U14 since the master password has not been changed?
 Post subject: Re: WD5000BMVV My Passport not recognized
PostPosted: January 18th, 2017, 22:30
Yes, I can clone by SATA but no tools to decrypt it because I believe it is 128-bit encryption instead of 256-bit.
PostPosted: January 19th, 2017, 1:56
I would suggest buying the correct tools for data recovery....
PostPosted: January 20th, 2017, 17:33
I did try swapping just the U12 chip but no luck. I'm not 100% sure the U14 USB firmware versions are identical though.
The magic sector does look the same as mod 0x25, however neither of them have the DEK (no ASCII "WDv1" in them). It does look like the correct sector according to this post (a string starting with WD then 0x0114 to confirm key sector found). Is this possibly because it is because it is a 128-bit encryption?
If I uploaded sectors 0 and 1, would someone be able to run 128-bit decryption and see if it's the case?
magic sector.zip [15.89 KiB]
Downloaded 551 times
PostPosted: January 21st, 2017, 21:57
Let's see those sectors
PostPosted: January 22nd, 2017, 19:41
@jermy see attached.
@Spildt I can't really see any major differences in the firmware, and wouldn't any issues have been resolved by swapping the chips? I believe the donor PCB is working but I bought it online so I didn't test it myself.
firmware.zip [434.97 KiB]
Downloaded 413 times
dev4_lba0_2.zip [262 Bytes]
Downloaded 494 times
PostPosted: January 23rd, 2017, 0:47
Are you sure that its the first 2 sectors ?
(Doesn't seems to be, i think something went wrong with the clone)
PostPosted: January 23rd, 2017, 1:19
What makes you say that? Maybe because it's encrypted?
PostPosted: January 23rd, 2017, 2:41
1. On what sector have you found the key ?
2. Can you tell me the marking on the initio chip ?
PostPosted: January 23rd, 2017, 5:34
It's user password encrypted.
Users browsing this forum: Google [Bot] and 251 guests
