 Post subject: Seagate ST3000DM001 spins but not recognized
PostPosted: January 26th, 2017, 7:40
Today I have disk Seagate ST3000DM001 FW:CC27. So at he moment disk spins normally but isn't recognized in bios or OS.
Could you tell me how I should diagnose this disk to find what is a problem? I'm available only terminal cable.
I used I few command and result is below. Probably disk have a lot bed sectors.
F3 7>X
Head 00 Resistance 0153
Head 01 Resistance 00F0
Head 02 Resistance 0155
Head 03 Resistance 0134
Head 04 Resistance 0111
Head 05 Resistance 012D
F3 1>N5
Att
Num  Flgs normlzd worst raw
1   000F   75     63   0000000833C0F0
3   0003   5E     5E   00000000000000
4   0032   64     64   0000000000002F
5   0033   59     59   00000000003688
7   000F   3F     38   00000900F6D919
9   0032   53     53   00000000003C6D
A   0013   64     64   00000000000000
C   0032   64     64   0000000000002F
B7   0032   64     64   00000000000000
B8   0032   64     64   00000000000000
BB   0032   64     64   00000000000000
BC   0032   5D     5D   00000700070007
BD   003A   60     60   00000000000004
BE   0022   3D     2B   00016D80800027
BF   0032   64     64   00000000000000
C0   0032   64     64   00000000000042
C1   0032   57     57   000000000067F3
C2   0022   27     39   00001500000027
C5   0012    1      1   0000000000C658
C6   0010    1      1   0000000000C658
C7   003E   C8     C8   00000000000000
F0   0000   64     FD   0105C200003804
F1   0000   64     FD   000003B8657193
F2   0000   64     FD   00002DF9B33115
0   0000    0      0   00000000000000
F3 T>V10
   4  58E12  58AB2   F1    93248 80 scr fill
P List
  phy   phy    log length
head   cyl    cyl in symb  SFI  flags
Head 0 Entries: CE9
Head 1 Entries: 187
Head 2 Entries: E81
Head 3 Entries: 171A
Head 4 Entries: 387
Head 5 Entries: CBA
  Total Entries: 444C
 Post subject: Re: Seagate ST3000DM001 spins but not recognized
PostPosted: January 26th, 2017, 10:18
If there were bad sectors you could read the user area....I Think you have FW problem
http://www.rescue-it.se
PostPosted: January 26th, 2017, 11:08
Data is not important for me. Only I want try to fix it of course if it is possible using only terminal. could you suggest me what I can do?
PostPosted: January 26th, 2017, 12:44
Lasek, If you have onlu TTL cable, this TTL Cable not help you.
Only PC3K Or Legal firmware soft tool.
Users browsing this forum: Google [Bot] and 207 guests
