 Post subject: ST2000DM001 looking bad... (Canada)
PostPosted: January 31st, 2017, 0:09
Hi all
I have a Seagate ST2000DM001 used as a secondary drive. All of a sudden it disappeared from Explorer; it now shows in Disk Mgr as unitialized and only 128GB in size.
HDD Raw Copy Tool is unable to make an image of the content -- it just shows a series of read errors at every offset.
It contains data which is not overly critical but I'd really like to get it back though!
I live in Montreal -- what are my best options?
(plus I'm *finally* discovering that this model and its 3TB cousin are crap... and the 3TB is my tertiary drive... damn...)
 Post subject: Re: ST2000DM001 looking bad... (Canada)
PostPosted: January 31st, 2017, 9:46
The 2TB are not much better than the 3TB. Your issues could be weak/failing heads, which is quite common. If you are lucky, a few firmware tweaks might be enough to stabilize the drive to be imaged with a hardware imager, without a head change.
My lab, Recovery Force, is in Ontario. If your data is worth our $350 minor rate, it is worth sending our way.
PostPosted: February 1st, 2017, 2:09
If the hard drive clicks and stops, then the drive is expected to have physical damages, or else firmware level damages.
http://www.nowdatarecovery.com
Data Recovery Experts
Users browsing this forum: Google [Bot] and 35 guests
