 Post subject: u14 dead
PostPosted: February 3rd, 2017, 0:07
hi
wd my passport 1tb
i have killed the U14 rom chip that is related to the USB bridge
can i found the firmware for that chip somewhere(this firmware it is specific for each hdd?)
thank you
 Post subject: Re: u14 dead
PostPosted: February 3rd, 2017, 1:43
What is your purpose?
If you want to recover data you don't need U14.
PostPosted: February 3rd, 2017, 4:09
You can collect U14 from another PCB if you still need it. For DR it's not required as replied.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: February 3rd, 2017, 20:41
hi,
yes, i am trying to recover some data.
usb-sata bridge is dead and i have killed the u 14
what kind of information is stored in u 14?
what are my options without u14?
i have a very good elecronical skils (matherboard repaire) but not in hdd repaire,so i need a little bit of help and information
thank you
PostPosted: February 3rd, 2017, 21:11
hi
i have a lot of wd hdd sata matherboards with the same configuration of ram, chipset, and motor driver
i supose that i can change only the bios chip? :!:
what is the next step?
thank you
PostPosted: February 3rd, 2017, 22:18
hi,
hdd model: WD10JMVW-11S5XS0
PCB: 2060-771801-002 rev.A with JMS 538S
and sata board that i found
PCB: 2060-771823-000 rev.A
ReallyMine will decript data for 100%?
THANK YOU
PostPosted: February 4th, 2017, 3:10
JMS538S is supported by reallymine. The encryption is handled by the bridge, not the drive.
In fact, in this case, the absence of U14 would be an advantage. That is, when U14 is removed, the bridge should identify itself as a JMicron rather than a Passport, and the whole drive, including the SmartWare area, should now be visible to the OS.
PostPosted: February 6th, 2017, 15:08
hi
can i change only the jmicron chip
PostPosted: February 6th, 2017, 15:29
Use 771823 with reallymine (after transferring U12).
PostPosted: February 6th, 2017, 16:58
Firebird.
If you have another one the same family and capacity you can take an image from patient to donor via SATA interface and convert the donor to USB interface with it's original USB PCB.
Sure if really mine doesn't work.
Good luck.
PostPosted: February 6th, 2017, 23:35
hi
what do you mean same family?
the same number of board or the same chip(jmicron),
i have a lot of boards with j micron but different year
thank you
PostPosted: February 7th, 2017, 11:30
I meant same model and capacity.
Do you have any DR tools (PC3K, MRT....etc)?
If not, convert it to SATA interface and try reallymine first
Good luck.
PostPosted: February 10th, 2017, 20:18
hi
no i don<t have dr tools
so, heads are dead too.
how can i change them
ther is a sn or i can take from the spare 1tb hdd
some inf please
PostPosted: February 10th, 2017, 20:33
Without any proper tools, you're just wasting your time. You'll never get the drive stable enough after replacing heads to extract all the data.
Users browsing this forum: No registered users and 245 guests
