 Post subject: WD5000LPVX-75V0TT0
PostPosted: March 8th, 2018, 12:34
Hello
This Hubble_LT takes a while to become ready then shows only SN.
No SA/user access
Any thoughts?
Thanks in advance
 Post subject: Re: WD5000LPVX-75V0TT0
PostPosted: March 8th, 2018, 12:37
Is this before or after head swap? If after, there is a chance the donor heads aren't compatible enough.
PostPosted: March 8th, 2018, 12:56
I have just took it from the client. Didn't do anything yet but diagnosis.
PostPosted: March 8th, 2018, 12:59
Have loader to test? Typically it is firmware and heads issues, where one surface is great and the other makes it pull your hairs out.
PostPosted: March 8th, 2018, 13:03
Tried Loader 0005001G, no SA access. ( with and w/o SA blocked )
PostPosted: March 8th, 2018, 13:04
Sounds like head(s) issue. More testing needed.
PostPosted: March 8th, 2018, 13:05
I will try with a donor heads and post results.
Thanks for your inputs.
PostPosted: March 8th, 2018, 14:00
@ labtech,
Thank you very much. Case solved ( heads )
Drive cloning now with ~100MB/s. :)
PostPosted: March 8th, 2018, 15:09
nice, glad it worked out
PostPosted: March 8th, 2018, 15:11
:good:
PostPosted: October 27th, 2020, 16:02
In advance, I would like to thank you very much for your comment.
My friends
I have a 2.5 "HD Western Digital Blue model: WD5000LPVX.
Would you like to know the quantity of Platters of this model?
PostPosted: October 28th, 2020, 9:10
My friends
Better to start your own thread, but anyway, 1 platter 2 heads.
Users browsing this forum: Google [Bot] and 251 guests
