 Post subject: CHKDSK after raw copy?
PostPosted: February 9th, 2017, 15:48
So noob question....
I cloned a seagate 1tb drive to a similar seagate 1tb drive and everything looked like it went pretty smooth. What is the typical next step? Chkdsk the drive to try and repair some of the damaged/missing sectors? Straight to data recovery with GetDataBack/EasyRecovery/Easeus? Surface test?
Thanks!
James
 Post subject: Re: CHKDSK after raw copy?
PostPosted: February 9th, 2017, 16:04
Don't run chkdsk!
PostPosted: February 9th, 2017, 16:20
Don't Chkdsk the non-faulty disk? What is the reasoning behind this? Is there a better tool or strategy?
PostPosted: February 9th, 2017, 17:53
What tool did you use to make the cloning ?
How many sectors weren´t cloned ?
If all went well, you do not need to check the image, just recover files from it.
PostPosted: February 9th, 2017, 18:00
I used HDDGuru's Raw Copy Tool. It finished but I accidentally rebooted before I copied the log. There were only about 5 lines of bad sectors listed near the end of cloning.
So do you just use Windows to recover the files, unstoppable copier, or something else?
PostPosted: February 9th, 2017, 18:20
Run R-Studio on the clone.
http://www.rescue-it.se
PostPosted: February 10th, 2017, 3:35
Chkdsk is a poor utility, it can often make matters worse. There is no need to run it, and it's advisable not to let it try!
Simply use a recovery software such as getdataback, reclaime or rstudio to scan your clone and copy the data to another drive.
Good luck!
PostPosted: February 10th, 2017, 3:38
Thanks!
I used Unstoppable Copier and got 99% of the data off! Now for the nitty gritty. Thanks for the advice it helped a ton!
James
Users browsing this forum: No registered users and 61 guests
