 Post subject: ST1000LM024 - possible stiction issue - where to fix in AU?
PostPosted: February 9th, 2017, 23:46
I have a ST1000LM024 which has come from an portable enclosure unit.
When it attempts to power up it produces perhaps a dozen or more short, fast soft-sounding beeps (about 10/sec). No platter spin-up that I can perceive.
Stiction perhaps? If so, recommendations on where to get it resolved so I can pass it on to my client so they can then deal with them directly?
Regards,
Paul.
You have a backup...right? | Tech Repairs on YouTube
 Post subject: Re: ST1000LM024 - possible stiction issue - where to fix in
PostPosted: February 10th, 2017, 2:45
No spin up + buzzing sound then definitely stiction.
These drives are also very prone to this kind of damage.
PostPosted: February 10th, 2017, 2:57
Thanks for the response. Do they typically end up needing new head assemblies, or do they just have the stiction resolved and then clone the drive? I suppose realistically it's too subjective to say one way or the other.
Hopefully someone here in AU will chime in with a local cleanroom who can do it.
Regards,
Paul.
PostPosted: February 10th, 2017, 4:26
They usually don't need a head transplant. But as you said, there is no general rule, it depends on what happened to the drive.
Generally they're good drives to work with.
PostPosted: February 10th, 2017, 5:20
Thanks. If I was over in Greece I'd send it over to you.
