 Post subject: need help to recover RAID0 drives
PostPosted: March 4th, 2017, 18:07
HI all
This is my first post and it will be a long one… I am sorry about this.
I need help, I am not that good with HDD’s but I can’t find anyone who can help me with my RAID0 problem. Here is my problem,. I have 2 Seagate cuda’s 300GB’s running RAID0 (sorry about that). I was not able to get any of my files so I gave my drives to one (PRO). After about a week he told me that my first drive is dying and the end of the week died completely. He was able to get some info from it but when he gave me a flash drive … all files where unreadable. (Pictures are all destroyed no avi’s). He did tell me that I have a bad board.
My second drive has a good board and it is the same model as the first one, S/N is deferent.
So, here are questions that I have.
Can I take board from the good one and replace the bad one, use a recovery program to read it?
If this is ok to do, what program would you recommend?
if everything works out (I hope) and I get saved recovery image( or whatever that is called) can I make a virtual RAID0 so that I can mount both drives and hopefully recover all my files.
All help and explanations would be highly appreciated
Thank you for reading
Fandi1
 Post subject: Re: need help to recover RAID0 drives
PostPosted: March 4th, 2017, 21:09
Clone the good drive, sector by sector, with a tool such as ddrescue or HDDSuperClone. These tools understand how to work with bad sectors. They also maintain a log which enables the process to resume after an interruption.
What is the model number of your drives?
Does the drive with the bad PCB spin up? If so, does it make any bad noises?
Can you show us a SMART report? You could use tools such as CrystalDiskInfo (Windows) or smartctl (Linux).
PostPosted: March 5th, 2017, 10:46
Hi and thank you for looking.
1. my drive is barracuda model st3000dm001
2. bed drive spins without any unusual noise
3. what drive do you want me to get smart report of?
PostPosted: March 5th, 2017, 11:22
i hope it's ok to post this here like this
thanks for the look
CrystalDiskInfo 5.6.2 (C) 2008-2013 hiyohiyo
Crystal Dew World : http://crystalmark.info/
OS : Windows 8 Pro [6.2 Build 9200] (x64)
Date : 2017/03/05 10:13:32
-- Controller Map ----------------------------------------------------------
- Standard SATA AHCI Controller [ATA]
+ Standard SATA AHCI Controller [ATA]
- ST3000DM001-1CH166
- Samsung SSD 850 EVO 250GB
- ASUS DRW-24B1ST i
- LITE-ON DVDRW LH-20A1L
- Microsoft Storage Spaces Controller [SCSI]
-- Disk List ---------------------------------------------------------------
(1) ST3000DM001-1CH166 : 3000.5 GB [0/1/0, pd1] - st
(2) ST3000DM001-1CH166 : 4294967.2 GB [1/1/0, pd1]
(3) Samsung SSD 850 EVO 250GB : 250.0 GB [2/1/0, pd1] - sg
(4) WDC WD20EARS-00MVWB0 : 2000.3 GB [3/0/0, sa1] - wd
(5) WDC WD1600BEVS-00RST0 : 160.0 GB [5/0/0, sa1] - wd
Model : ST3000DM001-1CH166
Firmware : CC27
Serial Number : W1F3P7CP
Disk Size : 3000.5 GB (8.4/137.4/3000.5/3000.5)
Buffer Size : Unknown
Queue Depth : 32
# of Sectors : 5860533168
Rotation Rate : 7200 RPM
Interface : Serial ATA
Major Version : ACS-2
Minor Version : ACS-3 Revision 3b
Transfer Mode : SATA/600
Power On Hours : 25747 hours
Power On Count : 113 count
Temparature : 25 C (77 F)
Health Status : Caution
Features : S.M.A.R.T., APM, 48bit LBA, NCQ
APM Level : 8080h [ON]
AAM Level : ----
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 108 _98 __6 000000FB82F0 Read Error Rate
03 _94 _94 __0 000000000000 Spin-Up Time
04 _94 _94 _20 00000000180D Start/Stop Count
05 100 100 _10 000000000000 Reallocated Sectors Count
07 _40 _32 _30 066800E67263 Seek Error Rate
09 _71 _71 __0 000000006493 Power-On Hours
0A 100 100 _97 000000000000 Spin Retry Count
0C 100 100 _20 000000000071 Power Cycle Count
B7 100 100 __0 000000000000 Unknown
B8 _97 _97 _99 000000000003 End-to-End Error
BB __1 __1 __0 000000000070 Reported Uncorrectable Errors
BC 100 100 __0 000000000000 Command Timeout
BD 100 100 __0 000000000000 High Fly Writes
BE _75 _58 _45 000119110019 Airflow Temperature
BF 100 100 __0 000000000000 G-Sense Error Rate
C0 100 100 __0 000000000040 Power-off Retract Count
C1 __1 __1 __0 000000033976 Load/Unload Cycle Count
C2 _25 _42 __0 800000000019 Temperature
C5 100 100 __0 000000000028 Current Pending Sector Count
C6 100 100 __0 000000000028 Uncorrectable Sector Count
C7 200 200 __0 000000000000 UltraDMA CRC Error Count
F0 100 253 __0 8F7400001DAF Head Flying Hours
F1 100 253 __0 00006D816895 Total Host Writes
F2 100 253 __0 00089F6EE56A Total Host Reads
-- IDENTIFY_DEVICE ---------------------------------------------------------
0 1 2 3 4 5 6 7 8 9
000: 0C5A 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 2020 2020 2020 2020 2020 2020 5731 4633 5037 4350
020: 0000 0000 0004 4343 3237 2020 2020 5354 3330 3030
030: 444D 3030 312D 3143 4831 3636 2020 2020 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 4000 2F00
050: 4000 0200 0200 0007 3FFF 0010 003F FC10 00FB 0110
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0000
070: 0000 0000 0000 0000 0000 001F 850E 0006 004C 0040
080: 03F0 001F 346B 7D69 4163 3469 BC49 4163 207F 00A0
090: 00A0 8080 FFFE 0000 D000 0000 0000 0000 0000 0000
100: A3B0 5D50 0001 0000 0000 0000 6003 0000 5000 C500
110: 6A9C 0041 0000 0000 0000 0000 0000 0000 0000 401E
120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 A3B0
130: 5D50 A3B0 5D50 2020 0002 0140 0100 5000 3C06 3C0A
140: 0000 003C 0000 0008 0000 0000 05FF 0280 0000 0000
150: 0008 0000 0000 0000 0000 0000 0000 0000 5800 8800
160: 0000 0000 0000 0000 0000 0000 0000 0000 0002 0000
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 3085 0000 0000 4000
210: 0000 0000 0000 0000 0000 0000 0000 1C20 0000 0000
220: 0000 0000 107E 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
240: 0000 0000 0000 0003 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 BEA5
-- SMART_READ_DATA ---------------------------------------------------------
+0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 0A 00 01 0F 00 6C 62 F0 82 FB 00 00 00 00 03 03
010: 00 5E 5E 00 00 00 00 00 00 00 04 32 00 5E 5E 0D
020: 18 00 00 00 00 00 05 33 00 64 64 00 00 00 00 00
030: 00 00 07 0F 00 28 20 63 72 E6 00 68 06 00 09 32
040: 00 47 47 93 64 00 00 00 00 00 0A 13 00 64 64 00
050: 00 00 00 00 00 00 0C 32 00 64 64 71 00 00 00 00
060: 00 00 B7 32 00 64 64 00 00 00 00 00 00 00 B8 32
070: 00 61 61 03 00 00 00 00 00 00 BB 32 00 01 01 70
080: 00 00 00 00 00 00 BC 32 00 64 64 00 00 00 00 00
090: 00 00 BD 3A 00 64 64 00 00 00 00 00 00 00 BE 22
0A0: 00 4B 3A 19 00 11 19 01 00 00 BF 32 00 64 64 00
0B0: 00 00 00 00 00 00 C0 32 00 64 64 40 00 00 00 00
0C0: 00 00 C1 32 00 01 01 76 39 03 00 00 00 00 C2 22
0D0: 00 19 2A 19 00 00 00 00 80 00 C5 12 00 64 64 28
0E0: 00 00 00 00 00 00 C6 10 00 64 64 28 00 00 00 00
0F0: 00 00 C7 3E 00 C8 C8 00 00 00 00 00 00 00 F0 00
100: 00 64 FD AF 1D 00 00 74 8F 1C F1 00 00 64 FD 95
110: 68 81 6D 00 00 00 F2 00 00 64 FD 6A E5 6E 9F 08
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 48 02 00 73
170: 03 00 01 00 01 FF 02 4E 01 00 00 00 00 00 00 00
180: 00 00 00 00 9B 08 00 00 05 06 06 06 06 06 06 06
190: 06 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 01 00 5E CE 9D EB 4C 54 00 00
1B0: 00 00 00 00 01 00 90 6C 95 68 81 6D 00 00 00 00
1C0: 6A E5 6E 9F 08 00 00 00 00 00 00 00 00 00 00 00
1D0: 00 00 00 00 00 00 00 00 98 00 00 00 01 00 00 00
1E0: 00 00 00 00 C0 01 00 00 00 00 00 00 00 00 00 02
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FE
-- SMART_READ_THRESHOLD ----------------------------------------------------
000: 01 00 01 06 00 00 00 00 00 00 00 00 00 00 03 00
010: 00 00 00 00 00 00 00 00 00 00 04 14 00 00 00 00
020: 00 00 00 00 00 00 05 0A 00 00 00 00 00 00 00 00
030: 00 00 07 1E 00 00 00 00 00 00 00 00 00 00 09 00
040: 00 00 00 00 00 00 00 00 00 00 0A 61 00 00 00 00
050: 00 00 00 00 00 00 0C 14 00 00 00 00 00 00 00 00
060: 00 00 B7 00 00 00 00 00 00 00 00 00 00 00 B8 63
070: 00 00 00 00 00 00 00 00 00 00 BB 00 00 00 00 00
080: 00 00 00 00 00 00 BC 00 00 00 00 00 00 00 00 00
090: 00 00 BD 00 00 00 00 00 00 00 00 00 00 00 BE 2D
0A0: 00 00 00 00 00 00 00 00 00 00 BF 00 00 00 00 00
0B0: 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00
0C0: 00 00 C1 00 00 00 00 00 00 00 00 00 00 00 C2 00
0D0: 00 00 00 00 00 00 00 00 00 00 C5 00 00 00 00 00
0E0: 00 00 00 00 00 00 C6 00 00 00 00 00 00 00 00 00
0F0: 00 00 C7 00 00 00 00 00 00 00 00 00 00 00 F0 00
100: 00 00 00 00 00 00 00 00 00 00 F1 00 00 00 00 00
110: 00 00 00 00 00 00 F2 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FD
Firmware : CC27
Serial Number : Z1F3JT15
Disk Size : 4294967.2 GB (8.4/137.4/3000.5/4294967.2)
Queue Depth : 32
Power On Hours : Unknown
Power On Count : Unknown
Temparature : Unknown
Health Status : Unknown
AAM Level : ----
0 1 2 3 4 5 6 7 8 9
010: 2020 2020 2020 2020 2020 2020 5A31 4633 4A54 3135
050: 4000 0200 0200 0007 3FFF 0010 003F FC10 00FB 0010
060: FFFF 0FFF 0000 0407 0003 0078 0078 0078 0078 0000
080: 03F0 001F 346B 7D69 4163 3469 BC49 4163 007F 00A1
090: 00A1 8080 FFFE 0000 D000 0000 0000 0000 0000 0000
110: 644B 289A 0000 0000 0000 0000 0000 0000 0000 401E
120: 401C 0000 0000 0000 0000 0000 0000 0000 0021 A3B0
250: 0000 0000 0000 0000 0000 CAA5
000: CF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Model : Samsung SSD 850 EVO 250GB
Firmware : EMT02B6Q
Serial Number : S2R5NB0HB26151Y
Disk Size : 250.0 GB (8.4/137.4/250.0/250.0)
Queue Depth : 32
# of Sectors : 488397168
Rotation Rate : ---- (SSD)
Minor Version : ATA8-ACS version 4c
Power On Hours : 757 hours
Power On Count : 23 count
Host Writes : 611 GB
Wear Level Count : 2
Temparature : 21 C (69 F)
Health Status : Good (100 %)
Features : S.M.A.R.T., 48bit LBA, NCQ, TRIM
APM Level : ----
AAM Level : ----
05 100 100 _10 000000000000 Reallocated Sector Count
09 _99 _99 __0 0000000002F5 Power-on Hours
0C _99 _99 __0 000000000017 Power-on Count
B1 _99 _99 __0 000000000002 Wear Leveling Count
B3 100 100 _10 000000000000 Used Reserved Block Count (Total)
B5 100 100 _10 000000000000 Program Fail Count (Total)
B6 100 100 _10 000000000000 Erase Fail Count (Total)
B7 100 100 _10 000000000000 Runtime Bad Block (Total)
BB 100 100 __0 000000000000 Uncorrectable Error Count
BE _79 _64 __0 000000000015 Airflow Temperature
C3 200 200 __0 000000000000 ECC Error Rate
C7 100 100 __0 000000000000 CRC Error Count
EB _99 _99 __0 00000000000E POR Recovery Count
F1 _99 _99 __0 00004C71F301 Total LBA Written
0 1 2 3 4 5 6 7 8 9
000: 0040 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 5332 5235 4E42 3048 4232 3631 3531 5920 2020 2020
020: 0000 0000 0000 454D 5430 3242 3651 5361 6D73 756E
030: 6720 5353 4420 3835 3020 4556 4F20 3235 3047 4220
040: 2020 2020 2020 2020 2020 2020 2020 8001 4001 2F00
050: 4000 0200 0200 0007 3FFF 0010 003F FC10 00FB 0101
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0F10
070: 0000 0000 0000 0000 0000 001F 850E 00C4 016C 0060
080: 03FC 0039 746B 7D01 4163 7469 BC01 4163 207F 0001
090: 0004 0000 FFFE 0000 0000 0000 0000 0000 0000 0000
100: 5970 1D1C 0000 0000 0000 0008 4000 0000 5002 538D
110: 416E 2456 0000 0000 0000 0000 0000 0000 0000 401E
120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 0000
130: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
140: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
150: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0003 0001
170: 2020 2020 2020 2020 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 003D 0000 0000 4000
210: 0000 0000 0000 0000 0000 0000 0000 0001 0000 0000
220: 0000 0000 107F 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0000 0800 0000 0000 0000 0000
240: 0000 0000 0000 4000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 3EA5
000: 01 00 05 33 00 64 64 00 00 00 00 00 00 00 09 32
010: 00 63 63 F5 02 00 00 00 00 00 0C 32 00 63 63 17
020: 00 00 00 00 00 00 B1 13 00 63 63 02 00 00 00 00
030: 00 00 B3 13 00 64 64 00 00 00 00 00 00 00 B5 32
040: 00 64 64 00 00 00 00 00 00 00 B6 32 00 64 64 00
050: 00 00 00 00 00 00 B7 13 00 64 64 00 00 00 00 00
060: 00 00 BB 32 00 64 64 00 00 00 00 00 00 00 BE 32
070: 00 4F 40 15 00 00 00 00 00 00 C3 1A 00 C8 C8 00
080: 00 00 00 00 00 00 C7 3E 00 64 64 00 00 00 00 00
090: 00 00 EB 12 00 63 63 0E 00 00 00 00 00 00 F1 32
0A0: 00 63 63 01 F3 71 4C 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53
170: 03 00 01 00 02 85 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 15
000: 01 00 05 0A 00 00 00 00 00 00 00 00 00 00 09 00
010: 00 00 00 00 00 00 00 00 00 00 0C 00 00 00 00 00
020: 00 00 00 00 00 00 B1 00 00 00 00 00 00 00 00 00
030: 00 00 B3 0A 00 00 00 00 00 00 00 00 00 00 B5 0A
040: 00 00 00 00 00 00 00 00 00 00 B6 0A 00 00 00 00
050: 00 00 00 00 00 00 B7 0A 00 00 00 00 00 00 00 00
060: 00 00 BB 00 00 00 00 00 00 00 00 00 00 00 BE 00
070: 00 00 00 00 00 00 00 00 00 00 C3 00 00 00 00 00
080: 00 00 00 00 00 00 C7 00 00 00 00 00 00 00 00 00
090: 00 00 EB 00 00 00 00 00 00 00 00 00 00 00 F1 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4E
Enclosure : WD My Book 1130 USB Device (V=1058, P=1130, sa1) - wd
Model : WDC WD20EARS-00MVWB0
Firmware : 51.0AB51
Serial Number : WD-WCAZA5177620
Disk Size : 2000.3 GB (8.4/137.4/2000.3/2000.3)
Queue Depth : 32
# of Sectors : 3907029168
Rotation Rate : Unknown
Interface : USB (Serial ATA)
Major Version : ATA8-ACS
Minor Version : ----
Transfer Mode : SATA/300
Power On Hours : 1622 hours
Power On Count : 1987 count
Temparature : 27 C (80 F)
Features : S.M.A.R.T., AAM, 48bit LBA, NCQ
APM Level : ----
AAM Level : 80FEh [OFF]
01 136 127 _51 000000002A00 Read Error Rate
03 253 253 _21 00000000046D Spin-Up Time
04 _99 _99 __0 0000000007C8 Start/Stop Count
05 200 200 140 000000000000 Reallocated Sectors Count
07 200 200 __0 000000000000 Seek Error Rate
09 _98 _98 __0 000000000656 Power-On Hours
0A 100 100 __0 000000000000 Spin Retry Count
0B 100 100 __0 000000000000 Recalibration Retries
0C _99 _99 __0 0000000007C3 Power Cycle Count
C0 200 200 __0 00000000009D Power-off Retract Count
C1 191 191 __0 000000006BE7 Load/Unload Cycle Count
C2 123 100 __0 00000000001B Temperature
C4 200 200 __0 000000000000 Reallocation Event Count
C5 200 200 __0 000000000015 Current Pending Sector Count
C6 200 200 __0 000000000015 Uncorrectable Sector Count
C8 200 200 __0 000000000015 Write Error Rate
0 1 2 3 4 5 6 7 8 9
000: 427A 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 2020 2020 2057 442D 5743 415A 4135 3137 3736 3230
020: 0000 0000 0032 3531 2E30 4142 3531 5744 4320 5744
030: 3230 4541 5253 2D30 304D 5657 4230 2020 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 0000 2F00
050: 4001 0000 0000 0007 3FFF 0010 003F FC10 00FB 0100
060: FFFF 0FFF 0000 0107 0003 0078 0078 0078 0078 0000
070: 0000 0000 0000 0000 0000 001F 1706 0000 0044 0040
080: 01FE 0000 746B 7F61 4123 7469 BC41 4123 007F 00BB
090: 00BB 0000 FFFE 0000 80FE 0000 0000 0000 0000 0000
100: 88B0 E8E0 0000 0000 0000 0000 0000 0000 5001 4EE2
110: B04B 21AC 0000 0000 0000 0000 0000 0000 0000 401C
120: 401C 0000 0000 0000 0000 0000 0000 0000 0021 0000
140: 0000 0000 0004 0000 0000 0000 0000 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 3035 0000 0000 0000
210: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
220: 0000 0000 101E 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0001 1000 0000 0000 0000 0000
240: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 5EA5
000: 10 00 01 2F 00 88 7F 00 2A 00 00 00 00 00 03 27
010: 00 FD FD 6D 04 00 00 00 00 00 04 32 00 63 63 C8
020: 07 00 00 00 00 00 05 33 00 C8 C8 00 00 00 00 00
030: 00 00 07 2E 00 C8 C8 00 00 00 00 00 00 00 09 32
040: 00 62 62 56 06 00 00 00 00 00 0A 32 00 64 64 00
050: 00 00 00 00 00 00 0B 32 00 64 64 00 00 00 00 00
060: 00 00 0C 32 00 63 63 C3 07 00 00 00 00 00 C0 32
070: 00 C8 C8 9D 00 00 00 00 00 00 C1 32 00 BF BF E7
080: 6B 00 00 00 00 00 C2 22 00 7B 64 1B 00 00 00 00
090: 00 00 C4 32 00 C8 C8 00 00 00 00 00 00 00 C5 32
0A0: 00 C8 C8 15 00 00 00 00 00 00 C6 30 00 C8 C8 15
0B0: 00 00 00 00 00 00 C7 32 00 C8 C8 00 00 00 00 00
0C0: 00 00 C8 08 00 C8 C8 15 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 82 00 AC 8F 01 7B
170: 03 00 01 00 02 FF 05 63 01 00 00 00 00 00 00 00
180: 00 00 01 06 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 47
000: 10 00 01 33 C8 A9 C8 88 C8 C8 00 00 00 00 03 15
010: 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00
020: 00 00 00 00 00 00 05 8C 00 00 00 00 00 00 00 00
030: 00 00 07 00 C8 C8 C8 C8 C8 C8 00 00 00 00 09 00
040: 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00
050: 00 00 00 00 00 00 0B 00 00 00 00 00 00 00 00 00
060: 00 00 0C 00 00 00 00 00 00 00 00 00 00 00 C0 00
070: 00 00 00 00 00 00 00 00 00 00 C1 00 00 00 00 00
080: 00 00 00 00 00 00 C2 00 00 00 00 00 00 00 00 00
090: 00 00 C4 00 00 00 00 00 00 00 00 00 00 00 C5 00
0A0: 00 00 00 00 00 00 00 00 00 00 C6 00 01 12 00 01
0B0: 00 01 00 00 00 00 C7 00 00 00 00 00 00 00 00 00
0C0: 00 00 C8 00 C8 C8 C8 C8 C8 C8 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F7
Enclosure : WD 1600BEV External USB Device (V=1058, P=0702, sa1) - wd
Model : WDC WD1600BEVS-00RST0
Firmware : 04.01G04
Serial Number : WD-WXE807488740
Disk Size : 160.0 GB (8.4/137.4/160.0/160.0)
Buffer Size : 8192 KB
Queue Depth : 32
# of Sectors : 312581808
Major Version : ATA/ATAPI-7
Transfer Mode : SATA/150
Power On Hours : 1409 hours
Power On Count : 572 count
Temparature : 26 C (78 F)
Features : S.M.A.R.T., APM, AAM, 48bit LBA, NCQ
APM Level : 0080h [ON]
AAM Level : 80FEh [ON]
01 131 130 _51 00000000162D Read Error Rate
03 145 132 _21 000000000E8D Spin-Up Time
04 _99 _99 __0 000000000478 Start/Stop Count
07 200 200 _51 000000000000 Seek Error Rate
09 _99 _99 __0 000000000581 Power-On Hours
0A 100 100 _51 000000000000 Spin Retry Count
0B 100 100 _51 000000000000 Recalibration Retries
0C 100 100 __0 00000000023C Power Cycle Count
C0 200 200 __0 0000000001AE Power-off Retract Count
C1 199 199 __0 000000000D73 Load/Unload Cycle Count
C2 121 _97 __0 00000000001A Temperature
C5 199 199 __0 000000000027 Current Pending Sector Count
C6 100 253 __0 000000000000 Uncorrectable Sector Count
C8 100 253 _51 000000000000 Write Error Rate
0 1 2 3 4 5 6 7 8 9
010: 2020 2020 2057 442D 5758 4538 3037 3438 3837 3430
020: 0000 4000 0032 3034 2E30 3147 3034 5744 4320 5744
030: 3136 3030 4245 5653 2D30 3052 5354 3020 2020 2020
070: 0000 0000 0000 0000 0000 001F 0702 0000 004C 0040
080: 00FE 0000 746B 7F09 6163 7469 BE09 6163 407F 0024
090: 0000 0080 FFFE 0000 80FE 0000 0000 0000 0000 0000
100: 9EB0 12A1 0000 0000 0000 0000 0000 0000 5001 4EE2
110: 55D9 3CF5 0000 0000 0000 0000 0000 0000 0000 4010
120: 4010 0000 0000 0000 0000 0000 0000 0000 0001 0000
130: 0000 0000 0000 1678 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 103F 0000 0000 0000
220: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0001 0800 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 02A5
000: 10 00 01 0F 00 83 82 2D 16 00 00 00 00 00 03 03
010: 00 91 84 8D 0E 00 00 00 00 00 04 32 00 63 63 78
020: 04 00 00 00 00 00 05 33 00 C8 C8 00 00 00 00 00
030: 00 00 07 0F 00 C8 C8 00 00 00 00 00 00 00 09 32
040: 00 63 63 81 05 00 00 00 00 00 0A 13 00 64 64 00
050: 00 00 00 00 00 00 0B 12 00 64 64 00 00 00 00 00
060: 00 00 0C 32 00 64 64 3C 02 00 00 00 00 00 C0 32
070: 00 C8 C8 AE 01 00 00 00 00 00 C1 32 00 C7 C7 73
080: 0D 00 00 00 00 00 C2 22 00 79 61 1A 00 00 00 00
090: 00 00 C4 32 00 C8 C8 00 00 00 00 00 00 00 C5 12
0A0: 00 C7 C7 27 00 00 00 00 00 00 C6 10 00 64 FD 00
0B0: 00 00 00 00 00 00 C7 3E 00 C8 C8 00 00 00 00 00
0C0: 00 00 C8 09 00 64 FD 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 20 1C 01 7B
170: 03 00 01 00 02 5C 06 00 00 00 00 00 00 00 00 00
180: 00 00 01 04 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28
000: 10 00 01 33 C8 C8 C8 83 00 00 00 00 00 00 03 15
030: 00 00 07 33 C8 C8 C8 C8 00 00 00 00 00 00 09 00
040: 00 00 00 00 00 00 00 00 00 00 0A 33 00 00 00 00
050: 00 00 00 00 00 00 0B 33 00 00 00 00 00 00 00 00
0A0: 00 00 00 00 00 00 00 00 00 00 C6 00 00 00 00 00
0B0: 00 00 00 00 00 00 C7 00 00 00 00 00 00 00 00 00
0C0: 00 00 C8 33 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F6
PostPosted: March 5th, 2017, 11:28
smart report.txt [34.96 KiB]
Downloaded 779 times
i have attached report here ... thank you for the look
PostPosted: March 5th, 2017, 12:18
You have attached a SMART report of 5 drives
I assume the RAID0 you referring to are 2xST3000DMxxx ?!
1. Judging by the drives model I would say replacing the board (PCB) will not help you
2. Since you say it doesn't make unusual noise, I would start with a terminal log
3. Almost sure there is problems with MC/heads and or media damage
PostPosted: March 5th, 2017, 12:26
I fully agree with Jeremy on this. The problem won't be the PCB and replacing that is only going to further complicate the situation. These drives are very prone to issues with the firmware specifically related to the media cache. They also have weak heads, but if that were the issue usually the drive would click and spin back down rather than sound normal. The fact that the drive is able to read ID for the SMART report but didn't actually read any SMART info pretty much confirms that the issue is either the media cache or bad sector re-allocation firmware bug.
It's an easy enough fix with the right tools and experience to get the data extracted. However, DIY is going to be a tough route and you'll most likely not succeed. I'm not going to say impossible, I'm sure a few guys w/o pro tools have been able to accomplish the task if the issue wasn't too bad, but most give up long before they make any progress.
Just to give you a baseline, we charge a flat $450 to recover drives with that issue, so long as the heads haven't failed.
I would guess your original "pro" was more of a computer repair tech, than an actual data recovery professional. PC repair guys are not going to have the proper tools to really work with failing drives and most often all they accomplish is running up the cost of recovery by causing more damage to the drives.
PostPosted: March 5th, 2017, 14:52
@fandi1, if the problem is confined to media cache and/or firmware bug, then there is potentially a simple DIY solution. To this end you would need a TTL adapter to access the drive's terminal log.
BTW, your WD drives have Current Pending sectors that you need to keep an eye on. Also, the Read Error Rate is non-zero, so watch that attribute as well.
PostPosted: March 5th, 2017, 22:19
The first thing that a "pro" would do would be to diagnose the problem and evaluate the failure(s).
We typically remove the heads in this family of drives and check for head contamination and media damage as part of the diagnostic process. If a drive has contaminated heads, then trying to copy data off of it in that state could destroy it quickly -- some drives with head and media issues are prone to quick degradation.
Assuming the heads checked out OK, the next step would be to use a hardware imager to make a clone of the drive(s). I'm unfamiliar with the software tools recommenced to copy the drives, but I would generally avoid software programs -- AFAIK they do not turn off SMART and sector reallocation.
If a drive has hardware issues, YOU CANNOT USE A SOFTWARE PROGRAM TO ADDRESS A HARDWARE FAILURE.
If a failing drive was run for a long time (a week???) in failing mode, the drive may become unrecoverable.
You need to get good images of BOTH DRIVES to get an acceptable recovery with RAID 0 - the strip sizes are often smaller than file sizes!
We don't know what intervention your "pro" provided; their tools; level of expertise, and the current condition of the failed drive. If they do not use best practices, your data may have been put at [unnecessary] risk along with your chances for recovery.
If your data is important, I recommend that you STOP what you are doing, and send BOTH drives to a known competent firm to see what your chances of recovery are at this point.
RAID 0 recoveries with one failing drive should not, IMO, be attempted as a DIY project.
http://www.datasaversllc.com
PostPosted: March 6th, 2017, 11:34
Well said Jon. If you don't care about your data and have no intention of paying someone to recover the data, then go ahead and follow the DIY instructions. The end result will likely be a fatal crash and burn. But, if there is any chance that you would consider paying for a professional to recover your data, it is best to do it while the data might still be recoverable.
PostPosted: March 6th, 2017, 14:09
I would like to thank everyone who looked at my post and replied to me.
in the nutshell, this data is important to me it has pictures and avi's of my kids.
i don't understand enough to even think about opening case and i would like someone to look at my drives
data-medics ... i would like to take you upon your offer of fixing my drive i will try to contact you.
thank you again all
PostPosted: March 6th, 2017, 14:11
How do I keep an eye on it? lol Like this? :shock:
thank's please let me know what to do ... should i get new drives?
PostPosted: March 6th, 2017, 14:41
Keep an eye means:
* backup your data (even from a good drive)
* don't save valuable data - you cant afford to lose - on it
PostPosted: March 6th, 2017, 14:54
Here is a potential DIY solution:
http://www.hddoracle.com/viewtopic.php?f=59&t=1842&start=60
viewtopic.php?f=1&t=34631
F"READ_SPARING_ENABLED",0,22
F"WRITE_SPARING_ENABLED",0,22
F"OFFLINE_SPARING_ENABLED",0,22
F"DAR_ENABLED",0,22
F"DISABLE_IDLE_ACTIVITY",1,22
F"BGMS_DISABLE_DATA_REFRESH",1,22
F"ABORT_PREFETCH",1,22
F"READ_LOOKAHEAD_DISABLED_ON_POWER_UP",1,22
F"READ_CACHING_DISABLED_ON_POWER_UP",1,22
PostPosted: March 6th, 2017, 15:39
F"DAR_ENABLED",0,22
sigh... i was lost on the 2nd line
i rather have someone help me for a Reasonable price
thank you
PostPosted: March 6th, 2017, 15:43
jermy wrote:
Keep an eye means:
i think i will get a new drives
PostPosted: March 6th, 2017, 17:52
Keep monitoring the SMART attributes. If the raw values start to rise, then be prepared to remove the drive from service. As already advised, maintain regular backups.
PostPosted: March 6th, 2017, 21:51
Maybe you can explain to me how this is going to help the OP when the other drive of a RAID 0 has "failed completely?"
I'm not sure I understand the benefits. The downsides seem pretty clear -- the remaining "good" drive could become unrecoverable, so why risk it, if the first (bad) drive is going to require clean room assessment of the damage anyway?
I wish you could look over my shoulder sometimes at the MANY drives we receive from clients who read advice like yours, and go full speed ahead without checking for sand bars, or even if there is any gas left in the tank, before they launch out to sea . . . and later discover they are over their heads, or the boat is taking on water . . .
Maybe you should have a disclaimer and warning with your posts, as a standard feature?
PostPosted: March 6th, 2017, 22:11
fandi1 wrote:
jermy wrote:
Keep an eye means:
The drives aren't the real problem here. The true problem is that you are using RAID 0 to store crucial data that isn't backed up. At the very least use RAID 1, or even better RAID 6 and an offsite backup.
PostPosted: March 6th, 2017, 22:15
Read it again ... slowly this time.
