 Post subject: extended test never stops
PostPosted: March 4th, 2017, 11:28
I have two twin hard drives (Toshiba 1TB). One long/extended test was passed and end after 4 hour but the second one lasts forever (at the moment about 10h).
smartctl result:
https://paste.ofcode.org/XfJpJtTmFmHEZJzzctd6k7
https://paste.ofcode.org/bNdTZFqRJ3iZNZJyGgtTiF
Where is the problem?! Should i run 'dd' command and overwrite all the disk?!
 Post subject: Re: extended test never stops
PostPosted: March 4th, 2017, 16:41
Something doesn't look right with the Current Pending Sector attribute. How does it compare with your other drive?
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000b   100   100   050    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0005   100   100   050    Pre-fail  Offline      -       0
  3 Spin_Up_Time            0x0027   100   100   001    Pre-fail  Always       -       1764
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       2
  5 Reallocated_Sector_Ct   0x0033   100   100   050    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000b   100   100   050    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   100   100   050    Pre-fail  Offline      -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       18
10 Spin_Retry_Count        0x0033   100   100   030    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       2
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       0
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       2
194 Temperature_Celsius     0x0022   100   100   000    Old_age   Always       -       33 (Min/Max 22/44)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   100   100   000    Old_age   Always       -       16376
198 Offline_Uncorrectable   0x0030   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
220 Disk_Shift              0x0002   100   100   000    Old_age   Always       -       0
222 Loaded_Hours            0x0032   100   100   000    Old_age   Always       -       0
223 Load_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
224 Load_Friction           0x0022   100   100   000    Old_age   Always       -       0
226 Load-in_Time            0x0026   100   100   000    Old_age   Always       -       188
240 Head_Flying_Hours       0x0001   100   100   001    Pre-fail  Offline      -       0
Users browsing this forum: No registered users and 31 guests
